Bose 3 2 1 GSX System Logo
Posted on Mar 29, 2010
How is wired de DB9 pinout conection for the module to speakers in the GS bose media System?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2211
Points
Did you find the solution???
  • Anonymous Apr 16, 2010
    Female DE9
    1-2 Pin Driver One (Speaker RIght)
    6-7 Pin Driver Two (Speaker RIght)
    5-4 Pin Driver One (Speaker Left)
    9-8 Pin Driver Two (Speaker Left)
    Pin 3 Is not used
  • nige1h May 09, 2011
    For correct phasing, which pairs of pins are for the "positive" or "hot" connections?
Anonymous
Level 1:
New Friend:
  • Posted on Jul 22, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2211
Points
Power surge now my bose 321 make a beep sound
Need a 9pin squematic for Bose cinemate 318942-1100
I found a forum post on All About Circuits where a user was trying to find the pinout for a Bose CineMate DB9 connector. According to one of the replies, you can connect the tip, ring, and sleeve to pins 2, 3, and 5 respectively. However, you will not be able to use a remote to turn on and off, mute, or adjust volume without the input adapter module1.
2helpful
I want to connect my Bose ps28 iii to another reciever. How and what do I need to make this possible. If I run a av left right to the unit will the reciever turn the unit (bose woofer) on.
The media center plug is wired to carry your left/right signal for front and rear along with reference and turn on voltage. Here's a link to the media center cable pinout images. If you have the connector you can pigtail in your high level inputs (speaker out from the amp you want to use to the corresponding pins. However, I can't guarantee this will work. Bose makes these cables proprietary for a reason... to make money. If hillrods like you and I can easily hack their stuff then they wouldn't be able to overcharge for their goodies. Here's the pinout link anyway. Good luck! http://www.google.com/patents/EP1605637A2?cl=en
2helpful
HOW CAN I CONECT THE BOSE TO MY YAMAHA AMP THE ONLY WAY TO CONECT THE BOSE IS TO BANANA INPUTS ON MY AMP AND THEY ARE FRONT SPEAKERS BUT THE AMP HAS A SUB OUTPUT
To enable the full potential of a SUB for Yamaha DSP A5 ,
you need to have
a separate amplifier for your Bose Acoustimass System.
The SUB out should be connected to an active subwoofer.
How to put together a double cube bose speaker
The Bose speakers with the cubes and bass module are all interconnected with a proprietary cable available from Bose, if lost you get a replacement by called 1-800-444-BOSE.
When you connect the speakers all wires run from the receiver to the base module first, then out to each of the speakers. All terminals on the bass module are labeled.
The Bose cubes are all identical and can be used in the front or back positions.
Try to keep them at ear level or aimed at the listening position for best sound.
2helpful
When I plug in my cinemate system the green light on the interface module won't turn on and power up. It only stays red and doesn't respond to the remote. I have unplugged and reset the system and check...
probablemente no este ccodificado el control remoto asegurate de poner pilas nuevas y trata otra vez checa los cables que van al modulo interfaz ya que pueden estar quebrados o sustituyelos o bien el sistema de interfaz no funciona o llevalo al centro de reparacion bose
1helpful
2answers
Bose Lifestyle 50 - connection to a non-bose amplifier
The 2 system are completely different your is low level input and its is having only 2 input L and R when those signal they get inside your sub it process through an DSP ( Digital Signal Processor ) and become 5 output to yours satellite cube speakers
The AM6 or 10 are high level input connected direct to any output of any AMP from those signal they convert down to low frequency for sub woofer
Bose 321
3 audio inputs (3 analog, 3 coaxial digital, 1 optical digital)
2 video pass-through inputs (composite and S-video)
Video output for TV (composite, S-video, and component)
Media center • 3 1/4"H x 13 3/4"W x 10"D • (8.3 x 34.9 x 25.4 cm) • 6.7 lbs. (3 kg)
Remote control • 1 1/8"H x 2 1/2"W x 9"D • (3 x 6.5 x 22.9 cm)
Gemstone speakers • 2 1/2"H x 5 1/2"W x 4 1/8"D • (6.4 x 14 x 10.5 cm) • 1 lb. (.45 kg) each
Acoustimass module • 14 1/2"H x 8 3/4"W x 19 1/8"D • (36.7 x 22.2 x 48.5 cm) • 23.3 lbs. (10.6 kg)
Total shipping weight • 44 lbs. (20 kg)
gray_hr.gif What's In the Box • Acoustimass® module • Media center • 2 speakers • 3·2·1 universal remote control • Setup DVD • Antenna stand • Stereo cable • Video cable • Speaker cable • Module cable • Rubber feet for Acoustimass® module • Rubber feet for speakers • Batteries • AM antenna • FM antenna • 120V power cord • Quick setup guidepls rate !!!!!!
1helpful
2answers
BOSE 901 ACTIVE EQUALIZER
i, trying to hook up a powered subwoofer to my hafler dh 110 and dh 500 running a bose 901 series v active equalizer and series v 901s any info would be appreciated
Av3 2 1GS Media center
Yes, Try Media Receive Ltd - 0845 20 20 118
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
