1994 Ford Crown Victoria Logo
Posted on Mar 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have 94'crown vic with rear air ride suspension problems. The back end won't rise. Any help is appreciated.
Ed
Level 3:
  • Master 479 Answers
  • Posted on Mar 29, 2010
Ed
Master
Level 3:
Answers
479
Questions
0
Helped
237497
Points
1568
Start by checking the fuses for the air compressor for the rear suspension. these will be listed in your owners manual. Failing this it could be the compressor motor or wiring to the motor, unless you can hear the compressor working. If the compressor is running but not adjusting the back of the car then you have an air leak in one of the shocks or air lines.
if you find it is a fuse, also listen for the compressor motor running and an air leak, if the system is running constantly to make up for a leak , that may be what blew the fuse.
Hope this helps
Ed
Mike G
Level 2:
New Friend:
  • Expert 100 Answers
Mike G
Expert
Level 2:
New Friend:
Answers
100
Questions
0
Helped
55029
Points
269
If air pump is working, there is an air leak in the air lines, or leak in shocks. in either case, replace.
1 Related Answer
Anonymous
  • 141 Answers
  • Posted on Aug 09, 2009
SOURCE: How does one reconnect the air suspension
You probably have a leak in the system. Did "they" check the lines and air suspension? "They" probably disconnected the compressor to keep it from burning out from overuse. You need to fix the leak before reconnecting or the compressor will wear out very quickly.
I recently had my 99 crown vic's front end aligned. but it still pulls to one side to the right. and it pitches and rollds around corners
get the rear end aligned first before the front end as it indicates that the rear end is not square to the body
have the rear end suspension checked out as well for mounting bush problems
replace shockys
How to take rear inside door panel off 94 ford crown vic lx
Hope this helps you ?? ps. would have made picture bigger, but this web page won't allow it....
2answers
1992 CROWN VICTORIA LX I REPLACED FUSES INSIDE AND UNDER HOOD FOR AIR RIDE SUSPENSION AND IT STILL WON'T AIR UP. PLEASE HELP
Air ride suspension basically works like this. you have a small air compressor and a sensor that connects between the rear axle and the under body Frame. When this sensor detects a load movement like more or less weight it turns on the air compressor to air up or opens a exhaust valve to let air out. most common problems with this system. broken or disconnected sensor. leak in the air lines between compressor and shocks. or a bad or weak compressor.
My 03 town car is sitting on the ground in the rear i do not know if it has air suspension or auto leveling or if their is a diffrence. should i start to check air lines first. also i do not here the...
THERE IS A AIR RIDE SWITCH IN THE TRUNK TO CUT IT OFF/ON IT MIGHT HAVE BEEN TRIP OR THE PUMP MIGHT BE BAD IF IT WAS ME I WOULD SWITCH OVER TO 1992 UP CROWN VIC REAR COIL SPRINGS AND DO AWAY WITH AIR RIDE IT NOTHING BUT TROUBLE
1helpful
1996 merc grand marquis Coil conversion
check out " strutmasters.com " They have what you are looking for. They are on the east coast and have the spring kit. The car will ride just as well and never have a suspension problem again. Trust me on this.
How do I reconnect my 95 Crown Vic air suspension compressor?
most likely someone unhooked it due to some part being bad in the system and even possiable that the air bags have been removed and coil springs installed
1helpful
2helpful
5answers
The trunk of car is low to the ground, the frontend is high
It sounds to me like your compressor got killed. What probably happened is that the airbag got a hole or tiny crack in it so the compressor has to work extra hard because it is like blowing up a balloon with a hole in it. Therefor the airbag killed the compressor. I would recommend going to strutmasters.com and taking a look at our conversion kits. these convert you from the airbag to a powder coated American made steel coil spring that is guaranteed to last the life of the car. I added the link below so you can check it out.
http://www.strutmasters.com/ford-suspension-parts-s/75.htm
I hope I was of some help
Good Luck!!!
1helpful
98 deville rear suspension problem
You may have either leaking shocks. follow the air line from the shock to the compressor.
4helpful
5answers
Air Rise Suspension/computer module
my brother in law replaced the air springs on my '94 town car with rear coil springs from a '92 crown vic. He raised the rear tires off the ground and put jack stands on the frame for safety on both sides. Then disconnected the shocks at the lower end and removed the air springs.removed rear tires and used a piece of 2x4 to pry axle down to provide clearance to put coil springs in place. then hooked shocks back up and it worked fine. the only way the coil springs could come out is if the car was upside down and then who cares. This project only cost $ 25.00 Real cheap being we were broke!
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
