Touch screen half loading only
I have a touch screen monitor and only the top half of the screen loads ok. The bottom half is a white haze. The touch still works on the whole screen. The same half screen issue still happens when the touch monitor starts independantly of the PC. Any ideas? Connecting to a normal CRT monitor works fine.
You mean half of the screen is always white, or it's a noisy white? Even during boot screens? Does the OSD (for screen controls) show on that part of the screen?) A little detail would help determine whether it was the screen or your video card or its driver. The driver one is the easiest to fix of course.
Posted on Mar 15, 2008
    Sergeant:
    Champion:
  • 326 Answers
Try uninstalling the TS from the control panel-system-devices (hardware).
Reboot and reinstall the drivers when asked.
The driver must match the OS.
The TS may be defective, does it operate proper on another Pc?
    New Friend:
    Problem Solver:
  • 5 Answers
So many things did affect the display of TS, one may be you use driver to intall TS on your system, driver may be corrupt, or some thing pressure affects the display of TS, try it in another system apart from the one you are using if everything is fine, this means it is from your system, if not it will be from TS itself, so best suggestion is to find technician nearest to check for you
Hope it will solve your problem.
Thanks
Yarima
Posted on Mar 18, 2008
I had top screen replaced on my Galaxy S4 SCH-I545. Now the bottom half of my touch screen does not work. What could have caused this?
Sounds like your digitizer wasn't properly connected or were given a defective one. Some connections have a cam-locks, some have a wedge style which you can fail to get the ribbon in far enough and some have a socket connection which either connect or don't. If a shop replaced it, they should have tested it which could indicate a defective part or a connection came apart. Was it dropped? If you or a friend replaced it, recheck all connections, especially those going to the digitizer.
Oct 06, 2014 | Samsung SCH-I545 Galaxy S4 16GB Verizon...
IPod touch-1.1.4 / 8gb ...when I log in to facebook,I can only see the top 1/2 of my homepage & the bottom half says it is loading but really is not. So,when I tap on the main menu button (on the screen)...
I had issues with my iPod touch in a similar situation, for me it all had to do with the WiFi component inside. It got damaged or fried from the over usage. It would load tiny bits of information on pretty much anything internet related but then die out trying to load forever. I would have to turn off wifi and try again. I had to take into apple and get the piece replaced, by which I firgured it was time to upgrade.
I RECOMMEND you try this first:
1. Uninstall Facebook app and re-install it.
  • Press and hold the "Home" button untill apps are shaking
  • Touch the "X" on the facebook app you want to uninstall
  • Re-download and install app from app store.
2. Update the iPod version
  • Settings
  • General
  • Software Update
3. Take into apple support get the wifi component replaced
or
4. Upgrade to a newer device :/
hope it helps.
May 29, 2014 | Apple iPod touch
Bottom Half of Laptop Screen quickly fades to white!
1. you can replace it with a new screen. (expensive) 2. have a technician to repair the board of the screen, the cable, the IC's, etc. (save you money but the length of repair is very long. maybe it will take a week or two.)
your choice.
May 24, 2010 | Dell Studio 1737 Laptop
Touch Screen on GE profile top load washer is not responding.
There is probably a problem with one of the following:
* electronic control board
* touchpad
Feb 24, 2010 | GE Profile WPRE6100G Top Load Washer
Unable to unlock my phone
Your device might have a problem in the touch screen.
In iPhone 2G the touch panel and the LCD screen are one unit that cannot be separated.
You shoud try to replace the iPhone screen with a new one and the problem should be fixed.
Aug 28, 2009 | Apple iPhone Smartphone
Ds top screen turns white then shuts off.
the cables need to be inserted Fully And squarely/evenly.
Also ensure The Tabs are locked Down correctly.
If none of this Works, you may have a blown On-Board Fuse.
I believe these Are Known As F1 And F2.
Mike @ Compurepair.
Aug 19, 2009 | Nintendo DS Console
Monitor/tv output with a pink haze - Help
Try to reconfigure the settings of your laptop then load its default setting to display its normal view.
Thanks
Aug 06, 2009 | Acer Extensa 5620-4677 Notebook
It's all black with a white apple sign
ok try reseting it and no reseting the ipod dose not erase it hold the power and home button at the same time for at least 10 sec or untill the ipodreset it should sjut off and a few sec later you should see the apple logo hope this helps
May 22, 2009 | Apple iPod touch
Computers & Internet Logo
110 people viewed this question
David Payne
David Payne
