Question about Linksys CIT400
Audio problem I just bought this phone. When calling, it rings on both ends but neither side can hear the other talking, just dead silence. It has to be a setting somewhere.
  • 1 more comment
  • Anonymous Mar 15, 2008
    I've had mine for over a year, and it just started doing the same thing in the last few weeks. I'm wondering if something changed at skype? I never had this issue before, and I don't think I changed anything on my network. I've reset the phone and all the other usual stuff.
  • chloebe May 31, 2008
    I also just bought the phone. I can make and receive calls, but upon pick up there is no sound at all. I reset my network and I still have the problem...
  • Chinaguy Jun 11, 2008
    Hello guys,
    thats the same for - I have problem as well. We are using two of these already for several month and now since around two weeks its no more working - we simply cant hear each other. Lets see if a total reset will help.
I had the same problem with CIT400. The problem was easily fixed by doing a reset. The solution was provided by another online friend.
Posted on May 18, 2008
SOURCE:
Stopping the phone from ringing when trying to avoid a call you don't want to answer
You will probably have to call your phone provider and request the number be blocked, that's the only surfire way.
Aug 05, 2015 | Lands Phones
I cannot hear incoming calls. But when i telephone somebody they can hear me. I have checked my volumns and they are all on maximum
If you cannot hear the phone ringing then you may have set it to meeting or silence option without changing the volume level. If you can hear the phone ring but not the person on the otherside then you may have muted the call. Check your phone settings
Apr 15, 2011 | Cell Phones
My Nokia twist's speaker, ear receiver, and mic went out. When I call people, their phones ring, but there is dead silence on my end and they can't hear me when I say "hello". Can't check my...
i know this isnt solving it but this exact thing happened to me. at first i could only use my calling options by putting it on speakerphone but then the whole sound system/ speaker just went away randomly. tell me if you figure anything out cause i love this little phone so much
Apr 02, 2011 | Nokia 7705 Twist
How can I get the telephone on my Brother Fax T96 to work?
Step by step information at the link below.
Brother Fax T96
The F/T Mode is used to allow the fax machine and the telephones to share the same telephone line. When a call comes in, the fax machine and all extension telephones on that line will ring according to the number of rings you have set for the Ring Delay.
When the Ring Delay is completed, the fax machine will answer the call and determine if it is a fax call or a telephone (voice) call.
The fax machine can determine this by the signal it is receiving on the telephone line. If someone is sending a fax automatically , the sending fax machine will transmit a fax tone (a series of beeps every 3 seconds).
If your fax machine hears these tones, it will receive the fax.
If the fax machine does not hear any fax tones, it assumes it is a telephone (voice) call and will begin ringing the F/T ring tones (double ring) for the length of time you selected for the F/T Ring Time. These tones will only ring on the fax machine's handset (extension or external phones will not ring). At the end of the F/T ring time the fax machine will go into the receive mode in order to receive a manual fax.
(If the call was a voice call and was not answered, the caller will hear the fax receive tones also).
  • If you answer the call before the fax machine(during the ring delay period) and determine it is a fax, you can transfer the fax to the fax machine for receiving.
  • If you answer the call on an "extension" phone and hear a beep every 3 seconds (automatic fax) or silence (manual fax), press *51 or *91 for New Zealand (remote activation code) on the telephone keypad, wait to hear the fax machine turn on (chirping sounds) and then hang up.
  • If you answer on the handset of the fax machine and hear a beep every 3 seconds or silence, press the Fax Start or Start/Copy key on the control panel of the fax machine and then hang up the handset.
  • If you answer a call on an "extension" phone during the F/T Ring Time, you will hear the F/T ring tones.
    To release the call from the fax machine, press #51 or #91 for New Zealand (remote deactivation code) on the telephone keypad and you can speak to the calling party.
  • If you pick up the handset of the fax machine during the F/T ring time, you may talk to the calling party immediately.
Mar 28, 2011 | Office Equipment & Supplies
My panasonic phones do not ring when an incoming call is coming in. There is a dialling tone on all 3 handsets and they all appear to be working ok
Ringer turned on? quite common and I'm a phone repair man. Does the calling party hear multiple rings? If it rings only once and goes to silence on the calling party end, there is a high resistance short on the line and it must be repaired.
Oct 19, 2010 | Panasonic (KX-TG1032S) Phone
I have no audio on my rtx 3088. i can log into it, retrieve my contacts, call it, but there is no audio in or out. i use a wireless-n netgear router and live in japan. i have tried making a skype test...
your ring type is set to be in silence, to make it ring go to menu --> settings -->. basic -->ring type --> and select a ring type, the above mentioned steps may not be exact
Apr 17, 2010 | RTX DUALphone 3088
I can make and receive calls, but I cannot hear anything.
Check Windows Sound mixer for application volume. Down in system tray at right side of taskbar double click sound icon for XP or click sound icon once and click Mixer for Vista. Look through volume settings for your phone application. Make sure it is not muted and volume is up.
Aug 21, 2009 | Google Android
XV 6800 phone
"Ringback" generally refers to the music people hear when they call your phone. You have to set that up thru Verizon (or other carrier).
If you're talking about ring tones (what YOU hear when the phone rings) that's easy. Look for a folder called "Rings" inside the Windows folder on your phone. If you put an audio file (wav, mp3, etc) in that folder, it will become available as a ring tone.
Jun 13, 2008 | Verizon Communications HTC XV6800 Cell...
Cell phone silence
It seems the phone may have had water damage.seems like your ear piece and mic dont work, but the loudspeaker does. Give the seller bad feedback and contact paypal. If all else fails, we can definetley help you look at my profile and we can take it from there.
Jan 23, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Phone does not ring
have you called the support line for assistance?dial 1.800.511.3180
Oct 12, 2007 | RCA 25414RE3 Corded Phone
Open Questions:
-\&;-OPTONLINE Customer Care Phone Number #{+ I8OO-828-O294 } AB .U.S.A This Optonline USA phone number is ranked #2 out of 2 because 7,728 Optonline USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the Optonline USA Customer Care department for problems like Where to buy, Complaint, Customer care, Repairs, Returns. As far as we can tell, Optonline USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. Optonline USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact Optonline USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling Optonline USA Calling Optonline USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from Optonline USA Customer Care can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with Optonline USA's Customer Care department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare Optonline USA's phone numbers against each other. Contacting Optonline USA in General While I8OO8280294 is Optonline USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact care for you to look at as well. One thing to keep in mind as you try to reach Optonline USA help by calling them, is that other customers give their customer care at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact Optonline USA.
Oct 16, 2019 | Best Computers & Internet
-\&;-COMCAST Customer Care Phone Number #{+ I8OO-828-O294 } AB .U.S.A This Comcast USA phone number is ranked #2 out of 2 because 7,728 Comcast USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the Comcast USA Customer Care department for problems like Where to buy, Complaint, Customer care, Repairs, Returns. As far as we can tell, Comcast USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. Comcast USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact Comcast USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling Comcast USA Calling Comcast USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from Comcast USA Customer Care can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with Comcast USA's Customer Care department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare Comcast USA's phone numbers against each other. Contacting Comcast USA in General While I8OO8280294 is Comcast USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact care for you to look at as well. One thing to keep in mind as you try to reach Comcast USA help by calling them, is that other customers give their customer care at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact Comcast USA.
Amazon Best pHoNe NUmber #{+1-85O-8I2-4OO9 how to get refund from amazon prime Amazon Prime Refund Phone Number +1-85O-8I2-4OO9. While +1-85O-8I2-4OO9 is Amazon's best toll-free number, there are 7 total ways to get in touch with them. The next best way to talk to their customer support team, according to other Amazon customers, is by telling about your issue above and letting us find somebody to help you. Besides calling, the next favorite option for customers looking for help for Customer Service. If you think this information is inaccurate or know of other ways to contact Amazon please let us know so we can share with other customers. And you can click here if you want to compare all the contact information we've gathered for Amazon. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere.
Oct 16, 2019 | Amazon Computers & Internet
See all Linksys CIT400 Questions
Linksys CIT400 Logo
216 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
