Question about KDS Valiant 6380iPTD-01 Notebook
Not sure I came home and my laptop was on the floor.I tried to turn it on and it acted like it didn't have enough battery power and thats also when I noticed that I had been using the wrong power cord on it.So I think that I had ran the battery all the way dead.But now I can't find the power cord for it.We have moved since then and now the cord is totally gone.I'm now wondering if I messed up the battery as well.Is there anyway I could have it checked to see if its bad? I know I need a power cord but I'm hoping I won't have to pick my husbands pockets to buy a battery.Can you help me? Thank You for any help at all,
  • 133 Answers
Yeah u can hace it cheched, just go to an electonics repair shop and tell them to check it for you NOT to repair it, they can't be able. but i think u still need a new code and battery
Posted on Mar 14, 2008
My apple ipad will not turn on
First thing is to make sure there is enough battery to power up the device. If you're sure it has battery, then you could try to do a hard reset.
Hold down the home and power buttons at the same time until the iPad completely turns off and the Apple logo appears.
Hope that helps!
Oct 31, 2013 | Apple iPad Tablets & eReaders
Laptop won't turn off
Unplug the power cord, remove the battery pack, and leave it out for a minute or so. Reinsert the battery and turn the computer on. Does it boot normally now?
Jul 25, 2013 | Sony Computers & Internet
It has power but no display
There isn't enough details, but:
Please unplug the battery (remember to disconnect the charger),
then, hold on the power button for a minute,
after that, connect the charger, and try to power on the laptop.
If it didn't work, you need to visit the technician
If it worked, disconnect the charger and connect the battery
If it worked, things are going well.
If not, the battery have problem.
Please tell us the results
Regards
Nov 21, 2011 | Computers & Internet
Briefly: laptop cant turn on Detail: After pushed power button, the note book didn't turn on. Screen kept black. Power button didn't light on(usually should). The laptop is without any sound...
The first solution I'd recommend is removing the battery and then trying to power on just with the AC adapter. Why are you afraid to remove the battery? no data will be lost.
It maybe that you have a dead motherboard or that there had been a power failure while you were putting your machine to hibernate.
Jul 03, 2011 | Computers & Internet
Hello, i have problem with my Iphone 3g 8gb. The problem is that, that after a few opening it stoped to work. It was not first time when i was opening it because wanted to make camera working well, but...
I would strongly suggest to bring it to the nearest apple store, but try these combinations as well.
1. Make sure your iPhone is connected to its charger for about 20 minutes, see if there's any reaction. The battery may be causing the problem.
2. If that's not the case, keep the phone connected to the charger, press the power button for 10 seconds, then press the home button without letting go of the power button for another 10 seconds.
3. Release the power button, and it should automatically start in DFU mode.
If this does not work, repeat all the steps above now with your USB connected to the laptop, and try restoring it with iTunes.
May 31, 2011 | Apple iPhone 3G
Gateway lt21 netbook not charging
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 13, 2010 | Gateway Computers & Internet
How do you charge a DV 1000 hp pavillion laptop?
plug in the power adapter, make sure the battery is installed firmly, let it run for 6 to 10 hours..hopefully the battery, installed under the unit, will be fresh enough to accept a recharge cycle.
got backup for that computer?
Feb 19, 2008 | HP Pavilion dv1000 Notebook
POWER
Does it work while pluged in !?
If yes, than it may be posible for the battery to be unable to store energy anymore .... change it ...
Jan 16, 2008 | Computers & Internet
KDS Valiant 6380iPTD-01 Notebook Logo
20 people viewed this question
Top KDS Computers & Internet Experts
Denise
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
