Question about Bose Wave Radio
Bose AWR1-1W older version, not Series III, no power, pop when unplugged.
I have an AWR1-1W that won't power up, makes a loud pop when unplugged. I know the fix for the newer version of this radio is the 5vdc power supply transistor. This is the older version with the 3 AA batteries for back up not the 9VDC battery. Do you have any suggestions. I can't even find the 5vdc supply in this radio, do you have a schematic. I have schematic for the series III of this radio but not the older version. If you can offer some info I'd appreciate it. Thanks
  • 9 more comments
  • jrsusc1 Mar 18, 2008
    I have the same problem. No power, a pop when unplugged. But mine uses a 9v battery as backup. Any suggestions/help would be appreciated. rspencer@sc.rr.com
  • NEATSIE May 17, 2008
    Hi
    I have the BOSE WHICH DOES NOT POWER UP. cAN YOU PLEASE TELL ME WHAT TO REPLACE IN THE SIMPLEST OF TERMS, AND HOW? i KNOW NOTHING ABOUT T HESE. tHANK YOU
  • tomshields99 Aug 02, 2008
    When unpluuged, short burst of audio, otherwise, seems dead when plugged in.
  • Anonymous Aug 11, 2008
    Model AWR1-1W no power ,lights, sound,makes loud pop when unpluged
  • kg4prk Aug 12, 2008
    Model AWR1-1W no power ,lights, sound,makes loud pop when unplugged...
    When unplugged, short burst of audio, otherwise, seems dead when plugged......
    Found shorted transistor TO-92 package 2SC3792 (near main transformer).
    I bought a 2N2222 transistor from Radioschack and it work's fine
  • postrow Sep 27, 2008
    I have the same problem - no power, but a pop when unplugged. I have no technical skill and would not like to try repairing it myself, but Bose wants $99.00 plus shipping to fix it for me. How much should I really have to pay?
  • cshealy Dec 04, 2008
    Where is R406 Located
  • Anonymous Jan 02, 2009
    will not power up
  • golda123 Jan 07, 2009
    I have the same problem. The Bose AWR-1W older version will not power up and when unplugged it makes a popping sound.
  • bob9517 May 12, 2009
    I do not have a 2sc3792 anywhere
    I do have a M4033G
  • charlesk May 11, 2010
    I have found U402 but do not see R406. Can you help me locate?
  • 6 Answers
I've got a simillar problem... will be looking into it this weekend. U402 is supposed to be the 5Volt regulator.
The input to U402 is U401 its a 12Volt regulator.
You should check both...
Posted on Apr 04, 2008
  • jjcicala Apr 05, 2008
    R406 (1 Ohm) acts as a fuse for the the input of U402, replaced R406, now the display works and the unit powers up.
    Problem Solver:
  • 13 Answers
After some checking Q4 c3792 was shorted, Closest I had in stock was a nte85 that matched the specs. Radio works fine after replacing with nte85.
Posted on Sep 15, 2009
Kg4prc has the right solution. 2sc3792 bad (no display, popping sound when unplugged) replace with 2n2222 or eq. Pay attention to basing diag. Located next to bridge rectifier ( only TO92 pkg xistor on board) excellent!!!
Posted on Jan 01, 2009
2 Suggested Answers
  • 1894 Answers
SOURCE: Older AWR1-1W not series III
when you have the back up what suggestion you are asking from us sir?
sir please be specific with what you want
Posted on Mar 14, 2008
Where can I get a set of crossovers for the Bose 601 series III
Bose don't sell a lot and indoubt you can order them at bose, i think they say: let it be repaired at a bose certified shop
Sep 18, 2014 | Audio Players & Recorders
Bose subwoofer has no power when pluged in
Make sure your power outlet and your audio source are ok. If they are then the subwoofer's power supply is probably dead.
Oct 17, 2012 | Bose Acoustimass 5 III System
AVR 1600 receiver won't connect to bose series III EQ
You mean BOSE 901 Series III Active Equalizer; and HARMAN KARDON AVR1600 right?
Sure it will. It goes in a Tape Loop such as Tape Out/In or Video 1 Out/In. But it won't work for anything except analog stereo sound sources as all digital audio is not available to the RECORD OUT jacks when the Tape or Video 1 is activated. AND 901 Active EQ is intended solely for 901's, not any other speaker system
The HK has no Line Level volume-controlled Pre-Outs so you're out of luck if you want the 901's to take part in a multichannel setup, which would require a separate power amp to drive them anyway.
Aug 23, 2011 | Audio Players & Recorders
Have a Bose 3-2-1 Series III. When I put in a DVD, I get sound through the Bose but no picture on my Pioneer TV. This is the second time it has happened. The first time it, we managed to get it going...
Here are 3 things to try and an if all else fails at the end.
1) Make sure the TV is set to the correct Video Input to see the video from DVDs on the Bose system.
• Make sure a DVD is in the disc tray.
• If the TV is connected to the media center using the HDMI cable:
Switch from one Video Input to another and then back to the original input.
2) Turn everything off, then:
Turn on the TV and set the TV Video Input for the Bose system video.
Turn on the Bose system and press DVD.
3) Turn off both the TV and the Bose system and then:
Unplug the HDMI cable from both ends.
Disconnect the power cables from both your TV and the Bose 321 system.
Re-connect power to the TV and to the Bose 321 system.
When the Bose 321 system startup message disappears from the display,
re-connect the HDMI cable to the TV then Bose 321 system.
Turn on the TV first, then turn on the Bose 321 system.
If all the above fail then disconnect the HDMI cable that connects the TV to the Bose 321 system and reconnect the two using a Component cable, an S-Video cable, or the Composite cable provided with the system.
Please leave feedback
Cheers
Andy
Apr 28, 2011 | Bose 3·2·1 II System
Not sure of how to wire these speakers ( internal ) Bose 901 series iv
Found on Google Search: "bose 901 internal wiring" You must first identify which series you have. The first two series were acoustic suspension, and used nine 8 ohm drivers in a series/paralel configuration. Series III through VI used nine .9 ohm drivers all wired in series. Series III and IV had an additional terminal for use only with the Bose Spacial Control Receiver. Series III through VI are easy to identify, as there are three ports sticking out the back of each enclose. The 1st two series have no ports.
Jan 17, 2011 | Bose 901 VI Main / Stereo Speaker
Bose Wave Radio pops, loud hum that fades
Power supply capacitors have dried out and need to be replaced.
Sep 03, 2017 | Bose Wave Radio
Can't get video to work so bose works with tv sound
We fixed it. We had everything hooked up right, but - stupid us - we didn't turn the sound off on the TV. Once I turned the TV's sound setting to off, I flipped the speaker switch a few times on the Bose remote, then turned up the volume on the Bose and it worked.
Sep 19, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Our Bose lifestyle 5 has no sound does the Bose CD disk restore the sound card. Mfg.1997 too old to do this must we buy a new one or does this cost a lot for repair ?
This can be repaired of it's later than a series 1. (not sure if the 1997 model was a series 1) Repair cost will be $225 plus tax (flat rate). Shipping is split between you and Bose. They give you a new 1 year warranty.
Otherwise, Bose can have you trade this in for about 25% off a new, current system.
-If this still powers up, make sure the small 1/8" portion of the input cable (plugged into "system control 1") is in good condition, because you may just need to replace that input cable for a no audio situation. If it's a different series, it will say "zone 1" I think.
In either case, you should call Bose tech support about this. (800-367-4008) Make sure you're with your system so they know what series of LS5 this is.
Jul 17, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Mar 14, 2008 | Bose Wave Radio
Bose Wave Radio Logo
3,447 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
