Inside the freezer remove the back panel. At the bottom of the evaporator coil you will see a hole about a 1/2 " diameter. This is the drain if it is frozen over use warm water and then clean out the drain hose being careful not to punture a hole thru it. You can get a diagram at www.appliancehelponline.com by entering your model # into the parts search block.
