Question about Canon PIXMA MP160 All-In-One InkJet Printer
Printer paper feed error #3
I have a 6 month printer and it was working fine and then the paper started jaming on the right side when it starts to feed. It does this every time and then give me error #3.
Help
Sorry, don't know why the other post came up as guest and not with my name.
don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
someone replied to my problem, i tried it and its fixed 1st time, also seems to of worked for some others.
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving PUSH it through! and hey presto it worked for me, everything printing fine now
Posted on Mar 14, 2008
Don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
    Master:
  • 351 Answers
Dear EATRUNNER,
This Error is related to PaperJAM now you can find the complete solution to related this Error ,on this URL:
http://support-au.canon.com.au/contents/AU/EN/8000647001.html
i'm 100% sure ,your problem is solved ,whenever you read this page properly.
Cheerup and Be Happy Always
My Epson R230x printer get paper james and not feed paper, how can I solve or repair this problem
i want to know. printer back side some gape i see. but i don't know which work do in this back side.
Nov 04, 2012 | Epson STYLUS R230 InkJet Photo Printer
My canon PIXMA MP190 All in one Injet Printer won't feed the paper through. It pulls to the right side and then bunches up. I've cleaned everything and even tried pushing cardstock through. It seems like...
Use a flashlight and small mirror to look down where the paper goes in the back, usually something has fallen in where it shouldn't be. A lady last week turned her printer upside down and shook until a bic pen fell out.I find pins, paper clips, toys, or gum inside. That one roller us usually enough.
Oct 23, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Paper feeds crooked into the printer
Check the adjustments for the paper your using. Open the printer and look on the rollers you'll probably find paper or an obstruction clear it and also clean then rubber moving parts with isopropyl alcohol to give them their grip back.
Jun 21, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Canon MP470 - Paper starts to feed and twists then jams
i had the same problem, mine went into the printer fine and started to tilt. all i did was check the paper input slot and there was a necklace stuck in it, it was an easy fix after all, just had to pull it out. too bad there are more problems than it is worth tho, right now mine wont feed lol
Nov 11, 2008 | Canon imageCLASS D880 All-In-One Laser...
Lexmark Z715 printer
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.IF the problem continues then its the problem with rollers in the printer ,hardware problem ,
Good luck....
Aug 22, 2008 | Lexmark Z715 InkJet Printer
My epson cs7800
I had the same problem and found a small spring was loose and interfering with the paper. The Spring was on the right side as you look at the printer, near the bottom of the paper feeder. I took it out and it works fine, for now.
Jun 15, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Cannon MP210 printer
I tried this and it worked (thanks to a suggestion from someone else but can't find his name right now) --
I found a slender piece of cardboard, the front off one of my 1-subject notebooks. I cut the jagged edges off, made sure there wasn't any debris or loose crumbs of paper. Put about 20 sheets of paper into the printer and put this cardboard as the first sheet. Pressed the copy button. When it started to attempt to feed, I forced it through.
What did it find?? A moth had flown into the printer at some time, gotten smushed, smashed and stuck -- and was preventing the paper from feeding through! OMG, I almost tossed this Canon MP210 in the garbarge.
So thanks to you guys with ideas about cardboard and a little muscle. I ran another piece through just to clean out all the stickiness (and the remnants of the moth's body). Works fine now.
webstuff
Jan 28, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Paper will not feed properly/one side of paper not feeding in straight
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
542
Dec 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Paper Jamming
Could be a faulty roller, or jam you have not found yet. Check again with a torch right up insied unit. If no go, try uninstalling and reinstalling printer.
Jun 29, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
67 people viewed this question
old marine
old marine
