Hello, I just purchased a old BBQ100 (serial#3639) I got it dirt cheap but I need to put allot of work into it. I was wondering were i could get a manual on all parts and components. Also his BBQ100 doesn't look like the current ones out there, in fact I have not been able to find any that look like it. All the ones I have seen have a stainless steel lid. The one I have has a orange lid. I suspect it is at least 10yrs old. Any info or help would be appreciated.
Call Treager direct Thye have a great customer service department and are always willing to help 1-800-872-3437Call Treager direct Thye have a great customer service department and are always willing to help 1-800-872-3437
You can't post conmments that contain an email address.
is the BT in a US B port or inside the PC.
most PC made for sure old ,(no model stated so answers will be wrong )
the BT is an option on all PCs mostly old.
if missing INSIDE we add it outside on a USB port
a dirt cheap fix.
ebay this USB Bluetooth.
VAIO goes back to 1996, surely you can tell what model you have and what OS it runs. next. windows what?
2007 they started offering BT as an options with wifi card.
it is just a battery and camera manufacturers use generic batteries
take the old battery out and all you need is a battery the same shape , voltage and composition --ni-cad or metal hydroxide
they would be available at any camera shop or online from e-bay
Hello! Happy to help with that. To replace the filter simply twist the dirt cup lid off of the dirt cup. Remove the old filter and replace with the new one. Twist and lock the dirt cup lid back on. This vacuum takes a Dirt Devil F1 filter. Follow the link below to purchase the filter directly from dirtdevil.com. Thanks!
From ISMACS database it appears as a Class 18 which would be an industrial machine. Can you provide any further information to help with id'ing it.
Letter
Register Numbers
From - To
Machine Class
(Model No.)
Quantity Allotted
Date Allotted
Year Allotted
Notes
G-
746501
748000
18
1500
September 27
Here's a solution that often works. Turn the Master ON/OFF Switch to
OFF. Unplug the unit from the wall outlet and wait 12-15 minutes before
plugging it back in. Then turn the Master ON/OFF Switch to ON and set
your control as you normally do. Hopefully, that 12-15 minute timeout
allowed the unit to reset itself. If it continues to do this contact Haier Customer Support 877-337-3639 and have your Model Number and Proof of Purchase handy. If it's less than a year old, it's still under warranty.
Here's the company contact info so you can get the parts directly.
To order parts directly from the factory: PARTS DEPARTMENT TRAEGER WOOD PELLET GRILLS LLC. PO BOX 829 ,Mt. Angel, OR. 97362 (503) 845-9234 1-800-872-3437 Fax: (503) 845-6366 Email: [email protected] Website: www.traegergrills.com
Get yourself a nice carbon fiber brush. Purchase some record cleaner or just get some isopropyl alcohol 90% (it has less impurities). Secure the arm of the turntable so you don't scratch the record and put the record on it. Put some of the cleaning solution on the brush..not the record. Put the brush on the record and turn the platter counter clockwise to work the dirt loose. Check the brush and clean it if need be and repeat. Take the record off and clean the turntable. Flip the record over and repeat the cleaning process. That should do it. Thanks for stopping by and come back if you need more help. If you don't mind, rate my answer appropriately. Thanks.
