3 weeks ago installed netgear rangemax router along with a gateway laptop com. also a H.P. printer wireless. eveerything was working fine now printer will not work wireless and i canot get into my router to change code and IP address tried to reboot printer as well as router need help. jack in ct.
    Scholar:
  • 178 Answers
Try the reset switch on the back of the router. Using a paperclip, hold the reste switch in for 30 secs and then power down the router. Once that is completed, you should be able to access the router config page under factory settings.
Posted on Mar 14, 2008
Hooking up a printer to a Netgear CG3000D Home Gateway
If you provide the printer make and model it would be helpful. Open the printer Wi-Fi settings select your SSID , enter password, connect.
Mar 07, 2013 | NetGear DGND3300 RANGEMAX DUAL BAND...
My Rangemax wireless wndr3000 is not working properly, though it has in the past. The problem seems to be that I'm hooked up to the wireless network (ex. I can print wirelessly), but with no internet....
Same situation here. Wired connection from modem works fine. I can also log in to the router via routerlogin.net. However, the router does not detect an internet connection.
Jul 12, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
Can you help me configure my netgear router? I cant seem to connect to http://192.168.0.1
you can try typing in your browser address bar www.routerlogin.net then press enter this should bring up your routers setting wirelessly but this will only happen if your laptop detects your routers wireless network.
if you can connect your laptop to your router using ethernet cable you can go to the command prompt then type in IPCONFIG then enter this should pull up your ipaddress and the default gateway is your routers Graphical User Interface where you can go and change the settings, your Netgear default gateway should be 192.168.1.1 this is the default gateway that should show in command prompt for netgear routers.
If you are going to use wireless make sure in the router the wireless capability of your router is enabled ^_^
your settings depend on what your Internet service provider requires you for settings
Jun 21, 2010 | NetGear DGND3300 RANGEMAX DUAL BAND...
The WPN111 RangeMax wireless UBS 2.0 adapter I bought a few days ago keeps disconnecting. At first the connection is fine throughout the day, but at night the connection fails. Internet access in the...
Do you have a good signal strength with the wireless USB adapter?
If not try moving the wireless router away from walls or metal objects and cordless phones, locate the wireless router higher.
See if there is a later driver for the wireless USB adapter, if so download and install it.
Dec 21, 2009 | NetGear WPN111 RangeMax Wireless USB 2.0...
Bought a NetGear WPN111 RangeMax Wireless USB 2.0 Adapter a few months ago. It was working fine up until a few days ago. It started dropping my internet connection, and now it won't even detect any...
Hi
firstly you can try upgrading the drivers on the adapter. following is the link for the latest drivers http://kb.netgear.com/app/answers/detail/a_id/12520
If the problem still persists
try changing the wireless settings on the wireless router.
Nov 12, 2009 | NetGear WPN111 RangeMax Wireless USB 2.0...
My wireless laptop won't connect to network printer using netgear router . When hard wired over LAN, printer works. Cannot ping when laptop is wireless. Other computers work fine. HELP~
  • laptop has to be connected first to SSID
  • then ping is possible
  • or else reset the wireless settings: change SSID name, channel 6, and no password first
Jul 31, 2009 | NetGear RangeMax WPN824 Wireless Router...
Connected to the internet, but cannot browse any webpages
i think u have soem firewall isse in router also try to reset router then check .
reset switch in back side of router.pres it for 10 seconds .then it reset to defaults.
Mar 28, 2009 | NetGear WNR834B RangeMax NEXT Wireless-N...
Connecting a router to a gateway
Sure, you just need to change the ip address of the Rangemax. Netgear usually uses 192.168.0.1 for their router ip addresses. Plug the ethernet cable from your PC into the Rangemax. Open a web browser and put 192.168.0.1 into the address bar. You should reach the home page of the Rangemax. Change it's ip address to 192.168.0.2 and save.
Run an ethernet cable from one of the four ports in your Netgear gateway to the internet in port on your Rangemax and all should be well.
Jan 15, 2009 | NetGear RangeMax WPN824 Wireless Kit
Cannot get wireless connection through router
Hi MistiShay,
You did mention that it was working fine for several weeks suddenly your wireless computers stopped functioning and your getting a message that the security key in incorrect. This only means that its either your entering the wrong encryption key or someone changed the previous security key to something else. By the way what type of wireless security did you configured on the router initially was it WEP or WPA, if its WEP(64 or 128 bit) and your using a bulit-in wireless adapter on your laptop you need the default WEP key because the passphrase only works with a Netgear WLAN Utility.
Know if your having difficulties accessing the setup page of the router you may need to check on your browser settings, turn off the pop up blocker and firewall temporarily, also try another computer. Now if all fails you may need to press that reset button on your router and set it up again.
I
Jul 28, 2008 | NetGear RangeMax WPN824 Wireless Router...
Can not connect to router from laptop
You need a wireless printer server to get your printer to work.
Apr 20, 2008 | NetGear RangeMax WPN824 Wireless Router...
Computers & Internet Logo
49 people viewed this question
Alun Cox
David Payne
David Payne
