Question about Linksys Wireless-G Broadband Router
Linksys wireless-G router configuration on PPPoE internet connection
Dear Sir
I purchased 2.4ghz 802.11g broadband router
I have Tata broadband PPPoE internet connection
I try to configure the said ruoter but fail to configure it
because i dont know how set the router on PPPoE connetion
Please help me
Thank YOU
    Scholar:
  • 141 Answers
Connect modem to the internet port of the wrt54g
Connect pc to port 2 of the wrt54g
Reset the wrt54g, push reset button for 30seconds with the power on, uplug the power for 10 seconds
Open internet explorer, type 192.168.1.1, you will be asked to login, no username, password is admin. This will take you to the router page. On the page you will se AUTOMATIC CONFIGURATION DHCP, change that to PPPOe, enter your broadband username and password. Click save settings at the buttom of the page. YOU WILL ONLY GET CONNECTION IF YOUR USERNAME AND PASSWORD IS CORRECT.
GOOD LUCK
Posted on Mar 15, 2008
  • Raymond Roque
    Raymond Roque Mar 15, 2008
    You should see this page
I need to reconfigure my Linksys WRT546 router
go to 192.168.1.1 on the internet; this page will allow you to configure your router. the username is: admin the password is: admin
Jul 15, 2010 | Linksys Wireless-G Broadband Router
Internet not working through wireless linksys router but working when directly connected to modem
I think the problem will rely depending on the settings on your router, Follow these step by step solution on resolving the problem.
1. Connect the cable coming from your modem going through the internet/WAN port of your wireless broadband router.
2. I suggest you test your internet connection first by connecting an ethernet cable from your Wireless Router LAN port going to your PC NIC(Network Interface Card).
3. In order for you to setup your router, you should be using a web browser. Go through your router configuration by typing 192.168.0.1 / 192.168.1.1, on your web browser. The ip address depends on the manual of the router which default ip address is assigned to your router.
Illustration:
after enter the ip address, pressEnter and you should see a login box where you can type the username and password of the router.
You should check from your manual what is the default username assigned when you purchase the router. Since some routers have been using standard username and passwords.
You should use "admin" as your username and leave the password blank, press Enter / OK.
If you have a successful login, you should see a router configuration webpage where you can setup your router.
Look for the Internet Setup panel, select what type of connection you are using,
DHCP - for cable modems
PPPoe - for most DSL modems
if you are unsure, just check with your ISP.
Set the SSID to identify your router and assign a WEP (Wireless Encryption Key) under your Wireless Security section to encrypt your routers network to prevent others from connecting to your internet without any permission.
Feb 03, 2010 | Linksys Wireless-G Broadband Router
WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance, please leave me a comment.
Dec 25, 2009 | Linksys Wireless-G Broadband Router
Computer repair tech said Linskey wireless caused internet prob
If you are using DSL as your internet connection there is a timeout period that could be setup in the linksys.
In order to change this you need to log into your router and on check on the setup page. You see the timeout option.
Check with your linksys manual for detailed instructions for logging into the unit. If you dont have it, you can always get it from their website.
Jul 31, 2009 | Linksys Wireless-G Broadband Router
Won't connect to the interent
This article describes how to manually configure a Linksys Router for broadband DSL
that uses PPPoE (Point-to-Point Protocol over Ethernet) for authentication.
http://www.betterbuilt.com/docs/ppoe_setup_07252005.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 17, 2009 | Linksys Wireless-G WRT54GS Router...
Time Warner Cable won't identify Linksys WRV54G wireless router
If you can connect directly via your modem, then the line up to your house is fine. So no problem with your ISP.
Since you changed from cable to DSL, you might have to re-configure your router.
Open a web browser, type "192.168.1.1" in the address bar and log on to the web based router configuration page. (The default values are "admin" for username and "admin" for password)
Go to "Setup", choose "Basic" and review the entries there. You want to see it configured for "PPPoE".
Some DSL-based ISPs use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections. If you are connected to the Internet through a DSL line, check with your ISP to see if they use PPPoE.
If they do, you will have to enable PPPoE.
User Name and Password: enter the User Name and Password provided by your ISP.
Connect on Demand: Max Idle Time. You can configure the Router to cut the Internet connection after it has been inactive for a specified period of time (Max Idle Time). If your Internet connection has been terminated due to inactivity, Connect on Demand enables the router to automatically re-establish your connection as soon as you attempt to access the Internet again.
If you wish to activate Connect on Demand, click the radio button.
In the Max Idle Time field, enter the number of minutes you want to have elapsed before your Internet connection terminates.
Keep Alive Option: Redial Period. If you select this option, the router will periodically check your Internet connection. If you are disconnected, then the Router will automatically re-establish your connection. To use this option, click the radio button next to Keep Alive.
In the Redial Period field, you specify how often you want the Router to check the Internet connection. The default Redial Period is 30 seconds.
When you have finished making changes to the screen, click the Save Settings button to save the changes, or click the Cancel Changes button to undo your changes.
(This info is from the Linksys manual)
Dec 29, 2008 | Linksys -Cisco Wireless-G VPN Broadband...
1. On your computer, open IE and type 192.168.1.1.
2. By default there is no username and the password is admin.
3. Once you're in, set Internet connection type to what your ISP requires to have. If you have cable ISP usually it is just set to Automatic configuration-DHCP. If you have DSL ISP, it usually uses PPPoE.
4. But verify it with your ISP.
5. Whatever changes you do on that page, do not forget to click "Save Settings" which can be found at the bottom of the page.
Nov 06, 2008 | Linksys Wireless-G Broadband Router
Hooking up rounter to cox cable
hello!
-- what is the operating system of your computer?
-- is the router working fine before or is it a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
May 27, 2008 | Linksys Wireless-G WRT54G Router
Get no connection useing 6100 modem connected to wireless B router
Hi starman re westell 6100.
Hi i hope you have find solution with your issue ifnot let me walk you through on how to get it up and working.
First , you need to connect your modem directly to your computer. We need to access its Graphic Unit Interface by opening your browser and type onyour address bar its default gateway.
The def. gateway can be 192.168.1.1 or depending what ISP youre connected to . For ATT broadband its 192.168.1.254 / verizon broadband is 192.168.1.1..  { onyour address bar : type in 192.168.1.1 and hit Enter.
to check def gateway : you can go to start > run > cmd then enter > on DOS command type in ipconfig /all  then HIT enter > itl provide you your network list > your default gateway is your westell modem or if your linksys is connected than it should be you linksys.
Itl route you to your westell page. Try to go to  Broadband and choose connection or configure connection.button. Look for configure and by default you will see its in PPPoE> change it to bridged ethernet and save.
By enabling bridge to your modem w/c is westell youl have a chance to configure you linksys to PPPoE.
Connect you westell to your linksys and on your computer try to check your default gateway as seen above. By default linksys can be access by typing in 192.168.2.1 or 192.168.1.1. Itl prompt you for UN and PW: by default your Username is : Blank and Password should be admin. { blank = dont type anything}
On your linksys SETUP page > by default it is set to DHCP or obtain IP address automatically. Pls change it to PPPoE and type in your UN and PW : username@isp { your ISP name}. and hit save settings or save.
Restart your linksys and try to browse to check fore connection.
For all types of modem such as westell : you need to set it to bridge mode first foryou wireless router to work ie linksys. Set linksys to PPPoE .. that should work .
For more detailed steps or questions re: this issue pls dont hestiate contact me. Best wishes.
Pls enable you Wireless Encryption for your home network security.
Ciao .
Prince
May 21, 2008 | Westell Wirespeed LiteLine 6100...
Linksys Wireless-G Broadband Router Logo
1,412 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
