Question about Candy CDC266 Dryer
Themostat reset button- where is it and what does it look like o Candy nova 266uk
Saw you fantastic answer to some one else.... now need to know where I look for thermo things and what they look like....to find reset button and see if that makes it work ...Please help[ thanks willow
ON MY MODEL THERE WAS NO RESET BUTTON SO NEEDED A REPLACEMENT PART.
Posted on Jun 11, 2008
Hi I am having the same problems, the filter light came on so I cleaned the filter and condenser, but the light won't go off, the dryer works fine other than that, exept theres no heat but the book says there won't be any heat untill the light goes off. any ideas thanks Christine
How to replace thermostat on holden nova 7a-fe
drain coolant
remove themostat housing (2 screws)
put in new. not backwards,and bleed hole up.
use the proper gasket and sealant.
coolant back
and burp three times so baby dont cry.
Jun 24, 2014 | 1990 Holden Nova
Political party of ronald reagan
valentine day is months away
plenty of time for you to type Ronald Regan in your browser page search bar to get all of his details
Dec 03, 2017 | Health & Beauty
The start button on Candy Nova CDV-262 won't stay in.
there seem to be a bad connection try sliding a thin knife next to the switch and see if that works
Feb 17, 2013 | Dryers
Candy nova cdv 262, heat works but drum does not revolve
Hi dodgedrums...
I can answer your question, but you will need to resubmit your question if you need help in the repair.
I have never worked on a Candy machine so therefore I cannot help with the dissassembly of the dryer for repair
Your problem is most likely to be a broken belt, or a faulty motor...normally even a novice mechanic can repair with the proper advise which you will normally find here at Fixya.
Please take time to rate me
Jul 20, 2011 | Candy CDV262 Dryer
Have a craftsman 10 inch table saw model #137.218250, serial #RCW3145. When we attempt to cut plywood or a 2X4 length ways, the motor dies a number of times. Most of the time the reset button will not...
sounds like the reset button needs replaced. Also when is the last time you cleaned the motor area?? When you reset the button is the motor "hot" to the touch and if so could also be a motor problem,, try the reset first
Aug 26, 2010 | Saws
NO HEAT ... and filter light stays on ... HELP/ADVICE NEEDED ... AM DISTRESSED .....
Most likely possibilities on heating problem. All are listed from most likely to least likely.
1. Thermal Fuse (Located near blower housing)
2. Thermostat
3. Thermostor
4. Heating Element
5. Ignitor (Gas Dryers Only)
All parts can be tested with an ohm meter for continuity. Most parts are under $20 with exceptions for the heating element and ignitor. Considering that you had a technician come out to your house, charge would be roughly $120-200. A dryer's life span is usually about 10 years; give or take. For a diagram to locate all parts within your dryer, refer to www3.sears.com with the model number of your dryer. Model number found on the side panel when you open the door of the unit. If you need more assistance, just comment and I will get back on later today or tomorrow.
Mar 14, 2008 | Dryers
Location of reset button on model 44110
There is a little reset button right under DAY/TIME. You will need a pencil/pen tip to press this little switch in to reset your unit.
Hope this helps.
Good luck.
Mac =)
Feb 09, 2008 | Hunter Fan Company 5/1/1 Programmable...
Candy CDC266 Dryer Logo
544 people viewed this question
Top Candy Dryers Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Marvin
Marvin
Are you a Candy Dryer Expert? Answer questions, earn points and help others
