Question about Nokia 6600
Bluetooth will not work
My phones bluetooth will not work, it reads system error. The phone also runs very slow and i can't even browse on the phone.
How bluetooth not work ?
Posted on Mar 14, 2008
  • Anonymous Mar 14, 2008
    network will not work?
SOURCE:
I want to connect my samsung montage sph-390 to the internet using the internet connection from my mac powerpc g4 (non-intel) running os x 10.5.8. both the cell phone and the mac are bluetooth enabled and...
i am covering for my sister at work right now and im using my 15 inch powerbook g4...i am rooted and try wifi tether here and there but its too slow so since i knew i was goona be working i tried pdanet last night and it worked and thats what im using right now to get online..i just installed pdanet on my phone then clicked bluetooth DUN and then on my powerbook went to bluetooth and clicked set up bluetooth device and let it run through the setup it found the droidx right away...then i had to pair it with a pin....now each time i wanna connect it i just start pdanet bluetooth DUN and then click the bluetooth in my status bar and mouse over where it says droid x and click connect to network....then the "droidx" turns bold and im connected
Mar 29, 2014 | Computers & Internet
Nokia 301 - error 005
I had similar issue with my Nokia 205 handset. You necessarily do not need any engineer to be able to browse the internet on the phone. You need a laptop/PC (with Bluetooth connection capability) to download Opera mini. Push the downloaded Opera mini to the phone via Bluetooth. install opera mini on the phone.
With a valid APN configuration the phone will browse using opera mini.
Feb 13, 2014 | Nokia 301 Sim Free Mobile Phone - Black
How do i recieve songs through bluetooth from another phone?
Instructions
    • 1
      Verify that Bluetooth is turned on or enabled in both your devices. Most cell phones will have a Bluetooth menu in their Settings or Tools. For computers, you may see a Bluetooth icon in your system tray. If unsure, check your product manual for specific instructions.
    • 2
      Follow the instructions to pair (connect) your two devices. If you are asked for a passkey, try entering 0000 which is usually the default for any device.
    • 3
      When prompted on the other device, give permission for the original device to access it.
    If transferring from phone to phone
    • 4
      Navigate to the song you want to send and hit the button that takes you to the options menu. Choose the option to send your song; depending on the brand of phone it may say "Send" or "Move."
    • 5
      The next menu should ask if you want to use a text message or Bluetooth to move or send the file. Choose Bluetooth.
    • 6
      When prompted on the phone receiving the file, accept it.
    If transferring from computer to phone
    • 7
      Look for an option to browse the contents of the phone. Navigate to the Music or Multimedia folder on your phone.
    • 8
      Navigate to the place on your computer where your music file is kept in a separate window.
    • 9
      Drag the file from its original location to the correct folder on your phone.
    • 10
      Accept the file when prompted by your phone.
Tips & Warnings
  • Pairing is usually the most difficult part of the process. Make sure you read your manual on both devices if it isn't working for you. If you don't see the menu to move or send your music, your phone manufacturer may not allow it. Check your manual or with your carrier's tech support website. This process usually applies to MP3s and not ringtones.
Read more: How to Send Music to a Phone Via Bluetooth ' eHow.com http://www.ehow.com/how_4897391_send-music-phone-via-bluetooth.html#ixzz1xBSYWixA
Jun 08, 2012 | Sanyo SCP-2700 PINK Scratched Used Sprint...
N79 bluetooth not working
If the bluetooth is not detected on the menu the fault is on the software or even a fault on the hardware. If there is no activation of the bluetooth perhaps the phone needs a rebooting . now it is possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Copy only valid files to the card and do a scan before it is replaced. Now replace the card and battery and switch on the phone. If the phone hangs up or is slow when it is switched ON , then it is possible that the fault is relative to the software and will need a reinstallation. Possible hardware issue cannot be ruled out.
Nov 12, 2011 | Nokia N79 Cellular Phone
I just got the new Kin Onem. I have a macbook and I'm trying to set up the bluetooth connection from my phone to my computer in order to transfer files such as pictures. My laptop is recognizing that...
I believe the kin's bluetooth is only for pairing with headsets and possibly sending a file. I doubt it is possible to actually browse the phones file system from the macbook. Try looking for an option on the phone to send the file via bluetooth instead of trying to browse the phone from the macbook.
May 11, 2011 | Microsoft KIN One Cell Phone
Hai, thanks for ur time share. I've samsung j 600 mobile. It seems my phone's text message memory running out. So,I wish to copy all messages to my pc. I've pc suite for my mobile & pc bluetooth,but,no...
Configure your PC Suite application (software) to detect your Samsung Phone. When you can establish a connection, then, even though you don't have cable, you can browse your phone's memory and copy or backup your messages.
Just a guide, when you have installed Samsung PC Suite already, open the program and a wizard window will guide you through the connection process of your phone. Then you will be given an option to connect through bluetooth. Make sure that your computer's bluetooth and your phone's bluetooth are ON.
Mar 07, 2010 | Cell Phones
I CANT BROWSE MY MOTOROLA L6 TO MY COMPUTER, WHAT DRIVER SHOULD I INSTALL?
You can download the Motorola L6 modem driver here.
After you download the driver, make sure extract it somewhere inyour computer since I packed it in a ZIP file. Connect your Motorola L6phone by using a USB cable until the system tray shows you the pop-upmessage “Found Motorola L6 Modem”. You’ll meet the “Add New HardwareWizard” dialog box then. Follow the instructions until you told tospecify an exact location for the corresponding hardware, which is yourMotorola L6 phone.
When your files are located, a dialog box will warn you whether tostop or continue the installation since the driver hasn’t digitallysigned by Windows. Click “Continue Anyway”, Windows will start to copythe driver files into a specific location. As the process finished,your Motorola L6 phone will automatically turn its mode to Loud andstart charging the battery.
That’s all. Next thing you should do is set up your internet connection through Start > Settings > Control Panel > Network Connections. Get yourself to the Files menu and choose New connection.. You’ll be guided with a step by step New Connection Wizard.
Jul 21, 2009 | Motorola Mobility L6 Cellular Phone
Blackberry curve browser problem
Try to do a hard reset on the phone, which means take the battery out of your phone with the power still on before you do it. Then give it about a minute, and place your batter back in the phone. Blackberrys take a while to load after a hard reset has been done on the phone so be patient with it. once it is all loaded and ready to run, try browsing the web. If that does not work, contact your cell phone provider to see what the problem is.
Mar 18, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Nokia 6600 Bluetooth, gallery problem.
yez.,, its a hardware problem, you just have to replace the bluetooth module of your phone, or go to a near repair cellshop and ask them to do that,, when you open gallery it only stuck up on opening and when u use your camera, it says temporary overload ryt?? and some application won't work, the only thing is to replace the bluetooth module of your phone
Aug 24, 2008 | Nokia 6600
3230 problem
NOKIA 3230 KEYPAD NOT WORKING
Aug 10, 2007 | Nokia 3230 Cellular Phone
Nokia 6600 Logo
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
ASHRAF CA
ASHRAF CA
