Question about Cable_and_wireless CWD4901 Cordless Expansion Handset
NOT SUB on head set
My codless phone doesn't work i am only getting NOT SUB on screen but i conn't use any keys
  • Anonymous Mar 17, 2008
    NOT SUB message on LCD and keys are not working.
I had the same problem to fix it you press the menu button then scrool up untill you see REGISTER.
Press OK the display shows "BS 1 2 3 4" Enter the number of the base unit you wish to register the handset to.
The display shows "PIN code" (original code 0000) press OK the display shows "Search X (where 'X' is the number of the base you are registering to)
Press and hold the "page button" on the Base unit untill it beeps twice then after a few seconds the phone should work again.
Posted on Apr 25, 2009
Not sub on screen
Posted on May 25, 2009
SOURCE:
Having a Codless KX-TG433SK, want to know how do we enhance the duration of the ringer rather than a few rings and ending up into an aNSWER MACHINE
go into the menu , phone set up scroll around until you get ring time/ duration and set for the desired no of rings before answer machine cuts in
down load a pdf version of the user manual for your system
May 14, 2015 | Lands Phones
Change pulse tone rotary
To change between pulse and rotary, from an administrator handset press MENU-9-1.
Jun 26, 2013 | EnGenius DURAFON1X DuraFon 1X System Phone
How to connect MS access in the visual basic?
This following code to connect vb 6 with access
place this code in module :
vb Syntax
  1. Global Conn As ADODB.Connection
  2. Global rs As ADODB.Recordset
  3. Sub Access_Connector()
  4. Set Conn = New ADODB.Connection
  5. Conn.Provider = "microsoft.jet.oledb.4.0"
  6. Conn.CursorLocation = adUseClient
  7. Conn.Open App.Path & "\SIS.mdb"
  8. End Sub
Below link might help you... http://www.functionx.com/vbaccess/Lesson01.htm
Please rate or vote me , if you like solution..
Thanks
sandeep
Mar 15, 2011 | Computers & Internet
I hv codless phone and when i dial number there are some prefix number 1050 comes automatically so that call can't get through
hm its the default settings in your number....its called as hot key...when u press it default number ll go....so go to settings and change the hot key numbers..or better remove it!!!!!!
Nov 24, 2009 | Cell Phones
Trying to change the intercom caller ID onthe M7324
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you want to change the name on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
Oct 23, 2009 | NorStar Meridian M7310 Phone
People can only hear me if I use a head set
hai ,
i have apple i phone 2g 4gb not working properly,that means touch screen not fully working .switch on the mobile at that time above quarter percentage working phone menu,after 5 min phone key locked and not working slide bar
May 30, 2009 | Apple iPhone Smartphone
How to connect vb with ms access
se Adodc OR Even better.. ADODB. for this you need to get MDAC fromMicrosoft free download.(check under project_References- Microsoft DataActiveX objects.. the current no is 2.8. if it is not there download invb directory.
next, you can learn about creating a DSN from control panel, ODBC. onceyou learn this, connection becomes a piece of cake. get some free vbtutoriasl from WWW.
then
you need to use DAO or ADO to connect to the database. better study both but since ADO is current, i am showing that code.
under Menu Project_References, put a check mark on Microsoft ActiveXData Objects latest version (though it works for all, currently 2.8with sp pack 1 ).
at the general declarations:
dim conn as adodb.connection, rec as adodb.recordset, esql as string,esql1 as string
Private Function connect()
Set rec = New ADODB.Recordset
Set conn = New ADODB.Connection
esql = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & "D:VBDesigndhana2.mdb" & ";Persist Security Info=False"
'here you put the correct path of your mdb file. and check if you have jet 4.0
conn.Open (esql), , , 0
End Function
private sub form_Load()
connect
end sub
and for adding records:
say let us say you have 3 fields. then have 3 textboxes and 1 command button on the form.
private command1_click()
esql1="select * from Yourtablename"
rec.open(esql1),conn,, adOpenDynamic, adLockOptimistic
rec.AddNew
rec.Fields(0) = text1.Text
rec.Fields(1) = Text2.text
rec.Fields(2) = text3.text
' you need to check if in your access table design you have Allowed Zero length .. set it to Yes for all text fields.
rec.update
if not rec.eof then rec.movenext
rec.close
conn.close
set conn to nothing
end sub
this will add new records to access table from VB.
' for picture store the full path of the path and the picture file nameint the text field. and in the picturebox of VB form for viewingrecords again you need ADO or ADODC and here you code:picture1.picture=Loadpicture(rec.fields(3) ' depending on where thepicture field is located. you need to make a few trials.
End Function
connect
end sub
and for accessing records:
esql1="select * from Yourtablename where id =" & val(text1) ' for integers
esql1="select * from Yourtablename where name=" & "'" & text1 & "'" ' for string
rec.open(esql1),conn, adOpenstatic, adLockreadonly
label1.caption =rec.Fields(0)
label2.caption= rec.Fields(1)
label3.caption= rec.Fields(2)
rec.close
conn.close
set conn to nothing
end sub
' similarly there are routines to ADD, Delete, Edit, View etc.
Feb 26, 2009 | Computers & Internet
No caller id on my phone
no caller id on my phone
Nov 11, 2008 | Uniden Cordless Phone
Cable_and_wireless CWD4901 Cordless Expansion Handset Logo
319 people viewed this question
Top Cable_and_wireless Lands Phones Experts
Russell
Level 1 Expert
Robbie Goodwin
Tom Chichester
Are you a Cable_and_wireless Lands Phone Expert? Answer questions, earn points and help others
