Question about Compaq Presario 5000 PC Desktop
My compaq presario 5000 does not see the new memory and when i put in both 256 cards it won't boot up just a black screen
    Sergeant:
  • 256 Answers
This might be incompatibility issue with the memory and pc. check for system specs from compaq and check also for maximum memory capacity.
Posted on Mar 29, 2010
SOURCE:
I have a compaq r4000 cto. I just replaced the system board with a used board. When I first started it up I got a black screen and three beeps which after a few tries became a black screen and four...
It's unlikely that you have 2 or more defective memory modules. Remove all cards such as video, modem, etc. Also disconnect all drives (hard drive, CD, DVD). Try booting with one memory module at a time. If still a no go then I would suspect the motherboard.
Feb 20, 2011 | HP Compaq Presario R4000 Notebook
Compaq Presario 5LOXE1 Memory upgrade
So you mean only 1 video card is working and the other one is not?
May 04, 2008 | Compaq Presario 5000 PC Desktop
I hace a compaq presario 700 . I added 256 memory
remove the memory ... try again ...
there is the possibility your memory was not seated correctly and/or it is not the correct memory.
remove it to get going again ...
256 is a strange number ...
please go to www.4allmemory.com and have them scan your computer. They will make recommendations based on that scan. Compare what you got with their recommendation.
Truth is a journey not a destination
Thanks for using fixya.com
Oct 26, 2009 | HP Compaq Presario 730US Notebook
Presario won't recognize second 256 RAM
Remove the original module, install just the new one and then start your computer. If it doesn't start, the memory you bought is bad. The system boards used in the Compaqs will auto-detect memory, and there are no jumpers or BIOS settings needed.
Apr 09, 2009 | Compaq Presario 5000 PC Desktop
New 256 Mb RAM in Compaq Presario 17XL2 not recognized
500Mhz CPU use DDR333/400 memories. majority are used in MAC.
800Mhz CPU use DDR2 400/533/667 Mhz.
look like either you cna change the CPU or change meories again to match them up.
Nov 14, 2008 | Computers & Internet
What are the ram limits on a compaq presario 5000a. I put 256 ram in the compaq and it only reads 128. Why?
You can install up to 3 sticks of 512 mb of memory. Did you add a 256 stick to the already-existing 128? You need to put DDR266/PC2100 memory. To troubleshoot, remove the 128 stick and put your 256 in and see if it is recognized. You will know right away from the bios screen. Memory needs to be the same type.
Jul 16, 2008 | Compaq Computers & Internet
RAM upgrade gone wrong?
Did you already try using last know good configuration?
When your computer boots instead of f10 press F8. Then select last known good configuration and enter.
if it didn't work try booting up the computer without the memory see if it will have the same problem.
May 12, 2008 | Compaq Presario 5000 PC Desktop
Memory card
Hey there speedboy2024, the answer is 768mb, spread over three SDram memory slots. I would try 256/256/128, if you were trying to max. Good Luck!
Jan 31, 2008 | Compaq Presario 5000 PC Desktop
Compaq presario 5000 startup problem
Firstly the keyboard does blink, but do you hear 2 beeps one then another a few seconds later, if not memory or graphics fault. Are you able to start in safe mode(press F8 when pc is booting up)when menu comes up highlight 'Start windows with last known good configuration' then press enter and it should re boot. The graphics card(if it's not onboard)may need to be removed and re seated, also the memory. Also check hard disk drive ide and power cable.
Jan 15, 2007 | Compaq Presario 5000 PC Desktop
Compaq Presario 5000 PC Desktop Logo
83 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
