Question about GE GSL25JFPBS Side by Side Refrigerator
Ge icemaker problems GSS25LSWASS
Ice maker will not dump ice. Installet new part, still no ice, will fill with water but will not dump. Is it possible that the icemaker is controlled by the control board for the ref??????
  • Anonymous Dec 27, 2008
    I know it's a hotpoint side by side but did not note model. A friend asked me to assist him in installing water line from water supply to water line at back of appliance. I am not sure what to do. Your opinion please.
    Scholar:
  • 54 Answers
What part was installed?
Ensure that the Ice Maker arm is in the down position.
There is a thermostat that closes when the ice mold reaches a temperature that indicates that the water in the mold is frozen if this thermostat is faulty it will prevent the Ice Maker from going into the dump cycle.
Hope this helps.
Posted on Mar 16, 2008
SOURCE:
My icemaker has stopped receiving water
it sounds like your water valve is bad. you have a double water valve - one side operates the ice maker and the other side operates the water dispenser. the ice maker side of the valve is bad.
you can manually pour a little water in the ice maker ice mold and wait an hour or so - if it dumps the ice then you know for sure that the ice maker is cycling and water is not getting to the ice maker from the water valved
May 25, 2010 | GE GSS20IEP Side by Side Refrigerator
Ice Maker does not dump ice
IF THE ICEMAKER IS TURNING AND NOT DUMPING YOU NEED TO REPLACE THE ICEMAKER ***.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 12, 2010 | Samsung Refrigerators
After 2yrs of not using the icemaker, moved
Good day,
Pour water from small paper cup until it near fills the well of the ice maker. With the lever down, close freezer door and wait 2 to 3 hours. If it dumps then the ice maker should be good, if not, replace ice maker.
If dumps O.K. then the dual water valve is bad, and needs replaced.
You should check the fill tube that runs from the back of the machine to see if it is blocked with ice. (requires removing ice maker) but even so, if it is iced, you'll need to clear, but the water valve in the back rear of the machine is leaking and still needs replaced.
Thanks for using FixYa
Dec 20, 2009 | Refrigerators
GE Profile Arctica PSS25SGNA BS Icemaker is not working seems to be filling with water but no ice.
The water dispenser and ice maker side run separate sides of the water control valve. Fill ice maker with tap water and let it freeze. If it dumps the ice then does not refill then the water control valve is the problem. I will be back soon with a photo and some links, Thanks, Sea Breeze
Nov 18, 2009 | GE Profile Arctica Stainless Steel Top...
Ice maker will not make ice. no ice is being made. no water appears to be in ice cube making area. can hear a ticking noise from icemaker area
Carefully pour water from small glass into ice maker, until the cavity is near filled. Wait a few hours. If it dumps ice, you can usually rule out the ice maker.
If ice maker dumps, then it will be either a bad water valve, Ice building up in fill pipe going into the icemaker, or blocked water line that runs from your water source to the machine.
Caution. If the fill tube going into the ice maker is filled with ice do NOT
use heat such as a hair dryer to melt it. It will melt things you do not want to melt. If it is this problem, you must also replace the water valve because it is leaking slowly causing your problem.
Lastly, in rare cases, the microswitch in the ice maker fails and does not allow water to enter the icemaker.
Oct 22, 2009 | Kenmore Refrigerators
Model 22 Icemaker is not making ice
The following assumes that the ice trays are properly filling with water. If not, check the water control valve.
As long as the ice trays are filling with water, it's not actually the function of the ice maker to make ice. Ice simply forms because the freezer compartment is cold.
The icemaker's function is to sense when ice is formed in the trays and to dump the ice into its container.
This requires the use of a thermostat to sense the water/ice temperture and 'tell' the icemaker when it's time to dump the ice.
During the dump cycle, a heater briefly comes on as the arm swings through the ice cube compartments to assist in loosening the ice cubes and make them easy to dump.
If the icemaker is filling with water but you get no ice, I suspect that either the control circuit (thermostat, relays, and wiring) is not 'telling' the heater to come on, or the heater is burned out.
Some units also have a timer circuit such that both the timer contacts and the thermostat contacts must be close in order to initiate a dump cycle (i.e., it must be time to dump and the water in the cubicles must be frozen).
A skilled homeowner could make these repairs, but if you don't feel comfortable taking your icemaker apart and testing the components, I advise leaving the job to a qualified repairman.
I hope this helps. Good luck.
Sep 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE REFRIG
Most likely your water control valve for the icemaker side, you can check the ice maker by filling with water and when freezes and if dumps then the water control valve. Part number WR57X10032
Sea Breeze
Aug 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
All water underneath.ice in the bottom.freezer working.not making
If I understand you correctly your water line that comes through the back wall of the freezer and into the icemaker is frozen. If so you have a bad water valve. When the valve goes bad it will not seal off the water. It will seep causing a slow drip where the water comes out at you icemaker. It'd slow enough to freez causing a ice blockage. This will not allow water to come through and fill your icemaker when it calls for water.
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker does not work
Make sure fill tube is clear . Pour about 1/2 cup of water into icemaker . If ice dumps but no water into icemaker , replace water inlet valve . If water stays in icemaker , never dumps , replace icemaker . Make sure the coils are clean of dust , lint ,etc...
Aug 05, 2009 | GE Refrigerators
Not putting water into ice maker to make ice
Try pouring 1/2 cup of water into the icemaker and if it dumps ice , then the water valve or fill tube is the problem . If it does not dump , then the icemaker is the problem , or , freezer is not cold enough . Check your coils under the refrig to make sure they are clean and the fan that cools the compressor is working ( and the freezer fan also ) .
Jul 16, 2009 | Kenmore 57029 Side by Side Refrigerator
GE GSL25JFPBS Side by Side Refrigerator Logo
395 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Tmik
Tmik
Level 1 Expert
