Question about Dishwashers
Frigidaire Dishw. Error code CL
Frigidaire dishwasher Gallery Professional Model
Stopped with Error code CL ???
Unplugging gives expected PF code
What is error code CL?
Any causes and their fixes welcome.
  • migjimez Sep 03, 2008
    I get a CL error code on my stainless steel Frigidaire professional series, I close the door and still nothing, ,I emptied out the dishwasher and still said code. Any ideas?
  • Anonymous Mar 12, 2014
    frigidaire dishwasher is noisy and displaying hd error code
This just happened to ours and it turned out to be the gasket that seals the door.
when you see the CL error and the door is indeed shut, pull gently back on the door. if you hear a click and the unit starts running again, it may be the gasket.
ours lost it's ability to keep the seal, allowing enough 'play' in the locking mechanism for it to think the door was not closed.
Posted on Sep 09, 2008
  • brucea280 Sep 17, 2010
    CL code turned out to be CHILD LOCK was turned on. The dishwasher would just drain very quietly and any button I pressed, CL would show. Bosch dishwasher model SHE6AF02UC/05
  • mctuhey Jan 24, 2011
    Thank you!! This was very helpful.. All I had to do this gently pull the door back and I was back in business..
Close dishwasher ( cl)
Posted on Mar 18, 2008
The CL code was correct. The dishwasher was off balance and therefore threw the door off from allowing it to close properly. Once balanced it closed and worked just fine.
Posted on May 02, 2008
My Frigidaire Gallery dishwasher has the code "PF" flashing and door latch is not working. Any suggestions.
PF code on Frigidaire dishwasher
Since the PF indicates a power failure, it has most likely lost electrical connection before the control board and this is the most likely place for this to occur. Frigidaire dishwasher (PLD4375RFC0) seems to complete wash cycle but often has power failure (PF) code during the dry cycle.
the latch must be fixed for it to work a broken latch will cause this problem Frigidaire Gallery dishwasher has the code PF Google Search
also we need to know what model it is to recommend a part
Feb 03, 2018 | Frigidaire Dishwashers
I need to know what the error code pf means for a frigidaire gallery model #fgh202465nf1a
Hey Carol, I understand that you are receiving an "PF" error message on your Frigidaire Dishwasher. Typically this error code indicates a power failure. Before considering contacting a service provider, I would recommend resetting the dishwasher by turning off the power to the appliance for about five minutes. After the five minutes return power to the appliance, this should allow the appliance to return to working condition. At this time if you find the problem still persists, you may want to consider contacting a professional technician. The concern could be the control board. Hope this helps! -JK
Oct 11, 2015 | Frigidaire Dishwashers
My Frigidaire electrolux dishwasher model # FDB2310LCC0 trips a pf code 40minutes into the cycle and it is not the circuit breaker. how do i correct this problem?
Good Morning Doria, thank you for allowing me to assist you!
Typically PF means power failure and you should be able to start a cycle. Unplug the unit or flip the household circuit breaker. Wait about ten minutes and then turn the unit back on. If the error code continues to display, I would suggest contacting a professional to accurately diagnose and repair it.
Best of luck!
Oct 07, 2013 | Electrolux Frigidaire Professional Series...
My Frigidaire Gallery dishwasher will run initially when i oporate it on a normal cycle. The time will start to lower then, it will go back to 90 minutes and then shut off and then a PF code will appear. ...
Hi Gabriel, thank you for allowing me to assist you. PF is commonly referred to a power failure and you should be able to start a cycle. Let's try resetting the dishwasher by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn the unit back on. If the error code continues to display, I would suggest contacting a professional to accurately diagnose and repair it. I hope this information proves to be helpful in a small way.
Aug 05, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
Need manual
Good Morning Steve - I am happy to assist you, however according to my database I'm not showing that Frigidaire has an error code FR for a dishwasher or for any product for that matter. Could the error code possibly be an ER, PF, FL or RF?
· Typically error code ER indicates that the main control board has detected a stuck key or a key pressed for more than one minute.
· Generally error code PF means that the dishwasher has experienced a power failure and you should be able to resume the cycle.
· Error code FL is advising you that the water valve is in the open position.
· RF indicates that the rinse aid reed switch in dispenser is open and needs to refill the rinse aid.
Let's try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn on the dishwasher. If issue persists, then I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
I hope these troubleshooting tips help you in some small way.
Jun 25, 2013 | Frigidaire Professional Series 24 in....
Frigidaire dishwasher model FDB2320REC0 when I push the normal wash CL flashes
Hello linda_ross88 - Typically CL indicates that the main control board is not sensing that the door is properly closing. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, typically an expert would need to check the door switches, wiring, and test the main control board. Regrettably, this is not a simple DIY job. I would strongly recommend seeking a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
Mar 18, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire gallery dishwasher CL code
CL is a generic clear code. Reset the unit at the household circuit breaker for about 10-15 minutes, and then retry. If the same code comes up then you have a communication error with your main control board, and will require a repair.
Aug 30, 2012 | Frigidaire Dishwashers
I have pf code on the display already changed the control board same code as befor
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Feb 05, 2011 | Frigidaire Professional Series 24 in....
My frigidaire dishwasher is blinking lights and a
heatman101
Jun 24, 2010 | Frigidaire Professional Series 24 in....
Dishwashers Logo
3,841 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
