Picture problem hey buddy! pls. help me with my sony tv. model no. kv-19apr2, it has sound but don't have picture, only yellow horizontal line... pls. tell me what do and what to check, i don't have oscilloscope only vom, aside from vertical IC, and resistors in vertical section what is the possible defective parts? pls. i need your expertise...
    Scholar:
  • 104 Answers
Aside from the parts you mentioned check the vertical connection to the yoke (usually yellow and green wires), it may have a cracked solder joint or it could be burned. Also check the yoke for a broken vertical winding.
If the line is yellow with no other colors you may also have a bad color gun or drive transistor. If all color guns are working the line should be white.
Posted on Mar 14, 2008
SOURCE:
Why are green horizontal lines are appearing, too much yellow colour and green light blinking red?
These horizontal lines are vertical flyback lines and would indicate
one or more of the tubes cathode drive circuits are defective.
As the picture is predominantly yellow this would indicate excessive drive to red and green guns. Check the red and green video output stages especialy any clamping diodes.regards from Vintie
Sep 19, 2013 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Retrace horizontal line
It seems to be some line frequency interference is effecting the picture.
Jun 07, 2013 | Televison & Video
I resolder the vertical Ic and surrounding area for Sony KV-27S26 but still no picture; only sound. Any suggestions? Thanks.
no picture at all?? try to find at supply section resistor 2.2ohm and also pls check the horizontal output ic
Jun 05, 2009 | Sony KV-27S26 27" TV
Have sound but no picture
some time it works mean the tv having dry joint ( loose connection ) inside the PCB pls resolder all parts spacialy system control IC horizontal/ vertical section and power supply board as well . I think no any other issue in this tv pls resolder all part as much as possible
Jan 08, 2009 | Sony KV-32S45 32" TV
Sony KV-27S42 no sound and audio blinks four times
+13 & -13 requires for Vertical Deflection IC and produced by Flyback Transformer, these volts will be produced IF Horizontal deflection circuit works properly. so try to check H-Out Transistor and its necessary volts / signal. Pls also mention correct Model Number to provide you more help.
Aug 13, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony tv model no. KV - 19 APR 2
This is for a different model, but I had thin horizontal lines in red and had to adjust the tube for red. You may have a similar adjustment on your set.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Aug 01, 2008 | Sony KP-48V80 48" Rear Projection...
Sony kv-32fs120
The 6 blinks mean no horizontal. Check the horizontal circuitry. I'll look up your specific model later and post more details.
Dan
May 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony tv no picture only horizontal line
The probable defective part is the vertical IC. If changing that does not resolve the problem, check the capacitors in the same circuit. Also, check for the proper voltages at the vertical IC. If the IC is not being fed its power, it won't work either. I don't have a listing for your specific model. If you can post the vertical IC part number (LA7837 for example), I can list the voltages per pin.
Dan
Apr 09, 2008 | Televison & Video
Sony tv there is sound but no picture only horizontal line
hi there, one horizontal line means a vertical section prob., check some resistor with low value and a defective diode, possible ic part is defective. do some test and check up. ty
Feb 25, 2008 | Sharp 27C-240 27" TV
Televison & Video Logo
127 people viewed this question
Top Televison & Video Experts
Ekse
