Question about Kenmore 16372 / 16374 / 16379 Built-in Dishwasher
Kenmore dishwasher touchpads
OK, I think the model umber is 665 . 16634000 The 665 is inked on the label, and the following 8 numbers are stamped in but are not lined up well and falling between the model and serial number prompts.
There is a "Type" 280-1 also, if that is helpful.
Are touchpads relatively easy to replace for the mechanically-challenged?
Thanks a million. much appreciated.
  • Anonymous Mar 31, 2008
    I contacted sears and they are not able to find that model number either...how can you get help for your problem if they don't even know their own models?
  • 4,889 Answers
Yes you can surely do it yourself..its just unplugging a few wires remove the old one and just install the new one..
I couldn't find the model number you have specified, but you can give these guys a call and specify ask for a new touchpad for kenmore 16372. They will ship it out for you.. I advise you call their toll free number that you can find on their site so that you can get it done real quick.. http://www.laundryparts.com/sunshop/index.php?action=category&id=bestsellers
Posted on Mar 14, 2008
Is it possible to get new upper and lower racks for this model - if so what is the cost and how do i order?
Hello Adriana;
My name is Peter. I am a retired field service appliance technician.
The model number you provided does not sound like a model number. Your model number is located on a label on the face of the dishwasher after you open the door or on the side of the door.
Go into the following website and put in your model number. You will get diagrams, part numbers and cost.
Record the part number and search the internet for a better price. Even discontinued items are available on the internet.
Water Filters Lawn Garden Appliance Parts
Mar 23, 2016 | Kenmore Dishwashers
Kenmore dishwasher clean button constantly flashing ,washer has been unplugged ???maybe reset itself did not work. 2 yrs old
please follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 09, 2013 | Dishwashers
Why won't my Kenmore dishwasher display work properly?
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Regency problems
If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board
The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been ruled out, the main control board might need to be replaced.
Jun 14, 2013 | Maytag Dishwashers
Upper rack axle for kenmore elite
Your model number is needed for more information.
It's usually stamped on a small tag in a visible location on your appliance.
Dishwasher- Inside the doorjamb on the top, left or right. On the door edge top left or right. Portable models on the back.
Mar 22, 2010 | Kenmore Dishwashers
Where can I find the model number of my kenmore dishwasher
There should be a label located on the inner lip of the dishwasher where the door makes contact when closed. The label should have the model and serial number. If the label is missing you might find one on the unit if you pull it from the cabinet.
Nov 18, 2009 | Kenmore Dishwashers
How do i find the model number for kenmore dishwasher
Model Number Locator Tips
1. A zero in the model number might be the letter O.
2. A lower case L might be a 1.
3. Some models have 3 digits and a period first, like this 555.66666666
Look for an aluminum tag--or a silver and white adhesive label in the locations illustrated below. The model number may be printed or stamped onto the tag and may be printed in different type sizes. NOTE: There may be partial model numbers on marketing stickers or in the owner's manual. These are often incomplete. For best results use the model number from the tag.
Jun 21, 2009 | Kenmore 24 in. 16182 / 16189 Built-in...
I dont how to fix it without manual. i neeed help
To get assembly instructions go to;
http://www.childcraftindustries.com/childcraft/assistance/
and enter your crib model number. The number you gave does not look correct.
Information from Child Craft Industries
MODEL NUMBER VERIFICATION:
Crib model numbers are stamped directly on the crib in black ink on the underneath bottom edge of one of the crib sides, headboard, footboard or stamped on the label attached to the inside face of footboard bottom rail.
On other Child Craft and/or Legacy furniture the model number will be stamped in black ink on the back panel.
Often "47167" and "01700291" are mistaken for model numbers. These numbers are NOT valid model numbers.
Apr 08, 2009 | Babys Dream Baby Gear
Inching closer on Kenmore dishwasher touchpad
You can try
www.appliancepartspros.com/
appliancehelp.com
http://www.partselect.com.
These sites also include how to guides that ship in along with the parts so it would just be a piece of cake!
Sai.
Mar 15, 2008 | Kenmore 16372 / 16374 / 16379 Built-in...
Kenmore touchpads
you can find it on Appliance Parts.com, Appliance Pros.com Discount Appliance Parts and Appliance Repair Parts.
The model you included isn't actually the model number. The data tag is somewhere near the door gasket, so include that for sure so that i can directly guide you to the purchase zone..
Mar 13, 2008 | Kenmore 16372 / 16374 / 16379 Built-in...
Kenmore 16372 / 16374 / 16379 Built-in Dishwasher Logo
803 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
