1st you may want make sure that's not an interference engine. if it is then chances are the valves are bend in the head. changing the timing belt probably won't help then. If its not an interference head, then you would need a timing mark diagram which can be found online. be very careful that all marks are aligned. when finshed installing the timing belt, rotate engine by hand twice and re-align marks before putting the rest back together! hyundai should be able to tell u if the engine runs interference or not.
