Question about Motorola Mobility RAZR V3
Constant Seeking My H500 Motorola headset used to work fine with my Motorola V3i. For some odd reason now, it will not connect to my V3i. It just constantly continues to "Seeking H500". i have tried deleting headset from phone and starting from square one. i have drained and fully charged both phone and headset. Pin is verifed, the phone recogonizes it, just constantly "Seeking H500". Any help?
    Brigadier General:
  • 7,752 Answers
Maybe faulty now....try a new one and see if it finds that one, if it does then you know you will have to get a new one.
Posted on Mar 21, 2008
SOURCE:
I am trying to connect my H500 to my new
Enter '0000' (four zeros) when your phone requests a passkey whilst pairing with your headset.
Hope it works for you.
Cheers! Carlos
May 17, 2010 | Motorola Mobility Universal Bluetooth...
MY BLUETOOTH FOR MOTOROLA H500 I LOST THE PASSKEY AND I USED THE DEFAULT PASS KEY AND IT SAID FAILED TO CONNECT
The passkey is default set for all Motorola headsets at 0000. try that. If this works, be sure to rate the solution. Thanks!
Nov 08, 2008 | Motorola Mobility H500 Wireless Headset
Motorola H500 Headset Problem
TRhe pair code for my motorola headset is 0000 (that's zero zero zero zero)
Oct 16, 2008 | Motorola Mobility H500 Headset
Can't pair with h500 headset with v3
try master resetting and clearing the phone and try pairing again
Aug 28, 2008 | Motorola Mobility RAZR V3
Motorola v3i problem with earphones?or usb port?
Hi Ihenski
If your USB cable is sure to be working try increasing your phone's volume or betterstill increase the volume of your earphones if it has one, if problem persists get new earphones.
Jan 15, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Problems With Pairing H500 and Motorola V190
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H500once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Dec 24, 2007 | Motorola Mobility H500 Wireless Headset
H500 won't pair with Blackberry Curve
It might already have been figured out but if you hold the answer button on the headset down until the light stays on steady, it is in pairing mode. You can then go to bluetooth setup on the Curve and it will find the headset.
Nov 08, 2007 | Motorola Mobility H500 Wireless Headset
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
