Samsung STP100 Thermal Printer installation
I have a Samsung STP100 Thermal Printer. I am trying to print Wordpad document using Generic Text driver, however it does not work. Is there any Printer driver existing ?
When you have installed the generic driver you must set up the port speed and parity bit settings to mach your printer
turn on the printer while holding "feed" and it will tell you what baud rate it is set to.
Posted on Mar 27, 2008
When printing, sentences over lap so the document is unreadable. Also it may only print the first line of a document.
I've seen word documents do this sometimes and fixing it has worked differently each time.
1) Open the document and press CTRL + A (select all) on the keyboard and then CTRL + C (copy), then start a new document and press CTRL + V (paste). Save the new document as something different and try printing again.
2) Open the document again and select all and copy again,but this time open wordpad (a different program to Microsoft Word) by going to Start > Programs > Accessories > Wordpad, and paste the text into wordpad. This may change some of the formatting. Now, select all again, and copy, and start a new word document and paste.
Copying the text out of word and back in seems to work more often. Sometimes the best program to copy out to is notepad, but you lose pretty much all of the formatting when you copy back into word.
3) If this doesn't work, you could try to update your printer drivers, and if that doesn't work, as a last resort, you can delete the printer and create it again via the Control Panel > Printers.
May 04, 2011 | Office Equipment & Supplies
Samsung ml-1710 printer does not always print
you need to reinstall printer with samsung printer driver specific for this model that can be downloaded from samsung website
Oct 04, 2009 | Samsung ML 1710 Laser Printer
Intermec 3400 label printer - Connected but no printing...
your com setting must be 9600baud 7 data bits even parity
you may need to drop back to win 98
here is the syntax you need to send to the printer STX ESC E5 CAN DATA CR DATA CR ETB ETX PRINT
Oct 29, 2008 | Intermec EasyCoder 3400 Thermal Label...
Samsung CLP-315
try to do this set of instruction & solution:
  1. Go to Start | Control Panel | Printers And Other Hardware | Printers And Faxes. Double-click the icon for your printer to open the Documents window and clear any pending print jobs by selecting Cancel All Documents from the Printer drop-down menu
  2. Try printing a test page from the printer, not from Windows XP. Most printers have a built-in test function that's activated by holding down one or more buttons while the printer is starting up. Check your printer's user manual for instructions. If this page prints successfully, you know the problem is either with your connection or with the software in your computer.
  3. Check your printer's USB or parallel connection.
  4. Try printing something simple from Windows' Notepad. To open Notepad, go to Start | All Programs | Accessories | Notepad, type a few lines of text in a document, and try printing it. If it successfully prints, the problem is with the software program you originally tried to print from.
  5. Try printing using Windows XP's generic printer driver. Open and run the Add Printer Wizard. When you get to the Install Printer Software screen, select Generic under Manufacturer and Generic/Text Only under Printers (see Figure 2).
  6. Select No for Do You Want To Use This Printer As The Default Printer? (see Figure 3). Click Next.
  7. When prompted on the next screen, tell Windows XP to print a test page. If the page successfully prints, then you probably have a problem with your installed printer driver. Either update or reinstall the driver.
Sep 16, 2008 | Samsung CLP 300 Laser Printer
Pixma IP3000 will not print
Sep 16, 2008 | Office Equipment & Supplies
Printer will not print
And.....
How about telling is what the make and model of the printer, what operating system you have, any error messages that pop up etc etc etc
TO Print the image using IPL.
I've printed images over 500kb. Can you print a small image? If not, perhaps the driver is the problem.
If you're trying to send a text file of IPL commands to the printer, set up a Generic Text printer driver, to to send the file as ascii characters instead of as a graphic image. You can set this up in addition to your Intermec driver.
Go to Printers and Faxes, Add Printer, Next, Select the Port, Select "Generic" Manufacturer, "Generic / Text Only" Printer, and give it a name like "Text". Cycle the printer power to clear previous attempts, then print the file to this printer name.
Aug 22, 2008 | Intermec EasyCoder 3400 Thermal Label...
Printer Clicking
What kind of printing job are you trying to do?
Jun 11, 2008 | Zebra LP 2844 Thermal Printer
Printing from windows
as i understand, DPL will works if you are using a serial comunication. When you say "using Generic Text Driver" i can see you are trying to print snce parallel port, as any other prnter. If that is the case, you can forget the DPL. Install an apropiated DATAMAX printer driver, and print from Wordpad.
Nov 21, 2007 | Datamax I-4308 Thermal Label Printer
Computers & Internet Logo
169 people viewed this question
Alun Cox
David Payne
David Payne
