Question about Polti Vaporetto 2400 Canister Steam Vacuum
Cant find out where i get a new gun handle mine has snapped
The gun handle has snapped i cant find out where to get a new one could you help i live in manchester ps on my polti 2400
  • cheesy 1945 Mar 14, 2008
    please could you help
  • Misjudgment Jan 22, 2009
    Bad design. I have used my Vaporetto 2400 6 times and the join below the nozzle has snapped. I am really fed up having paid all of this money for it only to find it is very fragile to use. Bought it a while ago but only just begun to use it so no chance of finding any guarantee.
Http://www.spares2you.co.uk/Vacuum+cleaner+spares/Polti+steam+cleaners/Vaporetto+2400/
Posted on Jun 06, 2008
How do I rebuild my dyson
without more information id say pull U shaped pipe off bottom and then re-install new hose at bottom then slide handle down into it snapping it in at top. if this doesn't help please feel free to respond with more info and maybe a pic
Jan 08, 2013 | Dyson DC07 All Floors Bagless Upright...
Can I get a replacement handle for a hoover wind tunnel upright? It snapped off
That part is available. Includes the handle, cord and "digital" switches. Here's the link:
http://www.vacuummedic.com/product.php?id=389
Good Luck!
Vac Dr.
Sep 29, 2012 | Hoover UH30010COM Bagged Vacuum
I can't get the lower handle cover off the Bissell
Did you ever get the lower handle unit unsnapped from your Bissell Proheat? I can't get mine off so if you have any suggestions, please let me know.
Jul 07, 2011 | Bissell 7901-R Clearview Proheat Plus...
How do you put the telescopic wand down? Just got a new dyson 17 and I cant use it cause I cant get the dang wand down..
make sure your handle is snapped in all the way on to the machine, that will release the clip on the hose to allow for the wand to slide in.
Jan 06, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
How do you replace the handle release pedal
The handle release is just snapped into the bottom base. To take it out you will need to take a flat screw driver and pry the old one out. Then take the new one and pop it into place.
Dec 02, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Dyson DC7 full Kit, with one belt does not get suction to head.
Not absolutely sure about this, so your feedback will be very welcome.
What follows applies to the DC14, which I think is similar in this respect:
Stand behind the machine, holding the handle at a 45 degree angle. Locate and remove the airway inspection valve (bottom of handle, right side). Where the valve plugs in there is a square plastic moulding that should slide up and down. Snap that square plastic piece up towards the ceiling. After it snaps into place, the machine should stand upright.
Good luck, and please let me know how you get on!
Mar 21, 2009 | Dyson DC07 All Floors Bagless Upright...
Assembling a steam vac handle part
when the machine comes new the way it is installed is to put the upper handle on the lower handle, install the bolts & nuts (tighten) and then to pull the trigger and press the surge button (if this model has one). you will feel them snap together. the clips on the rods should be at 90 degree's from each other. one will be a u type channel and the other a v type and will connect.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Jan 07, 2009 | Hoover F5810 SteamVac Upright Vacuum
Assembly
The handle just snaps into place on the top. there is a handle pivot, it goes in that. The bag, put over the exhaust hole on the right side, make sure it locks into place, the bag top will snap into the top part of the handle.
Jul 11, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Upholstry set up for ultimate g kirby.
Remove the entire cloth bag assembly and put the hose on the side where the bag came from. Remove the power nozzle and put the intake guard onto the front. (this is in your attachment set...the only one with little hooks that sit on the bar in front) You can change from the long handle to the short if you'd like also. You get the handles off by pushing the "seatbelt button" located at the rear bottom of the handle and pulling the handle straight up and out. Now, put your spray gun on the hose. Don't forget the little suds nozzle that goes on the end of the spray gun. I like to use a half and half solution of Kirby shampoo and water in the gun. It makes a nice dry foam that only wets the surface of the furniture. If you use more water, it takes longer to dry.
If you need a manual (book or DVD) for your Kirby, try this link....
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Hope I helped...
Marci
Mar 11, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Electrolux contour 1100 flexihead. Z1436
You need to unscrew the screw at the back / base of the handle. The whole handle section will need to be slid backwards. Best way is to unscrew the screw on the rear approx 5 turns and then bump the end of the screwdriver. A few more turns then bump the end of the screwdriver again. The whole handle will eventually slide backwards and fall off. Then unscrew the two screws at the front (near switch) and the front switch cover plate will lift up (hinging at the top). This reveals the incoming wires etc.
Jun 18, 2007 | Electrolux Cleaner Lux 6000 Vacuum
Polti Vaporetto 2400 Canister Steam Vacuum Logo
243 people viewed this question
Top Polti Vacuums Experts
Jose Pino
Are you a Polti Vacuum Expert? Answer questions, earn points and help others
