Back to:
Tags:
Fax Machines
Generic problem for all Fax Machines
Brother Fax T78 wont 'ring'
posted by tracey42 on Mar 14, 2008
Hi
Today the tax.telephone machine will not 'ring' when an incoming telephone call or fax is coming in.
I can use the machine to dial and fax out ok.
I have received a new BT reuter for the Internet today, could this be the problem.
Thanks
Comment by tracey42, posted on Mar 14, 2008
Hi
Thank you very much.
I have now managed to solve the problem, I had it wired up wrong.
Thanks agin for the speedy reply
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
tryit
Rank:Guru Guru
Rating: 88%, 686 votes
Yes. try bypassing the router by plugging your phone directly into the phone jack, and have someone send you a test fax.
What happens it even now days, the majority of fax machines still use analogue phone lines, and the digital signal will mess them up, mostly because the digital lines have less power and current, and do not signal the recieve mode to switch on.
Very common occurance. Glad you mentioned the router or I would have sent you down a long winding path LOL.
You are suffering a low signal issue.
The reason you can call out is that you are manually activating the phone or fax when you remove the receiver. When you receive, it taked the proper signal strength to activate the fax modem.
Comment by tryit, posted on Mar 14, 2008
Just curious, was the phone line plugged into the extension or phone jack???
Your welcome , glad to have been able to help.
Rating Locked! (?) tracey42 has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Brother Fax T78 wont 'ring':
I don't want to Accept this solution
Can you Help with these Fax Machines problems?
Brother IntelliFAX 4100 Plain Paper Laser...
There is a line on the side of the paper that makes it...
Fax Machines
I was sent a form with directions to open with Adobe. I...
Fax Machines
need to replace a broken gear in paper shredder motor
Panasonic KX-FHD331 Plain Paper Thermal...
Need to get a report of sent faxes for the month of June...
Fax Machines
the ratio is stuck on 145%. The only way I can get it off...
Loading problems.
Repair Service
Find Fax Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
