Question about EliteGroup ECS 945GCT-M/1333 Motherboard - v3.0, Intel 945GC, Socket 775, MicroATX, Audio, Video, PCI Express
Bios problem my computer not boot correctly the error display intel s2945g chipset svga bios.... DECOMPILATION OR DISASSEMBLY PROHIBITED.. ill try to reset, battery, but its repeat and repeat.. how can i fix it
  • jayanmp Aug 28, 2008
    my PC is not booting and iam not able to go bios setting also.i tried resting the bios still it giving the message
    please help me
    jayan
    New Friend:
His has worked for me: Turn off computer. Unplug power cord from computer. Hold power button in for 15-20 seconds. Remove motherboard battery and let sit for 15+ minutes. Replace battery. Plug in power cord. Turn on computer. Enter setup when prompted and set the date/time. If prompted, in Maintenance - reset defaults. If problem recurs, as it has with me just in the last few days, the motherboard battery probably needs replacing. Which I am going to do shortly, after going out and buying one.
Posted on May 18, 2012
  • 53 Answers
Dear sir/madam
First u see all the connections are connected to board or not including fan's   .
In bios settings u select the option 'Load default settings' and save and exit.
Was this soultion helpful?show ur appericiation by rating it.
Posted on Mar 17, 2008
SOURCE:
Processor: Core 2 Duo RAM : 2 gb Purchased on : july 2008 Supllier : HCL India OS : XP , SP2 Last Night I Installed XP SP2 . Today I restart my computer . it shown following Text : Intel R 82945...
Your computer is not taking the "next" step, i.e., reading your copy of Windows from your disk-drive, and starting to run Windows.
So, check that the "power" and "data" cables are correctly connected from your power-supply and motherboard to your disk-drive.
Also, it's possible that your disk-drive has "died".
Take the computer to a qualified computer technician, for more trouble-shooting.
Oct 22, 2010 | Computers & Internet
Cant do anything my computer wont go to the os
What you need to do my friend is remove the CMOS battery, then remove the power cord from the computer. Press the power button on the front of the pc, you might at this point see a temporary flash of the power LED (at this point the cmos /bios is now cleared and reloaded with the defaults.
Next, put the battery back in and then the power and boot to the bios. Just reload all settings as needed and you should be back in business!!!
Sep 19, 2009 | Dell Dimension 2400 PC Desktop
Bios Error Message
With the system off, open the side cover and re-seat the RAM. You may have one module that is bad.
Second, press F2 as soon as you see the Dell screen and see if you can get into the BIOS setup. Post back with the results please.
Mar 20, 2009 | Dell Dimension 3100 PC Desktop
Windows XP won't boot
sorry for my bad english
the problem may be your hardisk data cable.change your hardisk data cable.and also try this, remove ram memory and clean it and restore.
Dec 16, 2008 | Dell Dimension 3100 PC Desktop
Bios problem
Are you using the ON BOARD video output? or are you using an external video card?
Was the computer working and you installed SOFTWARE to enhance something?
I will assume the you know how to get into the BIOS setup to tell your cpu the diffenrnt configurations?!!
1st)Replace the VGA video card with anything...does not have to be FANCY, FANCE. and reboot...same problem? not the same problem?
2nd) take everything out of the desktop except memory and boot up.
continue adding hardware (one at a time) and reboot. If the message comes up..AFTER you've installed a hardware....that is the problem.
Nov 29, 2008 | Intel Motherboard
DELL Optiplex GX280 PC don't boot
This is what I did & it worked to solve this error message on my Dell Optiples GX-280. Intel(r) Grantsdale-G PCI Accelerated SVGA BIOS
Build Number: 3314 PC Dev 04/12/2004 17:02:24
Copyright (C) 2000-2003 Intel Corp. All rights reserved. I uninstalled all the ram except for one chip. I rebooted the system to to see if the one chip worked (ready to repeat the process if it didn't & thinking maybe it could also have a bad ram slot). The 1st chip worked & it went right into bios(clapping hands!!!) I then turned off & on the system...each time adding a new ram chip to see if any were bad, but to my surprise...none were...they all worked just fine after that(clapping hands & shaking head!!!)! Just to let you know...I had 4 sticks of DDR-2 4200 in it when I did all this...I know I know...it takes DDR-3200, but it will just clock it down to 3200 & still works just fine...trust me. Computer works fine now with no error messages what so ever...hope that helps~; )
May 11, 2008 | Dell Optiplex GX280 (99301) Motherboard
EliteGroup ECS 945GCT-M/1333 Motherboard - v3.0, Intel 945GC, Socket 775, MicroATX, Audio, Video, PCI Express Logo
641 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
