Question about Cyberhome CH-DVD 300 DVD Player
No Power.Model # DP02CD
Hi,I took cover off unit i see the fuse have a lump in the middle of it is this normal for a 250V fuse?
    Problem Solver:
  • 9 Answers
First check the power supply for bulging capacitors,and burned componants,these units stay on,even thogh you power the unit off,,unplug when not using
Replacec-10,and c-11 filter caps
Posted on Mar 15, 2008
Replace your fuse
Won't turn on
Unplug the unit , leave it unplugged, after an hour remove the top cover, look for a fuse near where the power cord enters the unit
. it will be near the power transformer and labeled F1 they are usually 4.5amp 125/250v. the reason for powering the unit down and leaving it off is to let the power capacitors bleed off.some fuses are in holders and some solder in. Hope this helps. If the unit has a bar code anywhere on it you can read the bar code with an app for cell phones and get all the info there. Also try schematicsunlimited.com
Apr 29, 2014 | RCA RTD615I 5.1 Home Theater System - 600...
GE Advantium 120 SCA1000DWW03 blowing 20amp fuse
Our unit was doing the same thing,
took it into the repair shop, they said there was nothing wrong with the unit, replace the main breaker that supplies power to microwave and try again.
Sure enough the breaker became defective, and we never had issues with it before, but now the unit has not had a single problem.
Feb 13, 2014 | GE Advantium SCA1000H Convection /...
Blowing a fuse up turning the selector on position.
I'm guessing this is a large Pro Espresso machine. 250V/15A is a bit low as they usually range in 25A which should be on a 250V/30A line. Not your normal home outlet unless your using a washer/dryer outlet. You need an electrician to check if this much power is available on your premises. Check the nameplate rating on the machine to confirm this. If everything checks out and your still blowing fuses then the heating element needs checking. Blown (cracked) elements will short out in a tank of water causing over boiling and high steam pressure. Serviceman should check this as there are dangerous voltages present. Aloha! ukeboy57
Sep 16, 2017 | Miele CVA610
I plugged it into 220V outlet and Brother HL 2140 only accepted 110-120V. Is there a fuse somewhere I can access and replace? THank you.
hi. I had the same problem and to fix it you need to take printers right-side cover off. Underneath you'll find a Power Supply Board - hidden under metal cover. Take it out and disconnect two cables from it. Now, I had to replace an fuse 125V 4A and varistor E241AD 83P on the Power Supply Board in mine HL-2140. It works fine now.
Note: I could not find the exact replacements in electronic store so I used:
- fuse: 250V 4A
- varistor: FNR 10K241 (241 is the important number)
Hope it helps.
Oct 28, 2010 | Brother HL 2140 Laser Printer
Actually iSymphony M110 - it doesn't wont to turn on. Just the stand on red lamp is on and no response on any buttons. Does it has sort of reset button or it should be repaired in service center? Do you...
I just bought one of these "dead" units for $15...I replaced the blown 2A 250V fuse with a new 2A fuse and it blew as soon as I plugged it in so then I took one of the 4A 250V fuses from the other side of the unit(located right behind the speaker output terminals) and it works perfectly now.
Sep 18, 2010 | iSymphony M1 Shelf System
Question about a T.13 AL 250v fuse
The short answer is yes. This is normal for this type of fuse.
Dan
May 25, 2009 | NAD C270 2-Channel Amplifier
Fuse blown
the fuse will always blow if there is a shorted component. the horizontal output transistor may be the most likely culprit, if you are not a technician, have it service by a qualified one.
May 15, 2007 | Samsung TXR3079 TV
Cyberhome CH-DVD 300 DVD Player Logo
367 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
