Question about Sony Cyber-Shot DSC-S60 Digital Camera
Dsc60 battery drains quickly
The problem I'm having is the batteries lose power very quickly. The batteries get replaced frequently and die within a short period of time, regardless of the number of pictures taken. Recently, the best case was about 150 pictures taken in a four hour period. The worst case was only one picture taken in a four hour period before new the batteries died.
    Master:
  • 351 Answers
Dear AIMORE,
it provides up to 110 shots with the supplied alkaline batteries2 and up to 550 shots with optional NiHM rechargeable batteries.so its depends on user that what kinda batteries are using by him.
i think you got the solution of your quarrey.
Cheerup and Be Happy Always
Posted on Mar 14, 2008
    Guru:
  • 1,894 Answers
Hello sir
these are the possiblities of the problem happening you are facing.
>>if the camera is facing this problem from the time you got it means then the product is defective one
>> if not then there must have been some problem with the power circuit
>> also if you are using low quality batteries they get drained out very soon.
>> so please go for very good alkaline batteries with high current rating .. a 2100mA will do good.
  • dewan nafees ahmed Mar 14, 2008
    and for detecting the problem do some sorting out checks.
    just check how many photos the camera is giving with flash.
    then use the same quality battery in some other digital; camera and take the photos in same mode.
    you can sort out if the battery is bad or the camera is bad
    after that you have cleared half way
    you can solve it from here easily
    thank you sir
    good luck
    don't forget to rate the solutions
  • Sony Master
  • 19,396 Answers
First of all, you need to use alkaline batteries with you camera, if you use mercury ones they wont last long.
  • Ginko
    Ginko Mar 14, 2008
    Ensure that you are using alkaline battery (eg. Duracell). if you are and you still get the problem then there is a short inside the camera that i s causing the battery to drain faster than normal.
    regards
Losing battery life too quickly.
Some of the things that drain the battery quickly are:
  • WiFi, if you're not using it turn it off
  • Cellular Data connection
  • Using push notifications - this requires that the iPad be constantly receptive and therefore using battery.
  • If you are using it during those two hours, try dimming the screen some.
  • Quitting apps that you aren't actually using can also reduce battery drain.
Feb 25, 2014 | Apple iPad Md368ll/A 64GB Wi-Fi ATT 4G...
Electrical short
Alternator's shot. You're probably running on battery only till it drains down.
Feb 22, 2014 | 2002 Chevrolet 0239 2500 Cargo Van
I will drive for about a mile with full power with little power lose.then all of a sudden,ill have extreme power loss . within 1quarter mile ill lose all power.something drains the batteries
Batteries do not provide a linear output during usage, but having it die out within a mile or so tells me that one of the battery cells is becoming weaker than the rest. If you're a handyman, you can save yourself a ton of money by replacing only the batteries (try interstate batteries) instead of going to the scooter store and purchasing the batteries and case.
Nov 04, 2010 | Pride New Mobility Victory XL 4 Wheel...
Frequent battery replacement - losing power while I drive, however I had the alternator tested by autozone which said it was "good" - the car starts fine, everytime, just loses power, rpm's fluctuate and...
go thru check ur starter connections,battery connections,alt connections,check all fuses then give it a shot if it still dies replace ur alt
Oct 21, 2009 | 1992 Toyota MR2
Battery drains quickly. Loses charge when plugged
Sounds like you need a battery. The key here is that the battery is losing charge while it is supposed to be charging. Works like a car battery, even if the alternator is working 100%, if the battery is pooched, the car won't start.
Sep 25, 2009 | Motorola Mobility Moto Q
Battery life dies out quickly on Nokia 6301...
if you have had your bluetooth on or have been listening to music for a long time that can drain the battery very quickly . the other problem could be if you are not lettting it die of totally then charging it the battery remembers so when you do charge it the battery dont last long . try turning your bluetooth off or just lettin your battery die off totally then charge it fully
Aug 07, 2009 | Nokia 6301 Cellular Phone
1992 prelude si - battery/alternator prob?
if you can charge the battery and drive it for a while then sounds like the altenator has failed and is not re-charging the battery, good way to test is to charge the battery, start the car and turn the light on, if everything is dimm or the motor dies there is little to no charge voltage, and will require altenator work
Jul 01, 2009 | 1992 Honda Prelude
1999 Volvo S80 will not hold a charge
Tricky ... Was the alternator replaced with a 2nd hand one or a new one?
A defective alternator can allow the battery to discharge within a few minutes (the diodes in the rear of the alternator can burn out and cause the problem. The diode pack can be replaced). When this happens recharging the battery only replaces the power in the battery - which drains straight back to earth via the alternator, flattening the battery again - often within a couple of minutes or less.
Does the battery lose its charge when the car is standing or just when the engine is fired up?
If the battery loses its charge overnight, try disconnecting the wiring from the rear of the alternator (also look at the electrical connector that fits into the back of the alternator - look for melting/burning marks which suggest something may be amiss inside the alternator).
Let the car stand overnight with the alternator wires disconnected. Will it start up ok and drive (with the alternator wires still disconnected) the next morning?
You could also try just disconnecting the alternator wires, firing up the car and then driving it -
If the car drives ok without dying out and gets further down the street than it usually does, then it probably is the alternator at fault. The car should drive until the battery drains and has insufficient power to trigger the ignition. You certainly would get further down the street with a charged battery and disconnected alternator than you currently do.
It does sound as though you've had an alternator fault to begin with. If it has been replaced with a 2nd hand unit that unit may also be faulty. Rather than replace parts in desperation, visit an auto electrician's - within a few minutes they will be able to test the battery/alternator output and also identify where the lost current is going. It will be cheaper in the long run to have an auto electrician look at the charging system. It only takes a few minutes.
Sep 14, 2008 | 1999 Volvo S80
Dsc60 batterries run out quiclky
Test a different battery (one you know is good) on the camera and see if you still have the problem. If with you still have the problem then probably it is a short. Check first in battery contacts, if you can see a short there than it is an easy fix, otherwise you need to open the camera and test contact inside.
regards
Mar 14, 2008 | Cameras
Sony Cyber-Shot DSC-S60 Digital Camera Logo
81 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
