My cd rom and cd burner do not work drivers are installed but cant find hardware code 41 appears
  • shiloh17 Mar 15, 2008
    i found out how to fix it when i reinstalled itunes which i had previously deleted both cd roms worked
  • 133 Answers
To resolve this behavior, follow these steps:
Start Registry Editor (Regedt32.exe).
Locate the UpperFilters value under the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
On the Edit menu, click Delete, and then click OK.
Locate the LowerFilters value under the same key in the registry:
Posted on Mar 14, 2008
Am getting error no 41 i.e my laptop is not recognozing my dvd
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Nov 25, 2010 | Philips (JR4DVDRWK/00) DVD+RW Burner
My tsstcorp cdw/dvd TS-H492C rom is not being displayed on my comp....it displays a message... Dat is windows successfully loaded the device driver for this hardware but cannot find the hardware device....
Hi
I see this is a month old,but I'll answer this for anyone doing a future search that may come across this thread.
The link is to Microsoft's on-line repair center.This will fix several error codes,including 41,and is probably the first thing to try when your optical drive is installed but Windows can't find it.
If this helps with your problem,and anyone in the future,would you rate my post please?
Thanks
Bob
http://support.microsoft.com/gp/cd_dvd_drive_problems
Jul 12, 2010 | Samsung TS-H492A/RSWN CD-RW/DVD-ROM...
DVD-ROM and DVD+RW
Did you do a system "Restart" after the driver install? Sometimes that is all that is required to enable the device to work.
Sep 11, 2009 | Intel DG31PR Motherboard
Dvd-rw gwa-4082n wont work
tampered connection cable with DVD rom is the problem get it repaired it will take not more than 5minutes to repair.
pls rate my solution
thankyou
Feb 11, 2009 | LG GWA-4082N DVD RW Dual Layer Burner
Code 41
This error occurs when Windows does not detect a non-Plug and Play device.If the device was removed, uninstall the driver, install the device, and then click Scan for hardware changes to reinstall the driver. If the hardware was not removed, obtain a new or updated driver for the device. Hope this helps
Feb 16, 2008 | LG GSA 4163B DVD±RW Dual Layer Burner
Computer can't find it
hi ...
try to change jumper position to slave or to master and start up you xp pro
good luck
Oct 22, 2007 | Samsung SW 240B CD-RW Burner
My CD-RW is not working.
Is the hardware installed properly? does it lights up? can you provide more info?
Aug 24, 2007 | LG (gce-8525bb) CD-RW Burner
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
