Question about Mitsubishi VS-50707 50" Rear Projection Television
The screen doesn't come on. You can hear the tv turn on, but the picture is not there.
  • 707RAIDERS Mar 14, 2008
    Are you talkin about the STK's? Which IC's are you referring to?
  • Mitsubishi Master
  • 8,617 Answers
Try resoldering the vertical output IC sounds like the CRTs are blanking due to vertical deflection. this model is famous for cold solder on the vertical output.
Posted on Mar 14, 2008
How do I fix a flat screen tv that when turned on the screen is black with no picture?
place a turned on torch against the tv screen while tv on can you see a picture ? If yes then back light problem possibly inverter that powers the back light.
You tubesearch on tv faults for more insight on possible causes of black screen or no screen on Tv's
if no picture with torch then it might be main board .
Check you tube for ideas on possible causes.
Jan 27, 2017 | Televison & Video
Small picture in left corner. Remote doesn,t work
Press Man from your LED TV back side.
Select setting and try to change Picture setting by Ch Up & Down and Vol Up & Down.
Feb 27, 2015 | Televison & Video
Turns on but doesn't do anything else. Screen doesn't come on. Can hear a clicking sounds like a turn signal sound.
looks like a( DLP) tv digital light proccessor . aka projection. most likely the bulb is burned out . if so cost is $65-125 bucks. aftermarket bulbs are available online but some dont work or burn out prematurely. if you decide to fix it or buy a new tv ,invest in a surge protector. it will save your tv from problems like this . good luck.
Feb 11, 2013 | Televison & Video
My tv blacksouts with no picture but has sound?
tried with resetting doesn't work?totally black screen or has a white screen display?
Sep 30, 2012 | Samsung PN50B430 50 in. TV
My tv turns but it doesn't show a picture but you can still hear
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 28, 2012 | Mitsubishi WD-60737 60 in. HDTV
No sound, no picture
Hello sorry to hear that. From your description it sounds like your signal board may have been damaged by you plugging in your laptop to it. The signal board is the one with the tuner on it.
Feb 22, 2012 | Vizio P50HDTV20A 50 in. Plasma HDTV
Hello, I experience a problem with my JVC LT23X475 TV. There is sound, i can hear everything, but no picture. it is a dark screen, as if it doesn't turned on.
Maybe the problem is no backlights.Its either deffective backlights driver or power supply.Its better to check by the athorized repair technician to do the repair.
Jul 11, 2011 | Televison & Video
The picture doesn`t fit the screen. Daewoo DWX-28W5GB telly
Sometimes the box that sends the signal to the TV preconditions the signal to 4x3 or 16x9, depending on the capability of the TV. I always opt to the "no fit" option and allow the intelligence of the TV to fit the screen.
If you have "off air" TV signal without that preconditioning, I cant help.
Oct 02, 2017 | Daewoo DTQ-20U9SC TV
TV has audio sound and no picture
major repair; requires 16 pin ic
Apr 19, 2008 | Televison & Video
Mitsubishi VS-50707 50" Rear Projection Television Logo
64 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
