Question about Sewing Machines
Bernina 1300 dc overlocker skipping stitches
Hi, my machine has recently started skipping stitches on the chain stitch when i use it to overlock and chainstitch together, i have replaced the needles and am using the recommended bernina overlocker needles, im using size 80/12 on slightly stretchy medium fabric i dont know a lot about what needles to use but ive used these before on this fabric and its been fine.i have checked all the tensions and rethreaded the machine several times but this keeps happening and its driving me mad!
  • 6 more comments
  • Anonymous Apr 18, 2008
    Bernina 1300dc:I have been sewing for nearly 50 years and have never been as frustrated with a machine as I am currently with this Bernina. I have run costume departments, sewing is my life, it's my profession, to be honest with you I don't believe that there is a solution, getting this machine to preform the way that it should is just not going to happen. I tried different threads, different needles and found that my old Bernina serger works better than this one. I purchased this model because I deal with a lot of high-end clothing, knits which may need the cover stitch, and I can't use it....very frustrating.
    Sorry, not much help. I plan to speak with the local Bernina shop, I've had this machine approximately eight months and find myself avoiding using it because it's just not worth my time. I always trusted Berninas, have recommended this brand of machines to others and, had them in shops I ran but, no more. Bernina need to admit that they put out a lemon!
  • QueenAnn Apr 18, 2008
    out a lemon!
  • Anonymous Jan 05, 2009
    I have the exact same problem as Queen Anne, with my Bernina 1300DC. I bought it for the cover stitches and I have yet to have them work without skipped stitches.
  • martylev Mar 29, 2009
    I have the same problem and have had the Bernina Serger 1300DC serviced by a VERY REPUTABLE Bernina dealer. They cannot fix the problem. Before I have this sent off to Bernina does anyone have a suggestion. How is the needle depth adjusted? This was a suggestion in one of your notes. Thanks for your help.
    [email protected]
  • kmnr2000
    kmnr2000 Nov 19, 2012
    I'm having the same problem. After hours of frustration and finally finding a video in line I was able to thread and set up machine properly. i hemmed a light weigt knit top with only a few skipped stitches. a sample on cotton fabric, two layers, had turned out perfectly. I am now tryin g to hem another knit shirt, medium weight, and am having no luck what so ever. I'm playing with adjusting the needle tensions but am getting no where fast. I hate to say how many hours I've been sitting here ripping out bad stitches. If someone has a solution please pass it along. Thanks, Kathy
  • genaburtch Jun 03, 2013
    well, I agree about the Berninas...I have an old 2000DCE and hate hate hate to change anything on it. It is so tempermental. If I get it working, I don't change it. Recently had to try to get it converted to coverstitch for something. What a mistake, I the stitch is horrible! I have been sewing since I was four. I had an old basic Bernina that lasted forever and never failed me. But not this thing. It looks beautiful and sews terrible. Very, very finicky. I always tell people that I sew for that it will take from 1 day to 1 month depending on whether my machine funks out or not!
  • Anonymous Mar 20, 2014
    Hi, I have broken a needle. Is there a brand or certain size I should use?
    Thank you in advance
  • Anonymous Mar 31, 2014
    I have a Bernina serial number 397445 I would like to know what size needles and bobbin's ? and what year this machine is ?
  • 106 Answers
Make sure the chain stitch thread is threaded exactly as it should be, make doubly sure the thread comes off the bobbin vertically and runs through all eyes smoothly. Any faults in the threading causes extra tension at the needle despite what the tension is set on.
If this is not the cause then the needle depth and the looper timing needs checking.
Rob
Posted on Mar 30, 2008
SOURCE:
I am trying to teach myself to sew.... what is a serge stitch an how do I set my brother sewing machine to do it?
A serger (overlocker) is not a sewing machine. If you look at the inside seams of a purchased t-shirt, you will usually find a serge stitch that was created using a serger (overlocker). A serger/overlocker usually uses 3 or 4 threads to create that stitch. It also trims the fabric at the same time it finishes the fabric edge. The serge stitch is a chain stitch that, if you pull a particular thread, the entire stitch will come undone.
Your sewing machine is not able to create that same stitch. Your sewing machine may have what is called an "overlock" stitch, but it will use only 2 threads (the top and bobbin) to create that stitch. You would have to consult your owner's manual to see if it can make an overlock stitch.
Different Serger Stitches and How to Use Them
The BERNINA Serger Overlocker line BERNINA
May 05, 2017 | Brother Sewing Machines
How do I get a balanced tension with my Elna 624 overlocker?
The best way is to thread with 4 separate colors of thread and then studying the stitch result. With the 4 colors, you can easily tell which thread tension is "off" and whether it should be tightened or loosened. However, a serger is not like a sewing machine where you can set the tension and use that setting for most projects. With a serger, a change in one or a couple of thread tensions will create a totally different stitch.
For most machines, there is a mark at the midway point on each tension control that is the "optimal" tension for a 4-thread overlock. HOWEVER, every machine differs, so these settings may need to be tweaked.
Make It Handmade Perfecting Serger Overlocker Tension
The Anatomy of The Best Serger Tension My Tips Bonus Unpick it Serger...
How to Adjust Thread Tension on an Overlocker Singer Australia
You may want to download the serger workbooks at this site (Bernina), and work through each of the stitches. Make notes in the workbook as to how you have set up your machine to get the best of each stitch. This will be a great reference manual for many years.
Bernina Mastery Workbooks
Feb 23, 2017 | Elna Sewing Machines
How do I make a new buttonhole on my 1260? B
Hi Karen,
Sew two parallel lines of overlock stitches very close together. Then see overlock stitches accros the ends of the first lot of stitches to close them off. Finally, carefully cut the fabric between the first set of stitches. Try this out several times on some scrap fabric. You'll need to get the spacings sorted out.
Jul 19, 2015 | Sewing Machines
My overlocker is skipping stitches, I have re threaded it and replaced the needles and oiled it, it is still skipping stitches. any ideas as there is nothing else in the manual to tell me what to do>
Check to make sure you have the right needles and that the thread and needles are compatible. Usually, coverstitch machines use a slightly longer needle than overlockers and sometimes people get them confused. Also, it might have something to do with the fabric you are overlocking. Try stitching a different kind of fabric and see if it is still a problem.
Mar 09, 2015 | Sewing Machines
Overlocker looping(forming chain stitch) not stitching on fabric
try new needles
make sure tension is correct
could possibly be in need of some adjustment
Mar 29, 2014 | Sewing Machines
What should the tension settings be for Elna Club 4D overlocker
Hi Nikita86,
Do you perhaps still have a scanned copy of the Club 4D overlocker?
Jul 10, 2012 | Elna Sewing Machines
What should I pay for a Bernina 1300dc. It has been used once and stored in a box for years. All parts, manual are included.
Take a look on amazon for Bernina sewing machines... You can find there various prices (100% cheapest on the net). Here: . Amazon com bernina sewing machines. I hope this was helpful. Cheers
Sep 21, 2011 | Sewing Machines
Starting overlocking
hi there,
check & correct the FF:
  • Correct thread tension.
  • Replace needle.
  • Replace needle with correct size.
  • Use proper thread or needle.
  • Check threading order.
  • Increase pressure on presser foot.
  • Reset needle.
Jun 01, 2009 | Bernina Sewing Machines
Sewing Machines Logo
1,848 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
