Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Motor coupling (for direct drive washers)
How difficult is this item to replace for a mechanically inclined person?
    President:
  • Whirlpool Master
  • 2,651 Answers
Not at all, under 30 min for even a novice!!!, remove 2 screws holding down console, depending on year they are either on the bottom of the face of console in both corners or looking over the top of unit you'll see 2 screw head in both corners screwing down into machine. remove the screws and the console will flip backwards. disconnect the harness going through he main top(lid switch assy). and twist off with a screwdriver the 2 brass wavy clips 3 inches in from either side of machine.( you nay have to twist hard but they will pop theyre sorta spring loaded), lift of the entire cabinet and set side. youll see the pump assy 2 spring clips remove it(leave the hoses attached just hold out of the way, next 2 spring clamps hold the motor and youll find the coupling just behind there, youll need to smack the coupling back on to the shaft, i use the back end of my nut driver and hit with small hammer. dont need to kill it but will need to be forced on, and your done reassemble, (dnot forget ot plug back in the lid switch before closing the console,) ant the cabinet hooks under the front of machine and should fall right back into place, the brass clips will line up real good when cabinet is on properly just a firm push down and they snap right back in
Posted on Mar 15, 2008
Will not spin. has a rattly noise to it. The water will still drain
You need to replace the "direct drive coupler" in the machine. Below is a link to the parts and a video to show you how to replace it. If you have a direct drive washer. I did not see your model number posted.
Here is the part http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Motor-coupling--for-Direct-Drive-Washers--item-number-AP3963893.aspx
Here is the video http://www.youtube.com/watch?v=WLPGs2UMUJc
I hope this helps you!
Nov 22, 2010 | Kenmore Washing Machines
LEAKING SOAPY WATER
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the section for the basket and tub assembly's
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
I'd also check the gaskets at the bottom of the tub.
If you're reasonably mechanically inclined, these are easy fixes.
If you have to get to the gaskets at the bottom of the tub, see the following for how to remove the agitators, pump, motor, transmission, spin tube and basket.
(It sounds a bit complicated but it's not really that difficult.)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
You don't have to buy a special spanner wrench to remove the spanner nut. I've used a short 10" pipe wrench hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
As an aside, see the following Whirlpool Service Manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Depending on the problem (hoses or gasket) it's certainly less expensive than calling in a repair person.
May 20, 2010 | Kenmore 22622 Top Load Washer
My washer is leaking underneath. What can I do??
See the following:
If the hoses are fine, check the shaft from the motor to the pump and check inside the pump to make sure the inlet and outlet aren't blocked.
May 18, 2010 | Kenmore 22422 Top Load Washer
WASHER WONT HOLD WATER,
See the following:
May 16, 2010 | Kenmore 22422 Top Load Washer
Water leaks under the washer
See the following:
May 13, 2010 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore Elite 3 Speed washer, Model number 110-22982-100. It wont spin, but the pump is working. Do you know if this is belt driven or if it has a coupler? I need repair diagrams if you have...
Your washer is a direct-drive model which means it uses a motor coupling instead of a drive belt. The symptoms your washer exhibits is typical of a motor coupling gone bad.
If the washer will fill and drain, but won't agitate or spin, the most common cause is a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. This configuration is known as a "direct-drive" system. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased for about $10 - $15. The following websites are great sources for replacement parts:
pcappliancerepair.com
repairclinic.com
If you have any questions about this repair, or if you require additional assistance, pease post back and let me know. I hope this helps you.
Jan 29, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore washer will not spin
Your problem is either attributed to a bad motor coupling, or the gearcase (transmission) may be worn out.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging and no agititation are common symptoms. This is a common fail item through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
The motor coupling is located between the drive motor and the gearcase (transmission) and takes the place of a drive belt. This configuration is known as a "direct-drive" system. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient and should last longer. An inspection of the motor coupling will indicate whether or not you need to replace it.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
If an inspection of the motor coupling shows the coupler is still good, your problem may be a gearcase failure. The gearcase is not a difficult repair on this model washer either. The part number (if required) is 3360629. A replacement can be purchased at any of the following websites:
repairclinic.com
Use the "Search by Part Number" feature and compare prices. The average price is about $150.
If you need to replace the gearcase, the following link explains how:
http://www.fixya.com/support/r3576575-replacing_a_gearcase_on_whirlpool_manufa
I hope this gives enough information to help determine the cause of your problem and whether or not the cost is worth your effort. If you have any questions, please let me know.
NOTE: Its a good idea to go ahead and replace the motor coupling if you are replacing the gearcase.
Dec 27, 2009 | Washing Machines
Agitator inside the drum is not moving during wash
Seems to be a common problem with Kenmore and Whirlpool machines. Follow this link to a good explanation of what's going on and how to fix it.
http://fixitnow.com/appliantology/wpdd_dogs.htm
Oct 29, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer drains but doesnt spin
There is a motor that makes the washer spin, and yours is burned out. You probably need a new one. My husband took ours out and we bought a replacement at a local small electric parts store. He is mechanically inclined, but it wasn't too difficult and it didn't cost much for the part, I think less than $50.00.
Oct 08, 2009 | Washing Machines
I have a Kenmore 110.22642 it started to wine for awhile and now it just fills up and drains no turning spinning nothing. My Husband who is not mechanicly inclined at all took the back off of the washer...
how old is this machine. if it is less than ten years old there is no belt. more than likley you have a broken drive coupler. never take the back panel off. tip the washer back and look under it. you will see the pump attached to that you will see the motor directly behind that you will see the drive coupler it couples the motor to the transmission this is a very common failure. check it out and let me know. please do not tip the washer all the way over it will damage the unit. tip it back and lean it against the wall.
Mar 16, 2009 | Kenmore 22642 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
47 people viewed this question
Dan Webster
Dan Webster
Sal De
