Question about RCA PROV712 Camcorder
Rca prov712 camcorder operates when plugged into home outlet. when trying the battery it will not even turn on. battery has been on charge for 24 hours at least. is there a way to check the battery? does there have to be a tape inserted for it to work? [email protected]
3 Suggested Answers
SOURCE:
SOURCE: RCA PRO854 camcorder
maybe I would buy your camera,
yes as far as I know hi8 and 8mm are completely different cameras,
where are you and how much for the camera?
[email protected]
Posted on Oct 15, 2007
SOURCE: Can't find an audio vider cable for my RCA Prov712
I found it on-line but thank you for your reply. ANgie
Posted on May 05, 2009
I had a power surge and my sony dcr-trv350 will not trn on is it worth fixing?
Follow this procedure to troubleshoot if the camcorder will not turn on.
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony eSupport Web site.
  1. Remove the battery from the camcorder.
  2. Connect the AC power adapter to the camcorder.
  3. Plug the AC power adapter into a working electrical outlet.
  4. Attempt to turn on the camcorder.
  5. Reset the camcorder back to factory settings.
  6. NOTES:
    • If the camcorder does not operate using the AC adapter, service may be required .
    • If the camcorder does operate using the AC adapter, proceed with the steps below to troubleshoot the battery.
  7. Ensure the battery has been fully charged.
  8. Ensure the battery is properly inserted into the camcorder.
  9. Remove the AC power adapter from the camcorder.
  10. Attempt to turn on the camcorder.
  11. NOTES:
    • If the camcorder does not turn on, then the battery may need to be replaced.
Aug 14, 2009 | Sony Handycam HDR-HC7 Mini DV Digital...
Sony DCR- DVD108 switches off automatically while recording
Follow this procedure to troubleshoot if the camcorder turns off by itself.
  6. NOTES:
  11. NOTES:
    • If the problem persists using a different battery, service may be required .
Aug 13, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
May 04, 2009 | RCA PROV712 Camcorder
Jazz DV-179
YOU PEOPLE IT IS JUST THE BATTERY THAT IS IN IT!.. BECAUSE THAT BATTERY IS NOT ONLY FOR AFTER IT IS CHARGED IT ALSO WORKS TO SHOW THE DISPLAY SCREEN! BECAUSE IF YOU TAKE OUT THE BATTERY THE LIGHT STAYS ON WHILE ITS PLUGGED INTO THE COMPUTER! MY BF IS HAVING THE SAME PROBLEM TRY BUYING A NEW BATTERY!! ITS THE SOLUTION! the battery is caput!
Jul 12, 2008 | Jazz DV-179 Digital Camera
Battery does not charge
If is is only months old, contact the seller for warranty diagnostics and repair. It can only be the charger, the lead or the batteries.
Mar 04, 2018 | JVC GR-AXM18US Camcorder
Digital video camcorder
Try the most obvious solutions first; making sure the AC adapter for the camera is plugged into the camcorder-- and the plug orientation is correct if applicable, and it is in turn plugged into the wall.
Is the wall outlet working? Try another location in your home to be sure. Is the AC adapter working? If you have a battery, attach it to the camera and see if it charges. Next, look for obvious outward physical damage to the camcorder that could cause it to stop working.
The thin battery you speak of if generally just for backing up the time and date, and is not needed for operation.
The power switch on Canon models is usually a slider that goes from Manual to Auto to VCR mode. If it is dirty or wearing out, move it a small amount to one side or the other, while watching the LED power indicator. If you see it flash, or light dimly, the switch is bad.
Read the manual-- the unit may have a reset function you can access, or require a tape in it to power up. Hope these help.
Nov 18, 2007 | Canon ZR70MC Mini DV Digital Camcorder
Camcorder problem
you need a new battery
Nov 06, 2007 | JVC COMPACT VHS-C CAMCORDER
RCA prov712 battery will only last 5 minutes
Be sure to charge for AT LEAST 14 hours on the new battery, even if the charger light goes out - it's still trickle charging. It's normal for most camcorders to auto-shut off after 5 minutes, if it's not recording. But if your batt light comes on, the problem is probably with the battery.
Dec 19, 2006 | RCA PROV712 Camcorder
Video Cameras Logo
77 people viewed this question
Top RCA Video Cameras Experts
Marvin
Marvin
Lawrence Oravetz
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
