Question about Dryers
NO HEAT ... and filter light stays on ... HELP/ADVICE NEEDED ... AM DISTRESSED .....
RE:CANDY NOVA CDC 266UK
Please can you advise...My machine is not heating/drying the clothes - although blowing air and going round..also the filter light stays on and I have cleaned both the filters ....WHAT DO YOU SUGGEST..????
I have ENORMOUS backloads of washing - with two new grandchildren to boot ...actually I am not booting them yet but may if they start disappearing under the piles of clothes !
Any advice or suggestions would be much appreciated - I am based in Islington , London.
1) I cannot afford to call an engineer out and pay him just to tell me to scrap it.
2) If parts and labour come to too much it makes more sense to start saving towards a new replacement.
Thank you 'Grandma' Willow
P.S.The guarantee ran out a couple of months ago!
P.P.S. If viable to get parts and mend I will call an engineer to fit ....if ness! ... yes I am that poor... but able bodied and willing ...with female brain.....?!?
  • Anonymous Mar 14, 2008
    just read about the reset button on thermostat thing but need to know what I am looking for and where on this model...Thank you for any help willow
  • Anonymous Nov 01, 2008
    The light stays on when the door is closed but nothing else works on the dryer.
  • 30 Answers
Most likely possibilities on heating problem. All are listed from most likely to least likely.
1. Thermal Fuse (Located near blower housing)
2. Thermostat
3. Thermostor
4. Heating Element
5. Ignitor (Gas Dryers Only)
All parts can be tested with an ohm meter for continuity. Most parts are under $20 with exceptions for the heating element and ignitor. Considering that you had a technician come out to your house, charge would be roughly $120-200. A dryer's life span is usually about 10 years; give or take. For a diagram to locate all parts within your dryer, refer to www3.sears.com with the model number of your dryer. Model number found on the side panel when you open the door of the unit. If you need more assistance, just comment and I will get back on later today or tomorrow.
Posted on Mar 14, 2008
SOURCE:
The start button on Candy Nova CDV-262 won't stay in.
there seem to be a bad connection try sliding a thin knife next to the switch and see if that works
Feb 17, 2013 | Dryers
Candy nova cdv 262, heat works but drum does not revolve
Hi dodgedrums...
I can answer your question, but you will need to resubmit your question if you need help in the repair.
I have never worked on a Candy machine so therefore I cannot help with the dissassembly of the dryer for repair
Your problem is most likely to be a broken belt, or a faulty motor...normally even a novice mechanic can repair with the proper advise which you will normally find here at Fixya.
Please take time to rate me
Jul 20, 2011 | Candy CDV262 Dryer
Candy nova cd112 dishwasher fills with water then stops working
nova cd112 this is a simple fix the machine has a electronic switch to add water to the machine it then has another switch to say the machine has water iin it , this switch is the one that is not working this is the one that turns on the element and heat the water .it costs around a tenner to replace u can find it as it is connected to the element via a wire conection .this a a common problem of over enginearing as this switch is not needed and is not on older machine .ie this switch can only come on when the machine has water in it in other words only after the switch to put water in the machine has been on.can this go on i hope u know what i mean lol. now u can replace this yourself or get an engineer it should take an engineer no more than 10/15 mins to fix better still have him bypass this switch and u will never haver the problem again as this switch is prone to going fixthis and the machine should last years no problem as its not a bad machine not quite a bosch but better than a zanussi or indicit etc hope this helps and may i just say that i tried everything including replacing the element ,stat and cpu non of which worked before realizing it was this .i must also say before u try this. Switch on your machine on put it on a universal cycle as u hear the water going in the machine open the door and add hot water as hot as u can close the door and the machine should do a full cycle including emptying and reheating the water this proves its not the cpu ,element or stat note the machine will not do the cycle without the hot water going in at the start if it does the cycle then its 100 % this switch hope this helps and sorry for the lond explantion bye
Feb 20, 2009 | Candy 24 in. CD622 Free-standing...
Candy cdc 266
your belt is probably broken, or your motor is bad, the motor and belt not only turn the drum, but also the fan that moves air out of your dryer so if it cannot move, the dryer gets hot and it thinks this is because the lint trap is full
Oct 27, 2008 | Candy CDC266 Dryer
Candy Nova CDC 266 tumble dryer. The tumble dryer tumbles but I have no heat and the filter light stays on constantly. Any ideas of what it could be?
hi ya this is the thermostat at the back of machine external,take the fan housing of it is nomaly the top one .beware change like for like do not exceed the temp rating of the stat.
hope you solve it
andy bird www.shropdive.co.uk
May 05, 2008 | Dryers
Themostat reset button- where is it and what does it look like o Candy nova 266uk
Hi I am having the same problems, the filter light came on so I cleaned the filter and condenser, but the light won't go off, the dryer works fine other than that, exept theres no heat but the book says there won't be any heat untill the light goes off. any ideas thanks Christine
Mar 14, 2008 | Candy CDC266 Dryer
Dryers Logo
171 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
