Question about Sybase SQL Anywhere Studio for Workgroups - ( v. 9.x ) - license (1838109)
DTS MS SQL 2000 to Sybase
I want to run a DTS between MS SQL Server 2000 and Sybase ASE 12.5.
I have created a DSN (ODBC). However I am unable to perform the same.
Below is the query
INSERT OPENQUERY (mysybase, 'SELECT name FROM mytestdb.table1')
VALUES ('abc')
Whenever I run this query the system lets me add a single transaction but if I run t he query a second time I get an out of memory exception. To resolve the same I need to restart the MS SQL Server before I can insert another row. Please suggest where am I going wrong.
Below is a trace of the tasks that I am performing.
SELECT @@version
--Microsoft SQL Server 2000 - 8.00.2039 (Intel X86) May 3 2005 23:18:38
--Copyright (c) 1988-2003 Microsoft Corporation Enterprise Evaluation Edition on
--Windows NT 5.1 (Build 2600: Service Pack 2)
GO
-- Adding linked server:
exec sp_addlinkedserver @server = 'Linked' ,
@srvproduct = 'Sybase',
@provider = 'MSDASQL',
@datasrc = 'sybase' -- dsn (Control Panel)
GO
-- Adding linked server login:
sp_addlinkedsrvlogin @useself='f alse ', @rmtsrvname = 'Linked',
@rmtuser = 'sa',
@rmtpassword = ''
GO
EXEC sp_linkedservers
GO
SELECT *
FROM OPENQUERY(Linked, 'Select * from mysybase..emp')
GO
INSERT OPENQUERY (Linked, 'SELECT eno,ename FROM mysybase..emp WHERE 1=2')
VALUES (4,'Tom')
(Both tables have the same structure)
  • ahead Mar 17, 2008
    Thanks mcc99,
    Main issue is to link MS SQL Server to Sybase.
    If aay one can help me on this.
    Regards
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 51 Answers
Try using a transaction block.
Posted on Mar 15, 2008
SOURCE:
Which database can I use with ColdFusion?
ColdFusion supports ODBC-compliant databases. With Net Nation's ColdFusion plans, you can use a Microsoft FoxPro, Microsoft Access or Microsoft SQL Server database. ColdFusion supports both DSN and DSN-less connections.
Oct 09, 2014 | Oracle 10g Database Standard (ODBSEONUPP0)
Tip
Tricks for Keeping SQL Server Safely
Some simple ways to protect your SQL Server database
1. Using the Microsoft Baseline Security Analyzer (MBSA) to assess the server's security
MBSA is one of a variety of Microsoft products, which can scan unsafe configuration tools. It can be run locally; you can also run through the network.
2. Isolate your server and regularly back up
Physical and logical isolation would form the basis of SQL Server security. Database should be installed within the enterprise network security area, but not directly connected to the Internet. Back up all data regularly and store copies in a safe location outside the site.
3. Assign a strong SA password for a SA account
SA account should always have a strong password, even if Windows is configured to require authentication of the server. This will ensure that the server has been reconfigured in the future as Mixed Mode authentication; it will not appear blank or weak SA.
4. Restrict the permissions SQL Server service
SQL Server 2000 and SQL Server Agent is running as a Windows service. Each service must be associated with a Windows account, and derive from this account security context. SA log in SQL Server allows the user (sometimes including other users) to access the operating system features.
About reset SA password in SQL 2008/2005/2000
To secure our database we would like to choose create an intricate password. But even our selves would forget the SA password in SQL Server 2005/2008 sometimes. So here is a way for you to reset SQL Server 2005 password -- MS SQL Server Password Unlocker, which is a highly A Highly Technical and Safe SQL password 2005 Recovery tool. And following is a few features of the tool.
Features:
* Support SQL Server password recovery for MS SQL Server and MS SQL Server Express 2008/2005/2000
* No need to install MS SQL Server on your PC or lose data, the file master.mdf format is necessary
* Stop and resume MS SQL service automatically if the MS SQL Server on your PC is running
* Reset SQL password with ease no matter how long and complicated the SQL password is
* Easy to use
Feedback:
The most of people who encountered with SQL 2005 password losing problems are getting back to their SQL account now. We can also feel that ease and the hilarious mood when a hard nut has been cracked. Hope this MS SQL Server Password Unlocker would help more people and get their trouble erased.
on Nov 12, 2010 | Computers & Internet
Tip
How to Create and Remove SQL Server Password
SQL Server is a Microsoft product used to manage and storeinformation. It uses tables to contain large sets of records for thedatabase. Do you have a SQL server and have you ever used SQL server?Do you know how to create a SQL Server passwordto protect your data stored on SQL server? What to do if you forgetyour SQL password? Following it will introduce you how to create a SQLpassword. And it also tells you how to remove SQL Server password ifyou forget as password can be easily lost.
How to create a SQL Server password?
As we know, it is an important security measure to set a passwordfor user accounts and in particular the SA account. And it is very easyfor you to create a SQL Server password. Just follow the simpleinstructions.
1. Open the Microsoft SQL Server Management Studio program from the Start menu bar in Windows.
2. Click on the SQL Server instance on which the new user will be created.
3. Right-click the Security folder, point to New, and then click Login.
4. On the General page, enter a name for the new login in the Login name box.
5. Select SQL Server Authentication and enter a password for the login.
6. Select the password policy options that should be applied to the new login. In general, enforcing password policy is the more secure option.
7. Click the OK to complete the creation of the new user.
Sometimes it happens that you ignore or forget the systemadministrator password. What will you do if you forget SQL password andcannot access to SQL database? The effective way I know is to remove SQL Server passwordwith the help of SQL Server password remover software. MS SQL ServerPassword Unlocker is one of the good MS SQL password remover toolswhich can help you remove SQL password in a few seconds.
How to remove SQL password with Windows Password Unlocker?
MS SQL Server Password Unlocker is handy SQL Server password remover software for you to reset SQLpassword including reset SA password and other user passwords. It caneasily remove SQL Server password for Microsoft SQL Server2000/2005/2008 in a minute. You don’t need to install MS SQL Server onyour PC, and the file in master.mdf format is enough for you to removeSQL Server password and set a new one for it.
Step 1. Download and install MS SQL Server Password Unlocker, and run the application.
Step 2. Click Open to import your master.mdf file. All the user names of your MS SQL Server will be displayed.
Step 3. Select an SQL account, click Change password button.
Step 4. Type a new password, and then click OK.
This SQL account password has been reset. You can login with the newly set SQL password. Although it is easy for you to remove SQL Server passwordwith SQL password remover, it is better to keep your SQL password inheart. Or you can also write it down on a paper and keep in a safeplace.
on Sep 07, 2010 | Computers & Internet
Re if I need create odbc dsn for all workstation?
Use servername as the server in setup and it will autocreate servername32 in odbc
May 15, 2010 | ACCPAC Simply Accounting 2004 PRO...
Visual Basic and SQL
Visual Basic 6.0 and MS Sql server 7 or 2000 are highly compatible with each other. VB.net is compatable with sql 2005 which is inbuilt as well.
Jul 07, 2009 | Microsoft Windows Vista Ultimate Edition
I am trying to connect to a SQL Server 2005 DB from Visual Studio
You must create an ODBC connection to your SQL database in the Windows Control Panel. Than you can call your ODBC connection via Visual Studio 2005. You can also create a DSN in Visual Studio 2005 and reference in that way. You will not be able to connect to an MDF but instead you have to connect to the SQL Server Service. Of course the username you use to connect must have access that will be created on the SQL server.
Apr 13, 2009 | Microsoft SQL Server 2005 Standard Edition
How can i connect the data base during my project
That seems fine.
I cant assume your level of confidence in programming, however, following are some simple steps you can follow to achieve (for complex implementations, much more time and details will be needed, i can help u with them as well)
1. Create a database in Access ( i assume u r using Access 2003)
2. Create a System DSN (if aren't clear, how to create then goto administrative tools under control panel and you'll find Data Sources (ODBC), here u need to create System level DSN for Access driver (may be Jet 4.0+)
3. In java, you need to import java core libraries for sql (javax.sql package specially)
4. you are almost done, just google for database code in java, simple code will be around 5-10 lines (just for your reference, search with these keywords, ClassName(""), jdbc:odbc:YourDSN)
5. Open a connection using Connection object
6. Fetch the records (select query) using Recordset object
7. You're done.
thanks
Kuldeep
Mar 13, 2009 | HP Computers & Internet
ODBC
give ur add i want to check it out.
Aug 26, 2008 | Microsoft Windows Server Standard 2003 for...
How to configure odbc for multiple user in windows 2003 server
You can also try adding the datasource as a System DSN instead of a User DSN. Of course, all users on a given system will then have access.
Apr 03, 2008 | Microsoft Windows Server Standard 2003 for...
MSSQL Related Problems
Please see link below http://www.php.net/function.mssql-connect
Basic tutorial in connection PHP Language to MS SQL Server.
Please rate me SOLVED.
Nov 22, 2007 | Microsoft SQL Server Standard Edition for...
Open Questions:
SBCGLOBAL helpline phone {&$&{[email protected]*1O69} NuMbEr USA This SBCGLOBAL USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 SBCGLOBAL USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the SBCGLOBAL USA helpline department for problems like Where to buy, Complaint, helpline, Repairs, Returns. As far as we can tell, SBCGLOBAL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SBCGLOBAL USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact SBCGLOBAL USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SBCGLOBAL USA Calling SBCGLOBAL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SBCGLOBAL USA helpline can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SBCGLOBAL USA's helpline department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SBCGLOBAL USA's phone numbers against each other. Contacting SBCGLOBAL USA in General While I8OO8O31O69 is SBCGLOBAL USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SBCGLOBAL USA help by calling them, is that other techs give their helpline at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SBCGLOBAL USA.
Oct 17, 2019 | Best Computers & Internet
aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...
Oct 17, 2019 | Computers & Internet
See all Sybase SQL Anywhere Studio for Workgroups - ( v. Questions
Computers & Internet Logo
279 people viewed this question
Top Sybase Computers & Internet Experts
Ekse
Alun Cox
Are you a Sybase Computer and Internet Expert? Answer questions, earn points and help others
