Question about Fisher and Paykel DEGX1 Electric Dryer
Heater won,t shutoff
Dryer did not heat pushed reset button heater came on will not shut off untill unpluged
  • Anonymous Apr 10, 2008
    Our dryer is 2 months old. I took out some towels and the dryer was very hot & smelled. Later that evening my husband went to check on the dryer because he could smell a "burning odor" the heat was still going even though the power button was turned off. He unpluged the machine for safety reasons. The next morning when he plugged the machine in to the socket it imediately started heating up even though no one had pushed the power button.
  • Anonymous Jun 10, 2008
    heater doesn't work
We have the same issue with ours right now.
Posted on May 27, 2008
We've had pretty much every problem you could have with this dryer.
Buy a different brand and send your fisher-junkel to the scrap yard.
Posted on Mar 16, 2008
Where is the reset button on an lg dryer dle2532w my dryer wont heat and was reading online it may need reset.
You need to unplug the unit and push the tabs between the front panel and the lid .This will allow the lid to come up and you can unscrew the front panel. There are 2 screws on the top of the front panel and 2 screws on the front behind the door when you open it. This will allow the front to come off. Now you can get access to the heater. There are 2 thermostats on the heater assembly. Check these for continuity with a meter. You need to check and see if the heater has continuity. The heater or one of the thermostats will be bad.
Apr 30, 2018 | LG Dryers
Kenmore 90 series dryer runs fine until I put clothes in it then it shuts off after I let go of start button
If you are lucky, it is just a heater relay.
You can actually use the motor relay to test if the heater relay is bad, by switching them around. They are interchangeable!
Below is a parts layout for reference.
  1. Unplug power
  2. Then pry the left end cap loose
  3. Remove the philips screw holding the control panel
  4. Remove the back panel plate to inspect, see below diagram:
25997497-lbinchh11fp0u2viv5ufwbp2-3-2.jpg Unplug the wire harnesses of both relays and plug the heater wires into the motor, motor wires into the heater.
If the dryer stays running when you push "start", you must replace the heater relay!
Note: Do not run your dryer until you have all returned the wires to their proper relays...
Dec 07, 2015 | Kenmore Dryers
P1237 fuel pump driver module
Have you checked the fuel shutoff switch? it's a safety device to shut off fuel flow in case of severe front or rear impacts, but sometimes it just trips for unknown reasons. It's behind the liner on the driver's side of the trunk. Look at the round opening on top: if you can see that the red button is setting level with top of the switch it has been activated. To reset it, push the button back down until it "clicks" into place (usually 1/2 inch down or so). If it has been activated and the button will not reset the unit must be replaced, and it is a dealer only item.
May 22, 2013 | 2000 Ford Contour
Can you please tell me where the reset button is ? I hate to pay someone $100 to do this. Thanks, Jo Ann Deloy
Hello, welcome to FixYa.
While I don't have a video or diagram I can tell you on the LG dryers there is indeed a "reset" for the heating/burner funnel (as you obviously know) on the right hand side of the funnel, however they also incorporate a no reset "hi-limit thermostat" on the left side of the funnel. Once it is tripped it must be replaced. This is only present on the gas dryers.
It is located on the left side as I mentioned, but the other is on the right side of the heater housing/burner funnel and will resemble the images shown below.
It is part number 6931EL3004B ( the reset type is part # 6931EL3003C ) and available at "searspartsdirect" (which also has a illustration which may help you) or "repairclinic.com" to name a couple.
i.e. NON-RESET
i.e. RESETTABLE
With the aid of an ohm meter you can check the non-reset for continuity, the other you should be able to push the center reset button ( listen closely for a "click" ) but it too can be ohmed out for continuity to confirm or dismiss it's condition.
Hope that help`s move you forward. If so please take a second and rate the guidance and a testimony to the assistance you received here at FixYa, either or all is appreciated.
Let me know if you need any further info and I'll continue to help in any manner I can. Good luck
Regards,
Macmarkus :)
Sep 01, 2011 | LG DLG5988 Gas Dryer
I have a Bosch 500 plus model. I was drying a blanket by itself when the dryer just shut off. The blanket was in a ball. I spread it out and turned the dryer back on and it wouldn't start. No error codes...
The motor tripped..The wiring diagram for the dryer is inside the back cover tie-wrapped to the frame as it sounds like the motor has a trip on it:
To reset the switch unplug the dryer, remove the power cable and back cover completely. two screws holding back cover are under the top cover which is held on with two screws at the rear. Remove the screws then pull top cover back and then lift it off. Remove last two screws and take off the full back cover . On the front of the motor you should see two white wires going into the safety switch for the belt breaking. Push the button on the left to reset the switch (you probably will hear a click) Do not push the right button as that is what got tripped originally . Good Luck Tim
Oct 30, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Heater works, dryer won't start
Replace your dryer belt.
Sep 19, 2009 | Whirlpool Dryers
First the dryer stopped heating, then when the reset button was pushed it started drying again, but now the heat will not shut off without unplugging the dryer
This is a situation that you need to be very careful with. It sounds like you have a grounded heating element. If this is the case, then the current can be running through the dryer's frame and can cause electrical shock. Keep the dryer unplugged and check the heating element for continuity. If it has none, replace the heating element. BE CAREFUL. Hope this helped and best wishes.
Aug 02, 2009 | Fisher and Paykel DEIX2 Electric Dryer
ASKO T700
I had the same problem. Turns out the reset button on the back of the dryer needs to be pushed; when you push the reset button you should hear a click. If you do not hear a click the problem was probably not the reset button. The button shuts down the dryer heating elements if they are getting too hot and also keeps the drum from turning unless the start button is held down.
If you push the reset button and the dryer starts to work again, I strongly recommend that you stop the dryer and investigate why the heater elements overheated. In my case there was lint/hair build up on the heater elements themselves. Extensive dryer disassembly is required to properly clean the heating elements but it is worth the prevention of a house fire. While you're at it, clean the rest of the machine and the duct work.
Hope this helps
Jun 20, 2008 | Asko T700 Electric Commercial Dryer
Not heating
It is probably a thermal fuse. Take off the back of the dryer and you will see it on the lint outlet tube. It is white and is 1/2 inches wide and 2 inches long. It has two leads coming out hooked to wires. To check it just pull one of the leads off, turn on the dryer and touch the wire you took off to the other one and the burner should come on. It costs $12 at a parts store.
Jan 31, 2008 | Roper RES7646KQ Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
126 people viewed this question
Top Fisher and Paykel Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
