Question about Toshiba Satellite A105-S4004 Notebook
Display Problem I have a Toshiba A105-S4004 and the image\Picture quality is bad. I have updated the driver , changed the display settings but still the picture quality is very bad. Is there anything that i can do?
    Scholar:
  • 105 Answers
Try connecting an external monitor if this also shows a "bad" picture then probably the graphics chip on the laptop is faulty.
Posted on Mar 15, 2008
Toshiba Satellite A105 Display
If you've replaced the LCD Panel already, then chances are good, the failing part may be the FLR inverter. It's a thin little chip about 3 or 4 inches in length that bridges the connection between the LCD and the motherboard. It's location varies from computer to computer though, so you may have to check with manufacturer documentation. They're not too terribly expensive to replace though, much cheaper than the LCD panel, anyways.
May 09, 2009 | Toshiba Satellite A105-S4004 Notebook
MODEL TOSHIBA TRCHER A5 DISPLAY PROBLEM IT IDICATING FOUER BEEP SOUND S
You either have a bad stick of RAM or a bad motherboard.
You can try swapping the RAM , it is in an access port on the bottom of the computer.
If that doesnt do it , you need a new motherboard. Best bet in that case is to upgrade.
Mar 02, 2009 | Toshiba Satellite A105-S4004 Notebook
I have no sound driver on my satellite a105 s4004
right click my computer
properties
hardware and then display
scroll down till you see your audio click it then update driver choose option to selective driver from a list click your driver
if you don't know the driver just click automatically detect
if that don't help let me know
Jan 17, 2009 | Toshiba Satellite A100-S8111TD Notebook
I have a satellite a105 s2716 and the lcd only works when in dual display mode... also seems to be a conflict with using dual displays, resulting in reboot cycle
Hi, the conflict that your equipment presents does not refer to the driver that this installing, refers to a fault of hardware which does not allow that the card of video give image to the LCD, and by the same situation when forza the video the equipment it is restarted, the solution to your problem is to replace the card of video.
Dec 05, 2008 | Toshiba Satellite A105-S4004 Notebook
QuickCam Express, blurry, snowy picture...sometimes the picture is totally shaded red
Many factors can affect the image quality of your pictures. If you are experiencing blurry images, please try adjusting the focus ring located around the lens.
This will allow you to focus the camera image on objects at different distances.
Also, make sure there is good lighting. Improving the lighting conditions can improve the image quality considerably.
Connection Issues:
If the image quality is poor while transmitting video over the Internet using video enabled programs such as MSN Messenger, Yahoo! or AOL Instant Messenger, your connection speed to the Internet directly affects the image quality of the transmitted video.
Corporate LAN, DSL/cable modem connections will result in the best image quality experience, while dial-up connections may result in choppy and overall poor quality because of the slower connection speed.
Even broadband connections such as DSL/cable modem may experience choppy video at times because of Internet traffic or slow upload speeds.
If the image appears clearly in the camera software, most likely your Internet connection may be responsible for the poor image quality in your video program.
Changing Display Adapter Settings:
If you are still experiencing a distorted, fuzzy or grainy image, you may need to change the settings for your display adapter.
For optimal image quality, please make sure the video display adapter is set to display at least 16-bit high color or higher.
To change the color palette please perform the following steps:
Click on "Start," "Settings," and "Control Panel."
Double-click on the Display icon.
Click on the tab labeled Settings.
In the dialog box labeled Color Palette, verify the video mode is set to 16-bit (high color) or 24-bit (true color).
Also, check with the manufacturer of the video card for updated video drivers.
Low Light Boost:
If you cannot do anything to improve the lighting situation, some Logitech video cameras have an option for "Low Light Boost."
If there is an option for "Low Light Boost," try enabling the "Low Light Boost" in the QuickCam software.
To do this:
Open the QuickCam software.
At the bottom right hand corner of the camera image box, click on the arrow next to the QuickCam icon.
Choose "Advanced Camera Settings".
Under the Image Enhancement box, place a check mark in the "Low Light Boost" option.
If that does not improve the image quality, try adjusting the other image settings, such as contrast, saturation brightness, gain and white balance.
Click OK when your are done.
Last, make sure that you ae using the latest drivers.
You can upodate them from here.
http://www.logitech.com/index.cfm/492/&cl=us,en?prodcrid=492
Hope this helps.
Good Luck.
Live, Love, Laugh.
May 12, 2008 | Logitech Webcam
Toshiba a105-s4344
In both cases it sounds like it could be a graphics card problem. You could try to find the latest driver updates for your graphics card by searching the internet for the most suitable driver & / or updates. (When software is automatically (Microsoft/Windows/etc) updated from the internet, it may be of versions that are no longer compatible to you Hardware drivers)
Overheating could also cause the problem if you have an older Laptop, with the latest software.
Mar 31, 2008 | Toshiba Satellite A105-S4004 Notebook
Toshiba Satillite A105
Send it back to geek squad and have them correct the issue.
Feb 08, 2008 | Toshiba Satellite A105-S4004 Notebook
LCD Display problem
THE WIRING OF UR SCREEN IS DAMAGED GET IT REPAIRED BY A PRO
Nov 24, 2007 | Toshiba Satellite A105-S4004 Notebook
LCD display problem
My Toshiba Satellite does a similar thing, It goes gray while I am working on it. The only way to continue to work on it is to complete shut it down manually and reboot. I took it to Toshiba they said nothing was wrong.
Oct 19, 2007 | Toshiba Satellite A105-S4004 Notebook
Blanck Display
Don't forget that there is a switch that toggles the display from internal to external display (possibly Fn+F5).
Sep 05, 2007 | Toshiba Satellite A105-S4004 Notebook
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
116 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
