Question about ASUS P4S533-MX Motherboard
My pc won't boot
Everytime i turn on my pc, i only see on my monitor screen a green grid... and if i turn of my CPU the grid turns to white... i am using a geforce video card, and it is working on other p.c... what should i do..?
I down load drive
Posted on Mar 14, 2008
Pc not booting
If you hear the CPU fan turn on that doesn't mean the CPU itself is working. It can be only that the motherboard is getting power. Check all your connections such as monitor and peripherals and re-connect them. If you still don't get P.O.S.T. or ANY letters or boot options on your screen then your CPU is dead. (unless your monitor is bad)
Another easy diagnostic is using your ears. For example the pitch sound of the fan in some motherboards tends to lower and then increase because it's reading of the hard drive. This means your CPU is ok but either your graphics connection is bad or your monitor is.
Apr 22, 2012 | Intel Motherboard
When i turn it on it only appears only a second , my monitor turn black
Hello Chelleydiao, hi, its either you have a CPU problem or the monitor itself. Check or use another monitor to see if the problem is fix. you see an blank monitor can also be caused by the CPU if it fails to boot. the aid the checking, do you see any orange light on the monitor? or any indication.... the led light on the screen in summary: green or blue means there is power and the CPU boots up. if orange the CPU fails to boot, if there are no lights on the Monitor panels, there are problems on the monitor. check these first....I need a much detail description.
Dec 18, 2010 | AOC Monitor
I have a Toshiba Tecra-M2-S410 machine, and it does not turn on anymore. When I remove the battery and plug it in, the power light turns green as expected. When I press the power button, two other lights...
Hi mohammad - seems the LCD of the laptop is gone bad . as u said u gets the light on the laptop and also sound and then it goes dark - shows possibly the LCD gone bad .
Give a try with this if you have a computer in your home - on the back of the monitor you will find a VGA cable (probably with a blue color end which goes to cpu ) unplug it from cpu and plug it in the laptop (side of laptop you will find a same input VGA slot blue color ) and boot your laptop after turning on both (monitor and laptop) if you find the screen on the monitor then it will be sure that your laptop LCD has gone bad .
On your laptop if you are not able to find the boot screen also that refers to LCD brokerage -anyway try the above you will be sure ..
Oct 01, 2010 | Toshiba Tecra M2-S410 (032017233812) PC...
My viewsonic monitor has orange spots on the black screen, or green spots on the white screen. They are in a grid layout
Sounds like you have some radio frequency interference from some electronic device such as a TV or another computer. Try a new vvideo lead with better screening. The fact that it is in a grid pattern indicates a steady frequency.
Dec 15, 2009 | Computers & Internet
Cant turn on the monitor
try another screen, if its ok than its your screen. if the other screen (even an old one) does it than its your video card.
you can also put your screen to another computer and if it does it than you know its the screen.
Apr 20, 2009 | Computers & Internet
Randomly lost display on my pc.. and its not a faulty card.
Try to set your PCI-E card as a first one in BIOS. There also should be an option to turn off onboard video.
Mar 07, 2009 | Gateway GT4022 PC Desktop
No signal on first boot
I think is a power supply problem,,
Mar 10, 2008 | Nokia 445 Pro 21" CRT Monitor
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
Dell E171FPb monitor turns on, but that's it
Hi Letneper,
Hope this will give you hints. Some monitors have standby mode or screen saver feature and or self test feature when not connected to video input of your PC or CPU. Except this problem did not occur at first use. You can turn this off like other monitors manually at OSD (on-screen display) settings if available. No more no less if it works fine with PC or CPU on then there's nothing to worry.
Best regards,
Rosener Guyano
Sep 04, 2007 | Dell E171FPb 17" Flat Panel LCD Monitor
ASUS P4S533-MX Motherboard Logo
59 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
