Question about Frigidaire ATF6000ES Front Load Washer
Maytag washer will fill but never starts cycle
I have a maytag washer it will fill but never starts to agatate. Timer progress's but never starts . Sometimes when it fills it will work for part of the cycle abd you can sometimes get it to spin and pump out
age of washer 12-15 years
  • 105 Answers
Motor is faulty most probably
or mayby faulty capacitor on motor
Posted on Mar 15, 2008
Maytag dependable care LAT8435AAE fills with water then quit. Has power but will not start in any cycle
You need a new timer. It's an easy repair ...
http://www.repairclinic.com/Maytag-Washing-Machine-Model-LAT8435AAE-ID-90821-Circuit-Board-Timer-Parts
Jul 19, 2011 | Maytag Dependable Clean Top MAV5920EWW Top...
Maytag washer noise during wash cycle
Check for the tighten nut to agatator is tighten. If agatator is lose it floats up and down during the wash. There is a lock ring (rubber) on the shaft that holds the agatator on, check this, if off replace thid . If the agatator is still in good shape can still use it , if not pull of and replace it. This work is't hard to do.
Jun 01, 2009 | Maytag Legacy Series Top Load Washer
Have a ge washer, filss then does not progress to
May be a bad water level switch.
Open the control panel, with a full tub of water bump the water level switch with your hand. If it starts to agitate, replace the water level switch.
Mar 20, 2009 | Maytag Performa PAV2200
Maytag washer wont start after it fills
Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
Mar 14, 2009 | Maytag Washing Machines
Maytag top loading washer won't agate. Instead it fills with water and spins, then drains, fills for the rinse and spins. Thanks Bill
Open your control panel.
Disconnect then reconnect your timer wiring harness.
If this does not correct the problem,replace the timer.
Feb 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer won't fill or agitate; only spins on cycle
sounds like you have a blown fuse. I dont have a schematic so I dont kno where you have to look to find it
Dec 30, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Top Load Washer - clanking noise when spinning
no spin cycle or agatator movement , fill cycle and pump cycle works
May 31, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Does complete cycle
When would the washer stop?
Is there water in the washer when it stops?
Feb 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Washing Machine Problem
yes it does sound like a bad timer
Nov 25, 2007 | Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
94 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
