Question about Lexmark X5470 All-In-One InkJet Printer
Scanner defective printer works fine,why is the scanner still not working?it worked when i just bought it but that was once.still saying cant download application
  • Anonymous Apr 06, 2008
    Ive a X4550 and have the same scanner problem. What is the "application" that I can't find? Thanks
    Bswaxart
  • Mad Matt B Apr 06, 2008
    i have the same problem
  • 29 Answers
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
908
Posted on Mar 02, 2009
Thankyou Hands
I dont use Vista at all (not heard anything good about it yet).I will try your recommendation tho.
Thanks
Bswaxart
Posted on Apr 22, 2008
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 137 Answers
I am sure you are running VISTA? If that is the case then VISTA has set the native VISTA Fax and Scan application build into VISTA as your default FAX/ SCAN application. The printer will work fine and I am sure that if you go to Start/ Programs - Windows Fax/ Scan and use the build in application of VISTA that you will be able to scan. If you do not like this change the default setting in control panel for Fax/ Scan to Lexmark.
I hope this help.
Regards
Hands of Time
Posted on Apr 21, 2008
SOURCE:
Downloading application list - cant retreive application
If your pc tels you its downloading application, have a look a your printer drivers, your usb cable connecting your pc to printer and or the data cable inside the scanner might have gone faulty
Apr 18, 2013 | Lexmark X5470 All-In-One InkJet Printer
I am unable to scan. While in the Scan Mode, the message says "Downloading scan application list from your computer, please wait" The next message says "cannot retrieve scan application list from my...
the reason why the printer is giving you that error msg is because the all in one center is not communicating properly with the programs on your computer to your printer.
try to scan directly to your computer using the all in one center instead.
Jul 23, 2009 | Dell 966 All-In-One InkJet Printer
Scanner error on PC says "cannot properly communicate with scanner. Make sure the scanner is on, properly connected and properly set up to scan." the test scan works and i can see the image. the printer...
Try and open MS Word and import a picture into a document via scan, follow the prompts in Word and it should work fine. If you don,t have MS Word you can download a completely compatible application at Open Office.org. It also has the same functionality is free and allows you to save documents as .doc, .xls, etc. Sometimes a scanner requires additional software or drivers in addition to functioning as a printer. I have found scanning internal to an application a workaround or test for the scanner. If this works I would review the installation or contact the manufacturer or website. Or post and we can give it another try.
Jun 04, 2009 | Epson Stylus CX5800F All-In-One InkJet...
Lexmark Scanner - "cannot retrieve application list" Won't Scan - HELP please!
delete the norton internet security as its blocking the scanner files of your printer software .or try reloading the printer drivers again but if reloading the printer drivers does not helps then removing the norton software is compulsary as the files of printer are getting blocked so scanner is not working.
Mar 07, 2009 | Lexmark X3350 All-In-One InkJet Printer
Microsoft Paint ----> 'File' ------> 'From scanner or camera' (when in scan mode on printer). Just tried this and it really works.
Oct 19, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x6170 will not scan
Try resetting you machines by turning off and unplug, reverse steps and try again. If no go, repost and we will try again. Cheers lilacgerry xxx
Jan 09, 2008 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
130 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
