Question about Dishwashers
Hotpoint aquarius dishwasher, After 2 minutes stop and flashes Eco 45oc and Delicate 50oc. Tried on intensive and normal washes
  • 2 more comments
  • wrightys Mar 14, 2008
    Nothing jammed and wont let reset can only turn off
    no sorry no manual ???
    what can i do to solve this
    what and where is the bat part on the power board. do i need to pull out the diswhasher or is it on the door
  • 796 Answers
Its not on the door.
it will be inside the washer.
once you pull out you can see the power board manually with sharp eyes.
there look for elements that are puffed on TOP.
just go and replace them.
Posted on Mar 14, 2008
    Guru:
  • 1,894 Answers
Does that washer get jammed up?
if so reset it
  • 3 more comments
  • dewan nafees ahmed Mar 14, 2008
    do you have a service manual?
    is so you can do it easily..
    if you dont have say me
    sir this error is due to the excessive heating of the unit
    this is due to the bad components in the power board that get heated up at start up.
    this is a sign of dying of the unit.
    if this is not cleared for few more days then the unit wont even start up for that first 5min also.
    so this must be done as soon as possible.
    thank you sir
    good luck
    dont forget to rate
    not a big deal.
    gear yourself up with a meter and solder rod and flux.
    and now open the unit and see for the bat part on the power board.
    now you got tonote down the component and then buy it from a shop and then replace it.
    matter is over.
    you get fixed.
    but you will do this at your own risk.
    if you are not sure about the interiors then i would suggest you to bring in a tech to do this.
    thank you sir
    ya johny chel was right...
    that is what i wanted to say
Lights flashing
temp solution, switch on and off at wall socket with on/off switch in and out, untill only on/off switch is lit, then use wall switch for power on off. worked for me.
Jul 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
My hotpoint Aquarius Dishwasher starts up bu only runs a few moments before stopping with 2 lights flashing " wash " " drying "
I had the problem of flashing lights and water did not pump out.Found a piece of bacon in drain pump wedged between impellor and pump body...cleaned it out...problem solved..
Mar 18, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Eco and fast wash lights flashing together and
this does mean draining cycle has timed out due to either blockage or faulty pump...
Dec 21, 2009 | Dishwashers
Hotpoint fwd60 eco and intensive lights flashing
Hi, I have a Hotpiont FWD60, the "delicate" lamp has started flashing about twice a second. Any ideas? Thanks, Nick
Mar 04, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Dishwasher prog light is flashing and pump is running nothing els
ok, just a few minutes after posting this as a fault, I have opened the covers, the machine has a leak, the undertray has a sensor which has detected this, flashing light (prog 45 degC wash) flashing is a code to indicate leak sensor active.
Other prog lights flashing indicate a different fault, the following details each... this is a cut/paste from another forum site, copied without permission....
jawa592rc_a04.gif on 6th Feb 2008
Cannot guarantee 100%accurate but you all might like what the flashing fault codes actually refer to, note what follows are pointers to what bit has gone wrong only. You should have the programmes running left to right: led1=intensive,led2=normal,led3=eco,led4=fast,led5=prewash,led6=delicate wash.ok so when this heap of western european tosh goes wrong one or two lights will flash this is what they mean:led3=m/ch has o/flowed water . ie the base underneath has sensed a leak.4=i/let h2o valve u/s or slow fill.5=thermister(electronic thermostat) is u/s or more likely the pcb .6=timeout heating which means the thermister senser between the door halves has become faulty or detached.3+4=no pump out,slow pump out,pcb u/s,blockage.4+5=tap off i/let valve.3+5=wash motor not coming on -seized,winding o/cic.but can also mean mesh plte filter badly blocked.1+4software fault with pcb.4+6=heating cic u/s (usually the heater tube )but can be the heater relay on pcb.3+4=pcb u/s.I don`t except any responsiblity for this being spot on or near spot on!! hope this helps someone.Try NOT to electrocute yourselves please!! If your not at all confident walk away and get "someone" who knows what they are doing.Cheers. jawa592
Jan 21, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint aquarius fdw60
My Hotpoint FDW60 dishwasher - I select new programme (normal 55 degree wash) and it defaults to 45 degree wash green light flashing and just making a whirring sound but nothing else happens. I have tried pressing the restart button, holding it in until I get the continuous sound and then restarting the programme but the same thing happens
Sep 17, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Dwf50 hotpoint aquarius dishwasher
hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
Jun 16, 2008 | Hotpoint 24 in. DWF32P Free-standing...
Dishwasher error codes please help
I too had this problen today. Printed off a manual from the Hotpoint website. Very helpful troubleshoot section. Anyway, flashing eco and fast lights and beeping sound indicates 'water feed pipe blocked' You need to check the water inlet connections on your tap.However, when we pulled it out we noticed the blue water inlet pipe was slightly kinked. Straightened this out and hey presto! It works fine again. How this happens when its worked ok for 18 months will never know but still. Try it! hope this was helpful...shewoo
Apr 26, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
97 people viewed this question
Top Dishwashers Experts
