Question about Panasonic PanaFax UF-8000 Laser Fax
Error Message: "Contact Your Dealer Printer Error E04-01" - What does that mean?
We just bought this Fax machine from an online dealer (we started using the Fax machine on Monday - 4 days ago). I sent out a fax this morning, and now it has this error message on it: Contact Your Dealer Printer Error E04-01. We've had 2 other UF-8000's for the past 2 years, and we've never seen this error on either of them.
Please let me know what we should do!
Thank you!
  • 1 more comment
  • martinhab346 Sep 18, 2008
    Panafax UF8100 E04-01 code...how can I acces service mode and do reset, if anyone knows pls help. Thanks, Martin
  • Anonymous Feb 27, 2009
    panafax 7000 E04-01 lamp ok, thermister ok. do i need to reset 04 codes ? if i do what is the reset procedure. how do i get the machine into service mode
    panafax 7000 E04-01 lamp ok, thermister ok. do i need to reset 04 codes ? if i do what is the reset procedure. how do i get the machine into service mode. e-mail me at rgarris@bak.rr.com
    Sergeant:
  • 284 Answers
You can try a LBP fuser reset and LBP error log clear . this might fix the problem your having.
Posted on Sep 17, 2008
  • Paul Homuth
    Paul Homuth Sep 22, 2008
    leave me a email so i can contact you to help
  • 82 Answers
It sounds like you have a problem with your heater lamp which may have broke or cracked in shipping. unplu machine from wall outlet for a couple of minutes then plug in and turn on and listen for the warm up cycle to go through it's process. if the error code comes up immediately after turn on the it's your thermal fuse or a thermistor. if after warm up cycle then it's a heater lamp.
Posted on Mar 16, 2008
How do I retriev a copy of fax I sent 6 days ago
Fax machines only keep a log of phone numbers for the last 50 transactions, not the actual fax. Sorry
Oct 07, 2009 | Office Equipment & Supplies
Need to confirm details of when and what number a fax was sent approx 15 days ago.
The only way to check old transfer info for faxes is by printing out the journal. The way to do this varies from fax to fax, but most often is either with it's own button "reports" (and then "fax journal"), or by choosing "print reports" in the regular menu. The journal is emptied during power outs, so if you have had a power failure since, you cannot get the information. Additionally, the only info you will get from this is to where/from where the fax was sent, and if it was successful. Any information on the actual fax content is unavailable.
Jun 03, 2009 | Brother Office Equipment & Supplies
Unable to enter faxes while the machine is either sending or rece
turn off
Real Time Transmission
When you are sending a fax, the machine will scan originals into memory before
sending. Then, as soon as the phone line is free, the machine will start dialing and
sending the fax. If memory becomes full, the machine will send the document in real
time (even if REAL TIME TX is set to OFF).
Sometimes you may want to send an important document immediately, without
waiting for memory transmission. You can set REAL TIME TX to ON.
1 Place the original face down in the ADF.
2 Press Menu, 2, 2, 6.
3 To change the default setting, and then
press or to select ON (or OFF) and
then press Set. Go to Step 5—OR—For
the next fax transmission only, press or to select NEXT FAX ONLY,
and then press Set.
4 For the next fax only, press or to select ON (or OFF), and then press Set.
5 Press 1 if you want to select additional settings. The LCD returns to the SETUP SEND
menu—OR—Press 2 if you are finished choosing settings, and then go to Step 6.
6 Enter fax number and then press Fax Start.
May 23, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Fax machine won't answer and pickup. I have to manually pick up the receiver and press start. This just started a few days ago.
You probably have it in the fax/tel or TAD mode. Press the butoon on the top right side of the keyboard marked "mode" until the light above it is on "fax" only. This mode (fax/tel) is for phones/faxes hooked to an answering machine. The "fax" mode puts in into the direct answer mode as a fax machine.
May 22, 2009 | Brother IntelliFAX 4100 Laser Fax
Retrieval of fax from memory
No. And even if you could, it would simply list the # the fax was received from, and the # of pages. The actual fax is not retained.
May 14, 2009 | Office Equipment & Supplies
MFC 7840W, fax not sending or receiving
Is your phone line DIGITAL? Fax machines are ANALOG devices.
Jan 15, 2009 | Brother MFC 7840W Printer
Printing a fax saved in memory
Press Function/Set, 8, 4.
2 Press Start.
3 Press Stop.
Aug 30, 2007 | Office Equipment & Supplies
Doesnt Know How To Use Fax
Very easy. Make sure you have a phone cord plugged from the wall to a port in the back of the machine marked "line". Place you document in the feed, dial the fax number of the other machine and press start. Your machine will dial the other machine, make some beeping noises then scan your document. If it feeds through ok, and you do not get an error message in the display, then it has been sent!
Jun 19, 2007 | Brother FAX-T78 Plain Paper
Panasonic PanaFax UF-8000 Laser Fax Logo
1,213 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
