Question about Brother IntelliFAX 4750 Plain Paper Laser Fax
Smudging and overlapping
Printouts are smudged and have to different documents on one printout.
    President:
  • 2,072 Answers
By smudging do you mean the print is actually rubbing off?
I am going to assume you are seeing some reprint on all printed pages.
If I am understanding correctly, what you have is a bad fuser, most likely a bad heat roller.
That is the heated area just before the pages exit the machine.
The coating on those rolls wear out with time, or may even debond from the aluminum. The ink does not then properly melt into the paper, sticks to the roller and progressively becomes worse.
Replacement of the fuser should resolve that issue. That's simply a normal wear item.
Posted on Mar 14, 2008
SOURCE:
My hp3600n makes a grinding sound at start and the printout always has gray verticle smudges on it
If you run the PQ troubleshooting pages you will likely find that your black cartridge is faulty. Sounds like the drum is dragging.
Aug 02, 2015 | HP LaserJet 3600n Printer
Smudge and missing ink
remove all image units. clean the class where the laser writes on the drum with machine no laser. so clean. smudge what color replace the that color image unit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 07, 2014 | Konica Minolta Magicolor 1600W Printer
Recently bought a kodak 3250, and had to renew the ink cartridges. i did this twice and still cannot get printer to print any documents. as far as printing pictures is concerned the printout seems to come...
itcould be the coagulation of ink in between the cartridge better dip it in mildhot water for some times and replace it wiping the water . it would do thetrick and solve your problem . it has been practically tested.
If this solution helpful/useful for you please rate my solution. THANKS FORUSING FIXYA
May 16, 2011 | Office Equipment & Supplies
My printer is smudging the left hand side of the printout. How do I clean it?
Check and verify smudging not caused by toner cartridge by removing toner from printer and checking the blue roller. DO NOT TOUCH the roller as oil from fingers may cause image defects. If toner good suspect fuser causing smudging on your printouts. Note fuser not considered a customer replaceable part for this model.
Mar 11, 2010 | HP LaserJet 1320 Printer
I have black smudges on my printouts. I using
This may be the cartridge itself, take the black ink cartridge out and check the head on it (the part that points in to the printer, usually down) and see if it is dirty or has ink smudges on it.
Mar 12, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Smudged printing
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Smudged Printing
change ink cartdidge then try. check also paper jam.
if still problem then change ink cartridge then check.
Jan 05, 2009 | HP LaserJet 2100 Printer
Need to know what would cause smudges on a laser printer printout and what the solution would be?
its very common when the climate is humid.the drum and the toner powder of ur laser cartridge catches moisture which then produce smudged printouts.to solve this problem u need to blow the hot air dryer on the drum and powder unit.the moisture will go off and ur prints will be fine thanks.
Sep 16, 2008 | Office Equipment & Supplies
Smudges on printout
drum or fusing assembly most likly
Aug 18, 2008 | Office Equipment & Supplies
Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
151 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
