Question about Motorola Mobility W220 Cellular Phone
Charging problem my does not charge properly. When on charge it shows that it's charging but when removing charger the battery i still low. Near the battery icon it shows a small bell alert want to remove it. I've got once a notice saying " under temperature"
    Problem Solver:
  • 5 Answers
Try to change your baterry
Posted on Mar 14, 2008
Sony xperia miro st.23i is showing charges but not charging I have try so many different charger but still not charging he keeping showing charging but if you removing the charger showing low battery and I...
These are my suggestions.
Possible issues.
The USB port on the phone is faulty and not making proper contact.
The battery charger you are using is not of sufficient current to charge the battery fast enough.
The charger/regulator circuit in the phone may be faulty. unfortunately it is not user serviceable.Have the phone repaired by a qualified technician.
Possible solutions
You may be able to purchase an external battery charger and use that then insert the battery in the phone.
Mar 26, 2015 | Sony Cell Phones
I put new batteries in my Cobra 2-way radios and charged them for 24 hours. Still shows "low battery" when I turn them on.
Check your charger and battery contacts. Cleaning battery contacts on the radio and charger with a pencil eraser will remove dust, dirt, debris, and hand oil which may cause the battery to charge poorly. Secondly, you might want to check that your charger itself is working properly. If you have a second known good radio you might try charging it on the same charger.
Best regards.
Sep 28, 2014 | Cobra Radio Communications
My LG RD 6100 is showing charging but it is not actually charging.After removing charger it is showing that recharge the battery
It is best to get the charger checked with another phone as to confirm the case. In some cases the low regulation within the phone can efffect the charging circuit.
Also cross check the battery as if the battery is weak or had been not charged initially properly then it seems a suspect.
Dec 29, 2011 | Cell Phones
Max mq340 charging show but not save
As a general rule, re-chargeable battery can be recharged 300 times. This means that after one year or thereabouts, the battery will not hold the charge.
1 Look up battery replacement shops in your city. (Use Yellow pages or Google).
2 Take the old battery and the phone to the shop. Buy an equivalent new battery.
3 If there is no battery shop near you, try Amazon.com to find someone selling the battery (NOTE: Give brand name model name and battery part number in your request).
Nov 25, 2011 | Cars & Trucks
I inherited the charger w/no manual - as I've
I can find no manual on line for the charger but the basic & most important things I can share with you.
On the charger should be your On & Off switch, possibly 6 volts / 12 volts switch, (you want 12 Volt) some have a meter to show how much amp draw is taking place as it is charging and you'll have to determine that from observation.
MOST important parts: It is best to disconnect the battery you are charging, at least the Negative post. This will speed up the charge process & prevent any mishaps with the electrical system on the vehicle. I prefer the battery completely removed & placed on an insulated material, plastic, wood, rubber, to prevent battery drain by sitting on concrete or the ground.
If you can check the battery first for swelling/cracked case=don't charge! Frozen inside=don't charge! Thaw first. The fumes from batteries charging are explosive & no sparks, or flames should be anywhere near. Upon reinstalling, Negative wire is always last to connect & be sure that everything inside as far as lights & ignition switch are off to prevent excessive sparking when you connect the final cable.
Charging & connecting. I prefer to test unknowns such as the connecting cables to make sure they are what they say they are. You need a multimeter for this but for now, I am expecting they are marked properly for this instruction. You need a Positive clamp , this one usually has Red handles, to connect to the Positive terminal of the battery (marked POS or +) The other cable, generally Black, connects to the Negative terminal (marked NEG or - ) and provides the ground to complete the circuit.
Make sure connections from the charger to the battery are all clean & well attached, then turn ON the charger. This will prevent sparks near the battery. Be sure to turn off the charger once charging is completed, then disconnect the cables from the battery. The unit you are charging with should give you some indication about when you're charged 100%, but these are the basics of charging a low battery. If by chance your charger shuts down on you & stops charging immediately, you either have the terminals reversed, or a shorted battery. good luck
Feb 06, 2010 | 2006 Ford Expedition
Low Battery, Connected car charger, now is dead
May be the battery won't have charge, keep 1 or 2 hrs continues charges, and if it is not working then you have to replace the battery set full.
Jul 04, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Battery charging
All lead-acid batteries contain highly corrosive sulfuric acid, generate explosive gases and have warning labels which should be observed closely. For best results, charge the battery as soon as you know it is discharged. To charge your battery, follow these steps and important safety tips: Before Charging: 1) Read the charger manufacturer's instructions. 2) Put on protective eyewear, rubber gloves, work clothes and remove all jewelry. 3) Place the battery in a well ventilated area. 4) Don't charge a frozen battery. Allow the battery to warm to about 60?F before charging. 5) If applicable, remove the vent caps and check the battery's water level and, if low, add distilled water to cover the tops of the plates. Do not overfill. 6) To determine if the battery needs to be charged, test it with a hydrometer to determine its specific gravity and/or with a voltmeter to determine its state of charge. 7) If applicable, reinstall vent caps before charging. 8) While the charger is unplugged, connect the leads to the proper battery terminals. Note: For side-post and studded batteries, we recommend that you use adapters to insure adequate contact. For additional information regarding adapters, contact Interstate Batteries. 9) Set the charger to the proper settings for your battery, e.g. 6 volts vs. 12 volts, low-maintenance vs. sealed, standard automotive vs. deep cycle. 10) Plug in and turn on the charger. 11) Don't wiggle the connections to check contact while the charger is turned on or plugged in. 12) Choose the lowest amperage setting initially. Once the charger is on and the battery is charging, you may want to choose a higher amp setting to reduce charge time. During Charging: 1) Keep the vent caps on. 2) Don't allow smoking, open flames or sparks near the battery. 3) Don't allow the battery to become hot to the touch. After Charging: 1) Immediately after the battery is fully charged, turn off and unplug the charger. Continuing to charge a fully charged battery will severely damage the internal plates and shorten battery life. 2) Disconnect the leads from the battery.
Nov 20, 2008 | 2004 Harley Davidson FXDL - FXDLI Dyna Low...
I.Mate -JAQ charging problem
my i mate jaq charging jak iss broken i need charging jak jumoers
Aug 27, 2008 | i-mate JAQ Pocket PC
Charging problem
your battry is either damaged or nonbranded
Change and use only nokia original battery and mobile charger
Jul 04, 2008 | Nokia 6681 Cellular Phone
V262 constantly beeps "low battery" alert
your battery might need to be changed. even if it has a full charger it might not be able to properly charge you phone.
try a new battery.
Mar 06, 2008 | Motorola Mobility V262
Motorola Mobility W220 Cellular Phone Logo
76 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
