Question about Lexmark X4270 All-in-One Multifunction Printer, Copier, Scanner, Fax
My Lexmark X4270 will send out faxes but when someone sends me a fax it rings once and no face comes through. I have been trying to figure this out for weeks. Please help. I need it for my buisness and I never recieved a manual.
  • Anonymous May 24, 2008
    won't send out the fax
NESECITO EL MANUAL EN ESPAñOL PARA LA PROGRAMACION DE ESTA
Posted on Apr 03, 2008
    President:
  • 2,072 Answers
95 percent of the time that is a phone line issue.
If there is more than one item on that line, it can be an issue.
I will throw out everything since I am not there.
A DSL or digital phone line can cause that problem. The majority of fax machines still require an analogue phone line.
Make sure that Junk Fax is off, secure fax is off, and that the ECM mode is ON. ECM is error correction mode.
Also be sure manual receive is not turned on.
I strongly suspect a phone line issue. I will explaine.
There are 3 phone line conditions that have to be correct for a fax machine to pick up. 1 is the phone line voltage, 2 is the phone line current, 3 is what is called decibel loss.
The reason you can send and call out on the line is that you manually turn "on" the phone line when you pick up the phone or when you select send on a fax, it is manually switching a relay to connect to the phone line.
When you are receiving you need the correct signal level to activate the fax. Think of how it is when your TV/VCR remote has weak batteries. You press the button and sometimes it works most of the time it doesn't. The volatge on the battery will still read 1.5 volts, but you dont have enough current draw or wattage to get the proper signal to change channels or turn the sound up and down. Same concept. But when you walk up to the TV/VCD you push the buttons it works fine. Very same concept.
Posted on Mar 14, 2008
Lexmark X4270 won't send out a fax
If you have DSL. you need a filter on the line you are trying to fax through.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 24, 2012 | Lexmark X4270 All-In-One InkJet Printer
How can I send and receive a fax from Lexmark x4270.?
You can send faxes via the operator panel, the All-In-One Center, or the fax driver.
Using the Operator Panel:
  1. Make sure your All-In-One is switched on.
  2. Load up to 30 sheets of your original document face down in the ADF (Automatic Document Feeder). Note: When you load small paper sizes, place your document in the center of the tray and adjust the paper guides to the edges of the paper.
  3. On the operator panel, press Fax.
Using the keypad you can:
  • Enter the fax number, and then press Black or Color.
  • Press Speed Dial, and then:
- Use the arrow keys to scroll through the list to find the number you want, and then press Black or Color. - Use the keypad to enter a two-digit number (viewable in the upper left of the display), and then press Black or Color.
The All-In-One scans your document and sends your fax to the number you entered.
Using the All-In-One Center:
  1. Make sure your All-In-One is attached to a computer.
  3. From your desktop, double-click the Lexmark 4200 Series All-In-One Center icon. The All-In-One Main Page appears.
  4. Under Productivity Tools, click Fax an image or document.
  5. Follow the instructions on your screen to complete the task.
For a more comprehensive guide on how to send and receive faxes using your Lexmark X4270 printer, please refer to the Lexmark X4270 User's Guide.
Aug 17, 2011 | Lexmark X4270 All-In-One InkJet Printer
I can recieve faxes but i cant send any
These articles in the Lexmark website will help you identify and fix your problem with sending faxes using your Lexmark X4270: Problems Sending a Fax to Specific Fax Machines and Main Contributing Factors to a Fax Send Failure on an Inkjet All-In-One (AIO).
I hope these information has been helpful.
Apr 14, 2011 | Lexmark X4270 All-In-One InkJet Printer
Fax machine will not let me send fax out or come in. x4270
make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility and line is working.go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 18, 2010 | Lexmark X4270 All-In-One InkJet Printer
Fax
Hi. To send fax on your X4270 printer, place the document in the feeder facing down. For additional information on how to send a fax, here's a link to the Lexmark website where you can download the User's Guide. http://bit.ly/d3t61I . Click on Publications tab on the center of the page. Choose User's Guide (Lexmark X4250, X4270). It will give some instructions, as well, on how to do other functions/features of the printer. Hope this helps.
Lexmark x4270 will send fax but won't receive
Hello sir; The better solution is replace a phone cable.
Feb 01, 2010 | Lexmark X4270 All-In-One InkJet Printer
Cant send a fax
Confirm dialing the correct fax number?
Any 0s to get an outside line, any special area codes?
What happens when you try to send a fax, can you hear a dial tone? can you hear the fax ringing? can you hear a response from the recipiant?
Jul 17, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
No dial tone on my Lexmark X4270
There are two outlets in the back where you plug in your phone line. I had the same problem when I
was plugged into the far left plug (as you are facing the front of the all in one). I switched to the other
outlet and it worked fine. But still once in a while it seems to loosen up and I have to push it back in
farther. Today I got a dialtone but could not send a fax. I got a dialtone but still wouldn't send. So I
checked the outlet and sure enough, it was just loose enough to prevent the machine from registering
the fax number, but connected enough to get a dialtone.....go figure. Good luck
Apr 10, 2009 | Lexmark X4270 All-In-One InkJet Printer
CAN'T RECIEVE FAXS
Make sure the Auto answer the button is on....
Or
Reset the printer setting to default and set the rings again to 3...and try..
Jun 25, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark
i am able to send out a fax on my lexmark x4270 all in one printer but when someone else sends me a fax i cannot receive it can
you give me a solution on this i need to be able to rec faxes
it is important in my work thank yoou
Oct 03, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-in-One Multifunction Printer, Copier, Scanner, Fax Logo
126 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
