Question about Sony Playstation 3 (PS3) Console
Bluetooth connection on ps3
I cant get much headset to work on my ps3 even though it says that they are paired together.
  • brillz Apr 07, 2008
    thankyou so much for your help it worked just changing the settings as u described,
  • 27 Answers
Make sure that in settings, that your bluetooth device is set as being your main chat audio device.
Posted on Apr 04, 2008
SOURCE:
Isymphony v1blue docking system, the bluetooth pairing function is not working, any ideas? Thanks
  1. Settings
    • If the Plantronics headset was working before, an unintentional change in settings may have resulted in the headset not pairing. Access the Audio Device Settings menu in Settings, and restore the default settings for headsets.
    Re-Pair
    • Resetting the connection between the headset and PS3 may solve the pairing issue. USB headsets only need to be connected to a USB port to be paired. A Bluetooth headset must go through the pairing process (see Resources).
    Functionality
    • If you're using a Bluetooth headset, confirm that it has fresh batteries and is receiving power. If possible, sync the headset with a cell phone or another PS3 to confirm that it works.
Jan 20, 2013 | Audio Players & Recorders
How do i connect this headset
Pairing the Headset
Pairing is a process of associating Bluetooth devices with each other.
It will establish a permanent security link between the devices and
enable quick access to the services provided without the need to reenter
Pass Keys. You will only need to pair your PS3 and the Headset
once.
Paired devices remain paired even when:
-One of the devices is powered off.
-A service connection is interrupted or stopped.
-One or both devices are restarted.
Mar 13, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
Recently when i try to connect the bluetooth to my ps3 it says that a connection could not be established.Howq do i fix this?
If the Headset has been paired with another Bluetooth device, the PS3 will have trouble finding the Headset. Either remove the Headset from the paired device or turn off the Bluetooth power on the paired device.
Aug 18, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
I cant connect my headset
Have you charged headset via usb cable plugged into ps3...when charged press + hold silver telephone symbol...a blue pulse light should appear on headset..go to menu in ps3..to pair devise [headset] with Bluetooth.
Feb 26, 2010 | Mad Catz Bluetooth Headset for PlayStation...
Can't pair bluetooth
....My madcatz bluetooth will not charge everytime i plug it in the ps3 the red light comes on then it goes off and it keeps on doing it and its a brand new bluetooth...i hold it for a long time and it still wont work..HELP PLEASE!!!!!!1
Feb 06, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
I cant get my bluetooth to work on my Ps3.
From what I understand, once your device is paired you have to go to Audio Device Settings > Input device > select "your headset" > output device > select "your headset. Then click "Connect Bluetooth" icon. Then OK. That should do it.
Jan 25, 2009 | Samsung WEP180 Wireless Headset
Linking a BT125 Bluetooth to my PS3
I had the same problem trying to connect my old Jabra BT125 headset to my brothers PS3, here's what worked for me:
-Turn on the headset by holding down the button but keeping it down until a solid light comes on.
This puts the headset into discovery mode, you can the start scanning for the device and it should find it.
Jan 26, 2008 | Jabra BT125 Headset
Bluetooth
I will take a guess that you are trying to pair with something other than a bluetooth headset. The iPhone cannot connect (even though it may pair okay) to other phones, headphones, or any device other than a bluetooth headset. This feature is intentionally crippled by Apple.
If my assumption is wrong, please provide additional information about what exactly you are trying to do (and with what) to get your problem resolved.
Jan 12, 2008 | Apple iPhone Smartphone
Connecting bluetooth headset to ps3
You have to do 2 things in order to use a bluetooth headset on your ps3. First you have to pair it with the ps3. To do this you go to your setting and register the bluetooth device. Make sure your bluetooth device is in pairing mode when you do this. On most headsets you can simply hold down the button until the light comes on a solid color. once it is in pairing mode you will have to scan for new devices. Once this is done you should see the headset on the list. Choose it and enter your pairing code. If you have not set one it will most likely be 0000. Once it is it paired you will have to change your audio output and input. Go to audio device settings and change the input and output device to your headset name. Enjoy!
Sep 25, 2007 | Video Game Consoles & Games
How do i connect my bletooth h350 to my phone
Hi, follow the steps to get your product paired. Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset With the headset power off, press and hold the Call button for 6 to 10 seconds until the blue indicator light turns on and remains steadily lit. (The light will flash while you hold the Call button.) If the indicator light is flashing or does not remain steadily lit, turn off the headset and repeat step above. Step B - SET THE PHONE TO LOOK FOR YOUR HEADSET Select (Menu) > Settings > Connection > Bluetooth Link > Handsfree > Look for Devices. The phone lists all Bluetooth devices it finds. Select Motorola H350. Press OK or Yes to pair (link) the handsfree device. Enter the passkey 0000 and press OK. Note: Passkey cannot be changed from 0000. When your headset is successfully paired with your phone, the blue indicator light changes from steadily lit to flashing. additional help http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf all the best sreejith 2 Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset
Jul 16, 2007 | Motorola Mobility H350 Wireless Headset
Sony Playstation 3 (PS3) Console Logo
75 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
