Question about Lands Phones
I have a KX-TG6700 base station and 4 Handsets. When I have been calling on the handsets I have recently found that there is static on the line. Later I realized that there is problem with the DTMF being regognized by the automated attendants at some buisnesses. Finally when I was working by the base station I noticed a noise from the base station like someone was talking and realized it was someone in the building using one of the phones to call out. After further investigation I was able to determine that I could hear anyone (very garbled) that was using one of the other phones. The speaker button was not pushed on the base station. I have another, older KX-TG2720 2.4 mHZ base station and handset units being used on the same incoming telephone lines about 40 feet away. Is the base station defective? Why all of a sudden am I experiencing problems? What do I do to get the base station fixed if necessary? Skip
    Guru:
  • 1,894 Answers
You are right its the problem of base station
for this you have to call a tech to fix it
also you have to tell him to check your phone line also
Posted on Mar 16, 2008
    Master:
  • 351 Answers
Skip Kaub,
yes you are right its the problem of base station.for this you have to call telephone engg. to fix it and additionally you have to tell him to check your phone line also .
Cheerup
Posted on Mar 14, 2008
    Master:
  • 788 Answers
The KX-TG6700 manual at: http://www.panasonic.ca/PDP/OperatingInstructions/kxtg6700-oi-eng.pdfhttp://www.panasonic.ca/PDP/OperatingInstructions/kxtg6700-oi-eng.pdf
States:
For best performance
Base unit location/avoiding noise
The base unit and other compatible
Panasonic units use radio waves to
communicate with each other.
For maximum distance and noise-free
operation, we recommend the following:
LPlacing the product away from electrical
appliances.
LPlacing the base unit in a HIGH and
CENTRAL location with no obstructions
such as walls.
LRaising the antennas vertically.
LIf you use the handset near a microwave
oven which is being used, noise may be
heard. Move away from the microwave
oven and closer to the base unit.
LIf you use the handset near another
cordless phone’s base unit, noise may
be heard. Move away from the other
cordless phone’s base unit and closer to
your base unit.
Have you considered all these points?
Is there a way you can move the base station to another location in your house to see if the problem get better? I don't beleive your base station is faulty, I suspect interference from something.
I don't think the 2.4GHz set is causing any issues, but you never know, try unplugged it for a while to investigate.
If you do determine that the base station is faulty there probably isn't many options to get it repair other than sending it to Panasonic. May be cheaper to buy a new base station to go with your extra handsets.
Good Luck!
SOURCE:
The line 2 ringer is off (it displayes message "ringer off line 2" on the number 2 remote phone panasonic kx-tg6700 & I cannot figure out how to turn it back on
Please try this first (Reset the phone which requires the ringer to operate again with the main base) Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phone
Jan 20, 2011 | Panasonic Lands Phones
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones.
Jan 20, 2011 | Panasonic KX-TG6700 Phone
I am getting static on all handsets. What can I do to stop it?
sounds like it may be your phone lines or loose connection at the base station. buy a cheap hardwire phone to test this if the new phone has static it is your phone lines. if it doesn't have static check the connection to the base station.
Mar 12, 2010 | Panasonic KX-TG9341T Cordless Phone
No KX-TGA101S communication with KX-TG1033S
The additional handsets must be registered to the base unit. Here are the instructions from the manual:
HANDSET
1. [menu}
2. "handset settings" - OK
3. "Registration" - OK
4 "HS registration" - OK
BASE UNIT
Press and hold [LOCATOR] until the registration tone sounds.
-if all registered handsets start ringing, press {LOCATOR] to stop, then repeat this step.
-after the base unit beeps, the rest of the procedure must be completed within 1 minute and 30 seconds.
HANDSET
Press [OK], then wait until a beep sounds and Y stops flashing.
Jan 31, 2009 | Panasonic KX-TGA101S Cordless Handset
Dead handsets
i had the same problem with my KX-TGA650 and called repair out and they said it wasn't seating on the home base to charge, we'll see. i'm looking for a manual for this phone lost mine and cost prohibitive to order from panasonic. and download pdf is just too large.
go to website and it tells you that only a same model is able to be used with the base unit. hope this helps.
martha
[email protected]
Jan 05, 2009 | Panasonic KX-TGA650 Cordless Expansion...
Extra handsets no longer seem to work. No ring and no line
Please be sure to put the extra handsets in the MAIN base station to register. They will not register in the small remote charger stations.
Let me know if that fixes the problem!
Brian
Jun 15, 2008 | GE 25942GE2 Cordless Phone System
Panasonic KX-TG6700
I have the same problem and I simply open the base (5 screws at the back), disconnect the cable that came from the keypad located (if you see the station from the back) at the left, turn on the base without connecting this cable. After that, I unpluged the station, reconnect the keypad cable and connect it again. Solved.
Jan 21, 2008 | Panasonic KX-TG6500 Cordless Phone
Unable to Play Messages on Base Unit
I called Panasonic on this problem....ended up sending the unit back for a free replacement. Guess thats the solution for this problem.
Dec 07, 2007 | Panasonic KX-TG6700 Cordless Phone
DeRegistering a Damaged Cordless Phone???!!!!
I have a Panasonic KX-TG6700 base unit and KX-TGA670B handsets. We had a similar problem where we were no longer able to deregister the handset using the handset itself. We wanted to be able to use that slot that the broken phone was still occupyng. The solution that we found in the manual online was to hold down the intercom button for 3 seconds until the "in use" light turned on. Then press and hold the number of the extension you want to deregister until it beeps. At this point the base unit has freed that extension.
Nov 05, 2007 | Panasonic KX-TGA600B Cordless Expansion...
Lands Phones Logo
269 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
