Key lock how to unlock key lock on vista
  • gazz2k7 Mar 17, 2008
    sorry i ment the keyboard lock
    Problem Solver:
  • 9 Answers
Just power off the system try to change the jumper settings and clear the bios ....i hope this ll help you.....
Posted on Mar 18, 2008
    Sergeant:
    Champion:
  • 293 Answers
Better buy license vista from microsoft
Posted on Mar 16, 2008
I have to agree with bigbiggs - unless you are talking about something else. if you are talking about activation - BUY the LICENSE!
Posted on Mar 15, 2008
    Sergeant:
    Champion:
  • 326 Answers
Buy the license!
What do you want to mean by "Key Lock", "Unlock" ??? Please specify descriptively.
I have a 1996 gmc suburban that i cannot unlock the driver's door. it was locked with key fob. i cannot unlock the door or open the door. the key will not unlock the door. help anyone?
if the key does not turn the lock spray it out with wd 40 run key in and out of lock few times.because everyone uses remotes to open their cars the waffers in the door locks get coroded and wont fall in proper place when key is inserted.give it good cleaning and see if it will unlock
Feb 03, 2013 | 1996 GMC Suburban
Keypad locked - how do I unlock it? Operating System is Windows Vista.
You may need to press and hold the Fn key then press the Numlock key to unlock your keypad.
Please tell me how this goes. Thank you for using FixYa.
Dec 28, 2010 | Sony VAIO RB30C (VGCRB30) PC Desktop
Un lock my vista pc
call microsoft to get a good key
Jun 04, 2010 | Microsoft Windows? Vista Home Basic...
How do I lock my keyboard while a program is running?
well you can do this by using the filter keys ..follow the steps below to get your job done:
To lock keyboard with filterkeys ->activate sticky keys by pressing the shift key 5 times.
-> Go to settings and click the radio button 'use filter keys' this locks the keyboard and gives nifty little sounds all except the taskbar button if keyboard has one
->. easily unlock by double clicking little clock emblem in the bottom right hand corner of screen and deselecting use filter keys. Make sure you hit 'apply'
good luck ....i'm sure this works
Apr 08, 2010 | Microsoft Windows Vista Home Basic for PC
I have replaced the batteries on the key remote control but it does not work
Programming
When
Key added or replaced. System malfunction.
How
Obtain all keys. A maximum of 3 keys can be programmed. Close all doors and boot/tailgate. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press key lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press key lock or unlock button. System should now lock or unlock vehicle. Within 4 seconds: Press key lock or unlock button. Within 10 seconds: Press lock or unlock button of first key. System should now lock or unlock vehicle. Press lock or unlock button of second key. System should now lock or unlock vehicle. Press lock or unlock button of third key. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed keys.
NOTE: If less than 3 keys are to be programmed, remove ignition key after programming last key.
Mar 22, 2010 | 2005 Honda Accord
2002 bmw 530i key does not (remotely) unlock doors or trunk but they work fine manually.
Unlock vehicle. Enter vehicle. Close driver's door. Switch ignition ON and OFF. Remove ignition key. Press and hold unlock button. Press lock button briefly 3 times within 10 seconds keeping unlock button depressed. Release unlock button. Some models: LED flashes slowly for 10 seconds. Some models: Central locking system locks and unlocks rapidly to indicate correct programming. Repeat above procedure if central locking system does not work and LED does not flash or LED flashes continuously.
Mar 09, 2010 | 2002 BMW 5 Series
Central locking on mk 5 golf works fine with key in lock and from inside car using switch but only unlocks drivers side using key fob. any answers?
Synchronization
When
Key buttons operated repeatedly while vehicle out of range and system becomes inoperative.
How
Polo: Press key unlock button for approximately 1 second. Golf/Bora: Press key lock or unlock button for approximately 1 second. Manually lock or unlock vehicle. System should now lock or unlock vehicle. If not, carry out programming procedure.
Programming
When
How - Polo
Keys can only be programmed using diagnostic equipment.
NOTE: A maximum of 4 keys can be programmed.
How - Golf/Bora
98MY
How - Golf/Bora 99MY
Switch ignition ON. Insert key to be programmed into driver's door lock. Lock vehicle manually. Press lock or unlock button. Wait at least 1 second. Press lock or unlock button again. Vehicle horn sounds to indicate correct programming. Keys can also be programmed using diagnostic equipment.
Mar 07, 2010 | 2001 Volkswagen Golf
REMOTE KEY LOCK DOES NOT WORK BATTERYS NEW BUT ALARM WILL NOT SHUT OFF WHEN FIRST START .HOW CAN I DISABLE ALARM
Synchronization
When
How
Carry out the following within 1 minute: Press key lock or unlock button for approximately 1 second. Manually lock or unlock vehicle. System should now lock or unlock vehicle. If not, carry out programming procedure.
Programming
When
How
Switch ignition ON. Insert key to be programmed into driver's door lock. Lock vehicle manually. Press lock or unlock button. Wait at least 1 second. Press lock or unlock button again. Vehicle horn sounds to indicate correct programming. Remote controls can also be programmed using diagnostic equipment.
Feb 09, 2010 | 2000 Volkswagen Beetle
Replaced battery now having problems with automatically locks
Synchronization
When
How
Programming
When
How -
98MY
How - 99MY
Feb 05, 2010 | 2002 Volkswagen Passat
I have a 2004 Honda Accord EX. Key Fob works trunk but not doors
Programming
When
How
Jan 25, 2010 | 2004 Honda Accord
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
