Question about Samsung 192MP (Silver) 19" LCD Monitor
How do I increase the size of my desktop and remove the blue border?
My 192MP monitor is hooked up to my laptop running XP. When used as a TV everything works fine but now when I use it as a monitor the screen size has changed so that it appears smaller & there is a large blue border where the screen used to occupy. Basically it looks like the desktop is set in the center of a blue background. The resolution has not changed so why does it appear smaller and how can I fix this?
  • rubykins Apr 16, 2008
    Everything on my computer screen appears too large and is not centered. My computer is running fine other than that. Please tell me how to fix my problem. Thank you! This includes allwriting and icons also.
    Scholar:
  • 104 Answers
There are three size settings you can choose from, Normal, Wide and Zoom. Try changing it using the 'Size' button on the remote or by going into the On Screen Display (OSD) settings. If you don't have a manual you can get one here. Hope this helps.
Posted on Mar 15, 2008
SOURCE:
I purchased a component cable (rectangular plug I think called VGA plugs into female left side laptop toward the back and red, blue and green RCA type jacks for LG TV.
Look for a Function Key (fn) on your laptop for activating the VGA external monitor.
If your fn button is blue (for example) all of the keys on your laptop that are activated when you hold down the fn button will have an option in blue. Look for a blue icon on a key that roughly looks like a monitor or two monitors.
With everything hooked up, press and hold the fn key, then tap the corresponding key to turn on the external monitor.
Having said that... the cable you are describing has a VGA (blue 15 pin connector) that plugs onto the VGA jack of your laptop and splits that signal into a set of component RCA plugs. Its critical how you plug these into the correct place on your LG TV component connections. I know such adapter cables exist but I've never seen one work.
Sep 06, 2017 | Acer Computers & Internet
How do you get a pic to extend desktop to tv monitor using vha to vga cord? I had no problem when I used a s-video hook up. I plugged in the pc and tv using the s-video cable, Choose Display, extended the...
What is occurring is the TV monitor is extending your desktop, where what you were doing in the past is switching between the two. When you plugged the VGA cable in, what occurred is your desktop was increased to account for the size of the TV, and it is acting like a second monitor, If you go into the display properties on your computer you will see a monitor with a 1 and one with a 2. The monitor with a 2 on it is the television, and whatever side it is to the #1 monitor (most likely to the right) if you scroll your mouse to the right of the monitor on your computer you should see it appear on the TV, to play or have a window on your TV, simply click and drag the window into the TV screen Frame, and then maximize the window, this will allow you to continue to work on your computer monitor while the other program runs on the television. It's basically like having two monitors instead of switching between the two
Jul 23, 2011 | Dell Latitude™ D510 PC Notebook
I use an lcd screen. I've just reinstalled my Windows xp. But the desktop screen doesn't display fully. Left side & right side has some space. I set my screen resolution at 1024 by 768 pixels &...
The monitor should have some buttons on it to enter the menu system for the monitor. as part of the settings there should be options for vertical/horizontal size and position. You will need to adjust these to bring your borders to the correct position.
May 21, 2010 | Computers & Internet
When I hook my tv up to my desktop computer the screen looks like it is going to work (it says dell then the loading bar fills up) as a monitor until it is time for my log in screen to come up. The screen...
hi,
This is normally due to a frequency or resolution incompatibility. Turn on your desktop computer, then change the screen resolution to 800x600 or 1024x768. Save the settings. Reboot to check that it is indeed saved.
Once you boot up on your TV, it should display fine. Gradually increase the resolution and colors to the max your TV can handle.
Feb 28, 2010 | Element Electronics FLX-3211B 32 in. LCD...
I hooked up the cable to my tv and laptop but I am not getting a picture on the tv? How do I get the tv to work with the laptop?
Are you using the VGA (15 pin connector) connection?
What operating system are you using?
If windows then right click anywhere on your desktop.
- Select "Personalize" (VISTA) or "Properties" (XP)
- Select Display Settings
From there you can extend your desktop onto a second monitor (your TV). Or mirror your desktop onto the TV...depending on your graphics card and the options it provides.
Let me know if you need any more clarification.
Thanks!
Jan 15, 2010 | Vizio L37 Television
I am having problems with an extra monitor
I would say this will be resolution problem.
Lower the resolution on the secondary monitor and try again.
let me know how it goes.
Dec 02, 2009 | Microsoft Windows XP Professional
How do I retune my Samsung Syncmaster 19''LCD TV as channel 5 is not available.
Manually select channel 5 (NOT by pressing "channel-up" while viewing channel 4) and press the 'ADD/DELETE CHANNEL' button.
Or, run through the complete "automatic channel seek" first-time-setup function to "re-discover" all the available channels.
Oct 26, 2009 | Samsung 192MP SyncMaster 19" LCD Monitor
Computer screen is beyond the monitor border
first things first check the max supported resolution on the polariod tv. Should be found in owners manual. set the pc to that resolution and you shoul have the whole screen.
Mar 16, 2009 | Televison & Video
Poor tv output
Download 'media player classic'. you can resize on the fly with the number keypad. 5=reset
Nov 16, 2008 | PNY Verto Ti 4200 Graphic Card
I am trying to connect my toshiba laptop to my philips tv by vga but i do not know what settings to put my laptop on
Assuming that you have hooked the cables right, you need to press the key combination Fn + F? to activate the external video output of the Toshiba laptop. The "?" would depend on the exact model of your Toshiba. Additionally, there would be a blue lettered indicator on one of the top keys of keyboard indicating a monitor.
Incidentally, it might be worth mentioning that most TV can not operate on too high a setting of the Resolution of your Display Properties and therefore would require that the laptop's Screen Resolution be lowered down when used in conjunction with an external display device such as a monitor. At other times, the Screen refresh Rates would need to be lowered down also.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 15, 2008 | Computers & Internet
Open Questions:
Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,Looking for Avast Tech Support 1888 499-5520 Avast Support avast Support,
Oct 14, 2019 | Computers & Internet
See all Samsung 192MP (Silver) 19" LCD Monitor Questions
Samsung 192MP (Silver) 19" LCD Monitor Logo
600 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
