Question about Philips 26PF5320 26 in. LCD Television
I can't get my remote to work (i changed the batteries). I now have satellite TV. I need to use the AV button on the remote in order to view DVDs. My satellite remote is no help. Do I need to order a new remote? Thanks, I have a Philips 26PF5320 LCD/HD TV
  • 476 Answers
It's unusual for these remotes to break down, but they often suffer from bent contacts in the battery slot.
When the battery is inserted with the tray, if makes contact with a spring terminal on the main board, and a spring terminal at the back of the battery.
First check that the replacement battery is the correct type. If the replacement is too fat, then the board spring has probably been flattened, otherwise the back spring has probably been pushed in.
Either way, its quite easy to fix.
Board Spring: using a thin wire, such as a paperclip or precision screwdriver. gently lift the two contacts from the back until they stay up from the board.
Back spring: using the same tool, hook into the loop on the contact, and gently pull forward.
This will ensure that proper contact is made when the battery is inserted.
Don't worry if you pull the contacts too far, because the battery will push them back.
In this case, remove the battery tray
Posted on Mar 14, 2008
How to source AV Input on remote
Search Results
    How do I change the input on my television? ' FAQ ' Cogeco ...
    CogecoClick on the TV button near the top of the remote. Click on the video source button on the bottom left corner of the remote. Using the arrow keys to highlight/select the inputyou want. Some televisions may require pressing the source button multiple times to change the inputs.
    Understanding Inputs - Harmony Support - MyHarmony
    Televisions, AV receivers, soundbars and other home electronic devices switch ...Devices with toggle (or cycle) inputs have a single button on their remote that ... In the below example, you would press the Source button to bring up a list of ...
    Changing AV input on TV using Sky remote ' AVForums > ... > Satellite TV, Sky TV & FreeSat
    Changing AV input on TV using Sky remote. Discussion in 'Satellite TV, Sky TV ...VSX-924 LG simplink changing AV source to TV. Posted By djrobmac In AV ...
    Selecting the DVD, VCR, Game Console, HDTV, Camera, or ...
Feb 08, 2016 | Venturer KLV39150 15" Under Cabinet LCD TV...
Why wont my hitachi remote RC1205 work on my TV, I've changed the batteries
If you changed the batteries and installed the replacement batteries correctly, the remote may have failed and will have to be replaced.
Jan 18, 2015 | Hitachi Televison & Video
Sony RM-Y186 remote will not work what is wrong with it?
1. don't press the buttons like a hardcore boxer :)
2. disassemble the remote control. No big deal. It has a plastic housing the buttons are on a plastic/rubber sheet. (remove batteries first)
3. clean the plastic/rubber sheet where the buttons are both on top and rear side. Take some clean petrol from the groceries next corner, and clean the black pads on the bottom of the buttons + also on the circuit sheet you'll find inside the remote control.
4. Put everything together and...
... TADAAA! It works again. :-)
Jul 20, 2014 | Sony Wega Tv Remote Control Rm-y180 4...
I misplaced the remote to the tv, but can power on and off with the satellite remote. I powered off and somehow the tv has switched to AV status and I am unable to change it back to tv status. When I press...
Hi There,
Don't press any more buttons at the moment as you may further complicate the problem. I really need to know which satellite remote you have to give the correct instructions, but the following applies to a large number of TVs.
First, press the TV button on the satellite remote. This simply ensures that any buttons pressed afterwards control the TV and not the satellite box.
Next look for a button on the satellite remote labelled INPUT or SOURCE. If you can find one of these buttons, try pressing it repeatedly until the picture from the satellite channels appears on the TV screen. If there is a TV/AV button on your satellite remote, press this once.
If you cannot find any of these buttons on your satellite remote or they do not switch the TV back to TV mode, please let me know which Satellite remote you are using. If you don't have a model number for the remote, please let me know the brand and model number of the satellite receiver.
Hope this helps. Please reply to me by clicking on "Add a comment" below your question.
Feb 27, 2011 | Durabrand Televison & Video
I have a Akai TV1420 and I am trying to operate a DVD from it - but cannot find an AV button on the TV remote control. How can I find a channel to view DVDs?
Look for a button marked "source" or "input" on the remote. Alternatively, press the "menu" button and look for an option marked "source" or "input" and selevt AV1, AV2 or DVD. hope this helps.
Jan 21, 2011 | Televison & Video
Have new 55ux600u toshiba. Hooked up a one year old wii and get no color
The 55ux600u toshiba hdtv has a setting that needs to be changed with the wii in order to get color.
1. Click 'Menu' on the TV remote 2. Arrow over to 'Preferences' 3. Arrow down to 'AV Connection' 4. Click 'OK' 5. Arrow down to 'AV Input' 6. Change setting from 'ColorStream HD' to 'Video' by clicking the right arrow. 7. Hit the'Exit' button on the TV remote.
This will give you color for your Wii. You will have to change this setting back in order to view DVDs in color. :-)
Jan 01, 2011 | Video Game Consoles & Games
What channel should I turn my tv to? i have dish
If you have Dish, your remote should have a selection for TV/VIDEO located just under the SAT and TV buttons on the upper left of the remote. Push the TV button, push the TV/VIDEO button, and you should be able to reset the TV to Satellite.
After you've reset the TV, remember to push the SAT button on the upper left to allow your remote to access the satellite.
Jan 28, 2010 | Nintendo Wii Console
Philips 26PF5320 26 in. LCD Television Logo
279 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
