Question about BenQ FP71G 17" LCD Monitor
BenQ FP71G+ LCD Monitor fault
Hi, this monitor just stopped working. The green light and display come on for about 2 seconds then switch off. Sometimes it's less. Have tried different power cord and different computer but same problem. Anyone got any ideas?
    Genius:
  • 1,142 Answers
Its not the fault with the monitor..its the VGa Cable thats going loose..plzs check the connections ...and contact the vendoe for furtehr support or replacements whichever is applicable
Posted on Mar 14, 2008
3 Suggested Answers
SOURCE:
SOURCE: Benq FP71G LCD Monitor - Can't keep POWER ON / Button Problem?
I had the same problem and found that Q808, Q809 and Q805 had failed and which if left long enough can also cause PF801 to fail. I also replaced all of the electrolytic capacitors during the rebuild as it was only a few dollars to do so.
Although in my case Q815, Q816 and Q812 were fine I suspect that they may also fail in time.
Here are the parts which should be available at most electronic stores or online.
Q808 & Q809 - 2SC5707
Q805 - IRFU9024N
PF801 - 3 AMP PICO FUSE
Posted on Jan 22, 2009
SOURCE: Where can I buy a logic PCB for FP71G Benq
Shenzhen VIIV Technology Co., Ltd is an expert at PCB,PCBA and Rigid Borad manufacturer based in shenzhen China.
MSN:[email protected]
Yahoo: viivtechavril
SKYPE: viivtech
Mobile: 86)15989403359
Email:[email protected] ,[email protected]
Website :www.szviivtech.com
Tel: 0086 755-29477736
Fax: 0086 755-29410695
ADD: sha
Posted on Aug 31, 2011
Hi sir iam surendra, present im using benq lcd moniter & since few days im facng display prblem, when i turn on my system, some lines are comming & causing visual problem.so iam nt able to see my...
The picture board on your monitor is bad, since the lines are causing visual display, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself. in other not to complicate issues.
Nov 26, 2010 | BenQ FP71G 17" LCD Monitor
I'm trying to set up BenQ FP71G+ as a second monitor connecting to Nvidia GeForce 8800 GT. I cannot get the BenQ to display even if it is the only monitor connected. However, I can see the BenQ in...
I have had problems occasionally with connecting a second monitor, too. Hook up both monitors. In the Windows control panel, look up display (or right click on your desktop and select display). Is the second monitor shown? If not, click "detect" and see if it shows up. I have had a couple times where I clicked on the monitor icon in "display" and then clicked "enable this monitor" and it started working. If not, then try switching the cords so your working monitor is the second one. try again and see if it show up. If not, the problem is probably with the video card or video card driver. Try and update the driver for your card.https://www.geforce.com/hardware/desktop-gpus/geforce-8800-gt
If this does not work, the issue is probably the card.
Feb 09, 2018 | BenQ FP71G 17" LCD Monitor
My BenQ FP71G powers on and off, repeatedly, by itself no matter whether connected to computer or not. Everything else is fine. Sometimes it stays on for a minute or so, but usually for just a few...
my BenQ FP71G 17 in goes on after hundreds of times pushing on off switch and when it's on it does not go off, I have checked the on/off switch which is working oke and when the moniter is on the auto adjust message (brightness and contrast)pops up frequently and the screen adjusts itself.
Oct 12, 2010 | BenQ FP71G 17" LCD Monitor
SKYPE: viivtech
ADD: sha
Jul 13, 2010 | BenQ FP71G 17" LCD Monitor
Monitor displays desktop for a short while
this kind of trouble is very common to all LCD monitors. your inverter is shutting down. please check all capacitors at the power supply some are badged or blown on top due to hot pressure inside.
Aug 17, 2009 | BenQ FP71G 17" LCD Monitor
When i turn on my monitor it shows my desktop then shuts off after 10 seconds...never stays on
elainenemeth, Hi, Tell me more! How old is this LCD monitor? Is it out of warranty? Did the "SHUT-DOWN-IMMEDIATE" problem occur without warning? Did the BenQ display a "perfect" image the day before? Did you actually count----1001, 1002----1010 and then it shut down, after pushing the monitor on button. Did you do the "flashlight" test? With monitor connected to a "known-good", fully booted pc with Win Desktop displayed, TURN ON the monitor! Did it display the desktop for 1-2-10 seconds ? What did you see or not see when you pointed the flashlight at different angles about 1-2" inches from the now dark (black) screen? Get back to me with your results. I will offer the best advice possible to you as a consumer/user of LCD/FPD monitor. I'm louie12fix on fixya or lmistyrel @ aol.com Bye for now.
Apr 17, 2009 | BenQ FP71G 17" LCD Monitor
Benq inverter board schemtic
Post me a picture of the board and I might be able to Help.Normally transistors 2Sc5707 are defective.
Samir.
[email protected]
Aug 20, 2008 | BenQ FP71G 17" LCD Monitor
Benq FP71G+ 17" LCD with Power Recycle (shutdown & return).
Seems either aproblem with Invertor board or Front panel switches are leaky.
Samir
Aug 17, 2008 | BenQ FP71G 17" LCD Monitor
Benq FP71G+S NOt starting.
Hello
I have had this problem twice once at my school and once with my BenQ FP71G Monitor. At my school the monitor ( HP ) just stopped working and smelt like burnt popcorn.(though is think this is due to some kids chucking a soccer(football) ball at it! With my BenQ it has the same problem though i nownthink it is because of the monitor has been on for excessive hours ( 3-4 ) and just shut down because of overheating. I will see in a couple of hours if it works !
Copper_R
Dec 30, 2007 | BenQ FP71G 17" LCD Monitor
BenQ FP71G 17" LCD Monitor Logo
162 people viewed this question
Top BenQ Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
